Just to look at this a little more ... small fixes are often the most
difficult. As you sand down the newly applied material, you ultimately hit the surrounding area and remove gelcoat there ... sometimes to the point where the underlying darker glass surface starts to show. Except for small chips, I always use some type of disclosure agent which shows where I am sanding. I have also used tape to shield areas ... this can help ... and always use the finest grit paper possible ... slower is better. Leading edge sanding around the front radius requires feel and wrist action ... it would be easier to explain on the phone if you want to discuss. KK |
One coat paint for aluminum? | [email protected] | Home Built | 10 | September 17th 04 07:01 AM |
Repairing gel coat chips | Gary Evans | Soaring | 6 | April 27th 04 03:23 AM |
Water-borne barrier coat | larsen-tools | Home Built | 0 | February 3rd 04 08:42 PM |
Refinishing: Who has tried a shortcut? | Ian Forbes | Soaring | 60 | December 26th 03 09:30 AM |
Poly paint | Miguel Lavalle | Soaring | 18 | October 30th 03 08:55 PM |
