Cockpit Placards
Old January 11th 05, 04:19 PM
Brian,
I had my placards made by Signs Now (local sign shop) They are black
vinyl over white painted aluminum about .040 thickness. I provided the
text, the font size and spacing. $25 later, I had placards to cut out
and place where I wanted them.
Clark
Old January 11th 05, 04:55 PM
Pete Reinhart
Brian,
You can make some yourself if you are handy.
Copy the placards in your pilots handbook on to regular copy paper.
Get two sheets of light plexiglass at the hardware store (Lowe's).
Wax 'em up three or four times with a good grade of paste wax.
Laminate the placard sheet between two layers of light fiberglass and place
the second sheet of plexi. on top to get a nice finish.
West System epoxy is cheap and does well for me, and it's readily available
most every where.
You can use the same process for othe things like operating limitationa
etc., by typing up what you need on you computer.
Stick 'em on with your favorite glue (contact cement?).
Hope this helps.
Cheers!
Brian,
Clark
backup cockpit lighting Josef Burger Instrument Flight Rules 35 January 2nd 05 01:23 AM
Cat in the cockpit forces emergency landing John Ousterhout Piloting 7 August 14th 04 11:10 PM
Antonov vs Galaxy cockpit Emilio Military Aviation 13 July 2nd 04 06:15 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
Cockpit sizes of standard Jantar goneill Soaring 2 December 28th 03 11:29 AM
