Greg Arnold wrote:
Why "slow blow"? I am pretty sure my gliders always came with "fast blow" fuses. Paul Remde wrote: Hi, Make sure it is a "Slow Blow" fuse. 1 A for the GPS-NAV and 2 A for the 302 would be a good start. Paul Remde "Greg Arnold" wrote in message news ![]() cernauta wrote: Brian Iten wrote: . I have looked in the appropriate manuals for the proper fuse size but can not find anything. Can anyone help me with this? Hi, 1 Amp is usually fine, and easily available. Aldo Cernezzi The 302 manual says the instrument uses 900 mA when hooked to an Ipaq with backlight on, so a 1 amp fuse might be a bit small. Slow blow is usually used for motors, where the initial current flow greatly exceeds normal operation. For electronics, the general rule is a fast blow fuse. All electronic equipment have capacitors in the power supply that cause a greater inrush. I am not sure if the extra size of the capacitors of the 302 would cause an inrush current excessive enought to warrent the need of the slow blow. Maybe someone else can provide some emperical test results. The general rule for the size of a fuse is twice the normal current flow. The purpose of a fuse is to keep the wire from burning if there is a short. A fuse doesn't do a whole lot for protecting the equipment. If there is an internal short in the equipment, the damage to the equipment has already been done. The equipment fuse simply protects the internal wiring, or circuitry that leads the the failed component. That is why wiring fuses, or breaker panels are at the power source. There should be a fuse right at the battery. The fuse wouldn't help if the battery is behind the seat, and the first fuse is behind the panel. With that arrangement, a frayed wire at the panel would create a fire between the battery and the panel. This main fuse, located at the battery, is sized for the gauge of wire that leads from the battery to the distribution panel. The distribution panel breakers should be sized to the wire that leads to each piece of equipment. It is ok to make that fuse smaller than the wire size dictates, and size the fuse based on the current draw of the equpment. |
Commercial - Updated Cambridge 302A | Paul Remde | Soaring | 2 | December 16th 04 07:35 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Cambridge Instruments | Ian McPhee | Soaring | 2 | June 18th 04 10:14 AM |
Cambridge Aero Explorer Fix | Guy Byars | Soaring | 8 | May 19th 04 03:04 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
