Has a glider ever been found using the transponder radar track?
Old January 19th 05, 09:28 PM
Mark James Boyd
COLIN LAMB wrote:
had ELTs and transponders. In both cases, the aircraft was found by luck
and/or good guesswork.
The ELT is not bullet proof. I believe it is likely to survive a crash if
the pilot does, but no more. The installation is also critical. For
example, with a remote antenna, the coax cable could be severed in a crash,
rendering the entire system useless.
Colin N12HS (Yamhill County Sheriffs Search and Rescue)
One of the reasons I wear my ELT across my chest and activate it before
outlandings is for all of these reasons. Plus I can take it in any
aircraft. I also carry handheld radio and cell phone.
Installed ELTs and radios seem really much more delicate than
the personal ELT or handheld radios. And certainly seem
somewhat more delicate than humans. I'd rather have a more
surviveable ELT with my little tiny battery and antenna than
an installed one that will have the coax severed and battery case
crushed.
If my personal ELT is destroyed, then it means my harness broke and
my body is dismembered and obliterated. Yes, it may take
a month for some hiker to wander over my body, but hey, I
wouldn't be in too much of a hurry anyway.
Like I said, I'm interested in cases where an installed ELT
would make the difference between life and death. Beyond that,
I'd like to know how many of these cases wouldn't be
just as solved by a personal ELT activated right before an
attempted outlanding.
I'm not so concerned about the midair/parchuting out cases.
I have yet to hear of any case where someone parachuting out
with a handheld or cell phone would have been better off
with ELT or not...
Mark J. Boyd
Old January 20th 05, 06:24 AM
Duane Eisenbeiss
Centurion wrote:
The possibility is there, but I don't know of any gliders that have
burned after crashing. Does anyone know someone that had a post-crash
fire?
Not a crash, but in the early 60's a pilot dropped his cigarette in a 2-22.
The ship started burning on final. The guys got out immediately on landing
and all the fabric burnt off the 2-22.
Duane
Old January 24th 05, 09:43 PM
BGMIFF
To my knowledge, no cellphone information was used in the Peter Masak
search. He was in mountains with little to no service, and very rugged. The
ELT was the saving grace here!
"For Example John Smith" wrote in message
I'm beginning to wonder if the problems associated w/ELTs don't approach
level of problems associated with a much lower cost and far more
ubiquitous
option--GPS enabled cell phones.
No, a GPS phone won't send out a signal if you crash and yes, we do fly in
a
lot of places where a cell phone conversation composed mostly of "can you
hear me now?" is considered a good connection. That said, the standard of
comparison isn't perfection--the ELT is an unreliable piece of equipment.
If a sailplane goes down, a 'last sighted near' report and a call to the
phone operator would be effective in some cases. Less often than with an
ELT?--that's anybody's GUESS. Do I remember correctly that the cell phone
company was able to provide some information to the teams searching for
Peter Masak, eventhough his phone was not GPS enabled?
This new rule looks a bit to me like a "we've gotta do something"
response.
I'd buy a $300 ELT to comply with the rules but would have a hard time
spending $2k, eventhough from the disucssion it seems like that's the
pricepoint where the product works well enough to be somewhat useful. We
each (should) decide for ourselves what the value is. I look at the
situation and say "this is a low occurance problem with a 'solution' that
only has a 50% chance of helping'. Others say "if it only saves one life
it
is worth it".
YMMV
Brent
"COLIN LAMB" wrote in message
. net...
I am a member of Search and Rescue - on the ground end of things. I
have
been involved in a number of missing aircraft searches and have my own
ELT
tracking equipment. We regularly practice searches in mountainous
country.
My experience has been that when we have a report of a missing aircraft
and
begin the search, that the sparse information we get is ambiguous and
incomplete. By the time information gets to us, it has been through a
number of relays. Our area is the Coast Range of Western Oregon.
Transponder tracking is undependable and late at best. In most cases we
get
no information at all. In one case, involving a fatality, the only
useful
information we had was from a "last seen" report from a fellow pilot.
We
picked a spot on the map that was likely and sent in ground teams on
logging
roads to do a visual search. Weather was bad. We found the aircraft
after
2 days, before either the National Guard or the CAP. The aircraft was
destroyed. After searching the wreckage, we found an orange piece of
plastic - similar to the color used in ELTs - the size of a quarter
dollar.
In a second fatality, our ground team was out searching when a logger
reported a plume of smoke by his cell phone. In both cases, the
aircraft
luck
if
crash,
rendering the entire system useless. I suppose the best solution would
be
to have an ejection system and ballistic parachute for the ELT, so that
just
before a crash the pilot hits a button to eject the ELT and bring it
down
to
safety, But I can tell that idea will never fly.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04
Old January 28th 05, 01:41 PM
can you verify for
me whether Peter's ELT was a 121.5/243 MHz unit or one of
the newer 406 MHz units?
In case others want to know the answer to this, I've been
informed it was a standard C91a 121.5/243 MHz unit. That
gives me some comfort, since that is the type of ELT I have
in my Ventus. In fact, the reason I bought it was after
getting low in a remote area on the same ridges where
Peter's accident occurred.
Additonal Info:
Peter's ELT is one of the later style that uploads info to satellite so
there was a positive ID. Very useful in knowing it was a real event.
UH
Old February 3rd 05, 02:41 PM
I got it wrong. Have since found out Peter was using older style 121.5
ELT. I was there and still had the wrong info.
Sorry for the misinformation.
UH
Lawsuit filed over AFA towpilot fatality Stewart Kissel Soaring 20 June 11th 17 02:58 PM
Soaring Seminar - March 19th - ChicagoLand Glider Council ContestID67 Soaring 4 January 6th 05 11:28 PM
Philadelphia Glider Council hosting Region 2 Ground School chipsoars Soaring 0 December 23rd 04 02:11 AM
Seeking Partners for Minden Based Glider Don Johnson Soaring 0 August 31st 03 07:20 PM
FAA Judy Ruprecht Soaring 51 August 25th 03 07:56 PM
