I'm sure I've seen an article about anti-collision
radar available for corporate aircraft. I believe that they are available, but am unsure how prevalent they are. There was some comment about this in AOPA(?) mag a couple of years ago. At 18:00 26 November 2004, Btiz wrote: Nyal, corporate radars are WX radars and not designed to me air-to-air intercept radars.. you'd be better off stuffing in a transponder for their TCAS and for ATC to really see you. BT 'Nyal Williams' wrote in message ... At 03:00 26 November 2004, Ralph Jones wrote: [snip] Boating stores sell radar reflectors made of cardboard and covered with aluminum foil. They are in three parts and can be disassembled. When put together they make a sphere about 12-14 inches across and they provide the 3D right triangles that are supposed to reflect a signal back. I inquired about their use in gliders (practically no weight and could go in fuselage behind wing) and someone told me they would not give a strong enough signal for aircraft use owing to the speeds involved. I have no idea about the validity of this statement. Couldn't hurt to try it. That is a corner reflector: three flat, mutually perpendicular surfaces. It has the special geometric property that a signal striking it from any direction will reflect from surface to surface and wind up going back exactly the way it came. On radar, it looks much larger than an irregular-shaped object the same size. Apollo crews left at least one optical corner reflector on the moon, and astronomers can bounce laser light off it to make precision orbital measurements. Signal strength is not the problem: a fiberglass ship with a one-foot corner reflector inside it will look bigger than a metal sailplane. The bad news: air traffic control radars are 'moving target' systems, which means they filter out returns that don't have any Doppler shift to indicate a moving object. I don't know what the minimum detectable speed is, but if you're under it, they just won't see you. rj What about the radars in corporate aircraft? If they can pick it up I might consider stuffing one in the Discus. |
Nyal Williams wrote:
I'm sure I've seen an article about anti-collision radar available for corporate aircraft. I believe that they are available, but am unsure how prevalent they are. There was some comment about this in AOPA(?) mag a couple of years ago. It's called TCAS (Traffic Alert/Collision Avoidance System). It's not radar based, it broadcasts an interrogation signal which causes any nearby transponders to respond. It calculates range and bearing to transponders that respond, and shows them on a display in the cockpit. If there appears to be the threat of collision, it sounds an alarm. If the other aircraft is TCAS equipped, the two units actually negotiate an avoidance strategy, then advise the pilots how to maneuver away from the other aircraft. Marc |
