"tango4" wrote: Aerotow no problem. Don't try it with a winch though! Why not? Winch is easier than aerotow: The rapid acceleration means you have instant roll-axis control. (done it several times, easy as pie) - mark |
![]() "Mark Newton" wrote in message ... In article , "tango4" wrote: Aerotow no problem. Don't try it with a winch though! Why not? Winch is easier than aerotow: The rapid acceleration means you have instant roll-axis control. (done it several times, easy as pie) - mark Instant roll control and no prop wash to deal with. There was a 'lone ranger' who built a remote controlled winch 20 or 30 years ago. He could launch himself with no help at all. I'd like to know more about that winch. Bill Daniels |
Bill Daniels wrote:
Instant roll control and no prop wash to deal with. Actually, the prop wash will help, by providing some airflow over the wings and control surfaces, giving you a certain degree of control, even before the speed builds up. CV |
![]() "CV" wrote in message ... Bill Daniels wrote: Instant roll control and no prop wash to deal with. Actually, the prop wash will help, by providing some airflow over the wings and control surfaces, giving you a certain degree of control, even before the speed builds up. CV Actually, I'd contend this causes most wing drops since it's usually not evenly distributed over both wings. |
CV wrote: Bill Daniels wrote: Instant roll control and no prop wash to deal with. Actually, the prop wash will help, by providing some airflow over the wings and control surfaces, giving you a certain degree of control, even before the speed builds up. We're talking about a winch, CV. You don't have to wait until the speed builds up :-) - mark |
You need to be "very very" quick on release if the down wing
does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, fatalities have happened with that scenario. The winch rapid acceleration is a two edged sword ,as long as you get the wings both moving forward its easier than a aerotow wingdown takeoff. gary "Mark Newton" wrote in message ... In article , "tango4" wrote: Aerotow no problem. Don't try it with a winch though! Why not? Winch is easier than aerotow: The rapid acceleration means you have instant roll-axis control. (done it several times, easy as pie) - mark |
"goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
Mark Newton wrote:
You don't start with a "down wing". You prop the wings so they're level. I always start with a "down wing" when being alone. No problem whatsoever. Stefan |
The point is this "cartwheel scenario" has happened before.
I believe there was a case in Europe not that long ago. gary "Mark Newton" wrote in message ... In article , "goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
![]() "goneill" wrote in message ... The point is this "cartwheel scenario" has happened before. I believe there was a case in Europe not that long ago. gary Indeed! If a wing tip catches on something like tall grass, the combination of high acceleration and CG hook can be disastrous. This sometimes results in a flick roll and inverted crash. This is why the takeoff area of winch operations needs to be smooth and the pilots 'spring loaded' to release if the takeoff roll swerves. If the takeoff surface was smooth asphalt and the glider had tip wheels or low-friction skids then starting with a wingtip propped up on a stand or box might not be so dangerous. It pays to be careful though. Let me add just how sweet it is to accelerate and lift off without the turbulence, noise and dust of a tow plane. Compared to air tow, a winch launch area is downright civilized. Bill Daniels |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 02:21 AM | |
Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 10:50 PM |
Pegasus/TRACE Launch Photos Posted | Brian Webb | Military Aviation | 0 | February 21st 04 03:50 PM |
Friendly fire pilot may testify against wingman | Otis Willie | Military Aviation | 0 | October 11th 03 09:32 PM |
