![]() wrote in message oups.com... It does provide good venting of the tank. It does have a drawback in that if the tanks are full and the plane is slightly wing low (sitting with the wing wheel on, for example), water will tend to siphon from the low wing out the vent hole. This vent is about 5/16th diameter on my Zuni. Steve, I should maybe manifold all three lines at the turtle deck that would prevent siphoning. I believe also the 5/16" vent tube will be enough, as each tank is relatively small and all will have a separate dumb valve. The centre tank is 2 x 8 gal. front 2x 6 and the back 2x5gal. one or two foam ribs outboard of the root rib. The intent of this system was to keep the water plumbing all in/on the wing. That way, there would be no leaks into the fuselage. Is this similar to what you are planning to do, but with one tank ahead of and one behind the spar? I was planning on placing the valves in the front and back tank and stay with a standard 2 ball valve set-up for the spar tank. Tank you Udo |
Udo Rumpf wrote:
Steve, I should maybe manifold all three lines at the turtle deck that would prevent siphoning. Now that I think about it a bit more, it is not so much siphoning, as simply draining. With the wing low enough that the water is up to the level of the vent at the outboard end of the tank, and the exit point of the vent tube from the aircraft is below the water level in the tank, it will simply drain. I suspect there is a point in the vent tube that goes above the water level in the tank when it is sitting with one wing level with the ground. I think if you just keep them above the level of the water in the tank, it should be OK. Manifolded together, or individually. I would make sure it is either outside the airplane or in an area that can drain, as if you tow the ballasted glider around a corner, you will likely push some water into the vents, even if it was level to start with. Steve |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
ASW27 Wing water tank | Ray Gimmey | Soaring | 0 | November 10th 03 10:35 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
