Battery for gliders
Old January 12th 05, 05:58 AM
keithw
Powersonic has a 8 ah battery that is the same size as a 7 ah.
keithw
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old January 12th 05, 11:17 AM
Bob Fidler
EaglePicher has a 9A same sixe as a 7A, cost me about $20.
Bob Fidler
"keithw" wrote in message
keithw
fly -
Old January 12th 05, 08:02 PM
Eric Greenwell
Can you give the model number and where you bought it? The only Eagle
Picher I can find that is the same size as the usual 7 AH is also 7.2 AH.
Eric Greenwell
Washington State
USA
Old January 12th 05, 10:53 PM
Nobody has mentioned the obvious. Not everybody is using the same discharge
time.
Some are 10 hr, some are 20 hr rates. It makes a difference. Easily enough
to
change the ads. Longer times (lower discharge rates) make their advertising
look better.
The other technique is to change the discharged voltage, or the charged
voltage.
If you want a better comparison, find the curves and compare them. And the
weights.
And the size. You might be surprised to find that there is little difference
in the
capacities. Chemistry is chemistry.
The other item is to pick a bingo voltage that is correct for the
application, not the
battery. Compare the curves down to that point. If the radio or other
electronics start
to go south at 11 volts, while loaded, the curve below 11 volts will not
take care of
everything that you want to do.
Hence twice the batteries so that the amp-hours are way up there, cause you
can
only use a part of them.
Dennis
Eric Greenwell wrote in message ...
Eric Greenwell
Washington State
USA
Old January 13th 05, 04:19 AM
Michael McNulty
" wrote in message
snip
weights.
difference
in the
Chemistry determines the voltage, but the capacity is set by geometry and
design details. I know that Eagle-Picher has been working on inovative
woven mat designs to increase the capactiy of SLA batteries; perhaps the
unusually high capacity battery (for its size) cited earlier in this thread
uses this technology.
snip
Old January 13th 05, 04:12 AM
Paul M. Cordell
Even @ 7 ah, we should support our own. The President of Eagle Picher
flies a Discus 2!
Old January 14th 05, 07:36 PM
Tim Mara
I used to offer Eagle Picher batteries.......the spec's looked impressive
but honestly I had more complaints with these than all other types I offered
and ended up replacing more and more often than others....finally elected
not to continue with this brand and offer now just Powersonic
batteries.......these are low cost and have proven to be excellent.
tim
www.wingsandwheels.com
"Bob Fidler" wrote in message
Eagle Picher Model No. CF-12V9
1-800-201-0215 or
I purchased from a local battery store in Michigan:
Batteries Plus 248-644-0666
AH.
Eric Greenwell
Washington State
USA
Old January 13th 05, 02:23 AM
Andy Blackburn
These 8Ah batteries have worked well for me.
http://www.zbattery.com/zbattery/hr9-12b1.html
They are 'High Rate' batteries, which appear to work
better under the ~1A that my panel draws. Even so,
each battery last about 5 hours.
9B
time.
Easily enough
to
look better.
or the charged
voltage.
weights.
in the
for the
the radio or other
electronics start
11 volts will not
take care of
can
Dennis
$20.
it? The only Eagle
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 12:07 AM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
