Lycoming 290g Questions
Old December 5th 04, 06:05 AM
Drew Dalgleish
On Sat, 04 Dec 2004 18:01:41 -0800, Ed Sullivan
On 3 Dec 2004 19:52:31 -0800, (Mike) wrote:
Hello All,
An "exhaustive" internet search regarding the 0-290G has left me with
several unanswered questions. I understand that the EAA published a
conversion guide years back that would be very helpful. In the mean
time, I am hoping some of you out there can answer any of the
following questions:
1) Which cylinders may be used (i.e. bolt-on) on the O-290G? I
understand that the stock cylinders, other 0-290 cylinders (D, D2
etc), and 0-435 may be bolted on and used.
2) Which pistons may be used (in native/unmodified form)?
3) Which cranks may be used (in native/unmodified form)? I understand
that "any" 0-320 crank may be installed without modification.
4) What "slight" modifications can be used to up the HP to 150hp?
5) Is the "converted" 0-290G still heavier than an 0-320? Why?
6) Any known sources for 0-290 parts?
Thanks for any help,
Mike
I saw an ad, I think in the latest Sport Aviation wherein someone
wrote a new manual on the conversion. Price was $40.
EBS
H Mike I can't answer any of your questions but as an owner of an
0-290 D my advice is. These are unsupported engines parts are hard to
find and brutally expensive. If you need cylinders and a crankshaft
it's probably cheaper to buy an 0-320. If you want 150hp you should
buy an 0-320. If you do all the work needed to make it airworthy it
will still be worth next to nothing
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
