No two Cobra trailers seem to be alike so I'm not sure if mine (ca.
1992) is a close match to yours. But my trailer's strut isn't a gas spring, it's a damper; i.e., it doesn't push the trailer away from the tow vehicle at all but rather damps the movement during acceleration and braking. With older trailers which lacked such a damper, hard braking would sometimes cause the surge-brake sliding tongue to compress suddenly, applying full brakes and often causing the wheels to hop off the ground at the slightest bump in the road. When they landed again with the brakes locked, the tongue would extend just as quickly before being compressed violently, repeating the cycle and leaving little chirp marks of rubber on the road. To remove the damping strut, I have to remove the inner tube to which is bolted the hitch. That's usually (see below) pretty easy: you can leave the hitch on the inner tube; just remove the big bolt (maybe two, I'm not sure) that holds it all together and slide the inner tube forward out of the outer tube. You must remove remove the bolt that retains at least one end of the damping strut first, of course. Years ago, after the trailer sat for a while, moisture apparently caused the two large plastic bushings in which the tube slides to swell, plus the inner tube rusted/corroded. The tongue assembly was frozen in place no matter how hard we pulled (we didn't try Udo's trick). I chained a long lever arm to the inner tube and was able to rotate the tube slightly back and forth while I slowly pulled it out. I had to clean up/smooth the inner tube's surface where it slides in the bushings. More important, I also had to open up the bushings a little bit with a sanding wheel on a long shaft (the front bushing is accessible but the aft one is recessed in the outer tube) before it would all go back together properly. Keeping the bushings lubricated properly minimizes this problem. After I use a grease gun on the fittings, I remove the bolts holding the two tubes together and rotate the inner tube 360 degrees to distribute the grease all the way around. Chip Bearden Actually, the tongue strut still moves just fine. The strut has lost it's charge so it will not push the trailer away from the tow vehicle at a stop. I just can't figure out how to remove the strut from inside of the tube that goes into the trailer. Brian At 23:00 28 November 2004, Udo Rumpf wrote: Brain Use your vehicle to pull it apart. Install the hitch again Tie your trailer to something sturdy hook up your vehicle, pull it off by driving forward. If you have a shop try to set-up a lever arrangement. If the tongue strut did not move in normal operation you may need several 100 lbs of force to get it moving. Udo 'Brian Iten' wrote in message ... I have a 1995 Cobra trailer for my Discus. The tongue strut is shot and needs to be replaced. Can anyone give me some advice on how to do this? I removed the hitch, all the bolts along with the bolts holding the strut in but can not pull the strut out of the front. Thanks for the help and advice, Brian |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
Cobra Trailer Question | Deputy Dog | Soaring | 7 | January 3rd 04 03:11 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM | |
Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 03:21 PM |
