Motorgliders and TE Probes
Hi,
I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul Remde wrote:
is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The vario will not be too accurate in the propwash, but who needs an accurate vario when the prop is turning? Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? Not necessary, but recommended. Stefan |
Hi,
I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Paul Remde" wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
I think most of the newer variometer systems can electronically calculate
total energy, without the need for any TE probe...I have tried this and while I haven't met with great success in comparison to using an actual TE probe on my DG-400, I would speculate that the Europa is not going to be high enough performing to know the difference in the very minor differences between a probe and what the vario system will electronically compensate. I will say that when I tried the electronic setup in my DG, there was a gust filter the previous owner had installed, which I didn't know about until later...after removing that filter, my TE probe was much more accurate, but my guess is that electronically I could have compensated the system fairly accurately. Steve. |
Paul:
I got a nice manual pneumatic switch for use in my oxygen system from Mountain High a few years ago. You might check with them. Ray Warshaw "Paul Remde" wrote in message news:f%Lod.141383$R05.121337@attbi_s53... Hi, I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Paul Remde" wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul Remde wrote:
Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Miniature toggle routing valves are also available
through MSC Industrial Supply Co. mail order. This is page 3950 of their on-line PDF catalog. Note the routing valve at mid-page. http://tinyurl.com/5hv9o This is their web site. http://tinyurl.com/629x5 At 20:30 23 November 2004, Tim Mara wrote: Clippard Industries in Cincinnati Ohio makes several types of Pneumatic switches..... these were commonly used years ago back when sailplane pilots used to have to make their own and a few variometer manufacturers like Richard Ball made alternative Pneumatic inputs for Netto's and Speed to Fly variometers from normal TE variometers tim 'Paul Remde' wrote in message news:f%Lod.141383$R05.121337@attbi_s53... Hi, I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com 'Paul Remde' wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
My Guess on the Europa is that with the front mounted Propeller and
the rather High Vertical Tail, He could just mount it has High as possible on the Vertical fin and have little problem with the TE Prob. I suspect that most of the prop wash would miss the TE prob anyway. Brian |
On Tue, 23 Nov 2004 14:49:21 -0800, Tim Mara wrote:
Clippard Industries in Cincinnati Ohio makes several types of Pneumatic switches..... these were commonly used years ago back when sailplane pilots used to have to make their own and a few variometer manufacturers like Richard Ball made alternative Pneumatic inputs for Netto's and Speed to Fly variometers from normal TE variometers tim "Paul Remde" wrote in message news:f%Lod.141383$R05.121337@attbi_s53... Hi, I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Paul Remde" wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com I mounted a vertical TE Probe on the top of the fin on our SF25C FALKE motorglider, connected to a dedicated vario (Borgelt B40). The aircraft already had a Winter vario connected directly to the static ports which acts more like a VSI. The TE probe seems to work very well. The sensing holes near the tip of the probe would be (from memory) about 10 inces above the top of the fin. Regarding switches to change from static to TE, many GA aircraft use such switches to give an alternative static source for the instruments in case the primary static ports become blocked. Maybe one of the aircraft supply houses would have them. Cheers, John G. |
switches..... these were commonly used years ago back when sailplane pilots used to have to make their own and a few variometer manufacturers like Richard Ball made alternative Pneumatic inputs for Netto's and Speed to Fly variometers from normal TE variometers tim "Paul Remde" wrote in message news:f%Lod.141383$R05.121337@attbi_s53... Hi, I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Paul Remde" wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Similar Threads | ||||
Lambada vs Sinus motorgliders | Andre van Niekekerk | Soaring | 2 | June 9th 04 11:28 AM |
Motorgliders (long) | JJ Sinclair | Soaring | 98 | October 9th 03 10:11 PM |
Motorgliders (long) | M B | Soaring | 1 | September 23rd 03 09:15 PM |
Latest Newsletter Pipistrel Motorgliders | Michael Coates | Home Built | 18 | September 19th 03 01:25 AM |
Latest Newsletter Pipistrel Motorgliders | Michael Coates | Soaring | 20 | September 19th 03 01:25 AM |
