GPS and DME
Old February 15th 05, 03:58 PM
Newps
Denny wrote:
The bottom line is simple... GPS is a legal substitute where the GPS
distance measurement matches the DME numbers... It is not legal where
the DME is offset from the VOR or airport center and the GPS database
does not correct for this... Increasingly, the DME location and/or the
GPS databases have been matched up so either the GPS or the DME gives
you the appropriate distance measurement, and offset DME's are now
definitely in the minority...
Not quite right. GPS can substitute for DME even when the DME source
isn't in the database. For example my terminal/enroute GPS does not
have the DME location for ILS's. One of the approaches here at BIL
requires DME. I simply make the OM the active waypoint.
You can skip installing the DME and simply check your approach plates
to be sure you are legal (and out of the trees) when shooting a DME
approach with the GPS as your distance measuring equipment...
There is the occasional approach that I run into where the plate says
DME REQUIRED... If you are IMC then you will simply have to shoot a
different approach using your GPS...
Wrong. If you can determine distance with your GPS then you are good to go.
Old February 15th 05, 05:55 PM
Denny
Hmm, not to be difficult, but if you come to the attention of the FAA
after shooting an approach using a GPS where the plate says DME
REQUIRED and the FSDO gets involved, it will be very entertaining to
listen to you lecture the inspector that you can simply create your own
approaches... But, you fly your ship your way and I will fly mine and
we will both be happy...
Cheers ... Denny
Old February 16th 05, 11:13 PM
Newps
REQUIRED
I have DME. It's my terminal/enroute GPS. What seems to be the
problem? A plate that says "DME Required" doesn't actually mean you
need a DME box. Just like the plate that says "ADF Required" doesn't
mean you have to have an ADF, the GPS substitutes for both quite nicely.
Do you have a FSDO that says otherwise?
approaches...
I'm not creating my own approaches. I'm simply following the published
plate. Nowhere does it say that an approach labeled "DME Required" must
be flown with an actual DME.
Old February 16th 05, 11:22 PM
Lakeview Bill
Have you noticed any ILS approaches labeled "ILS receiver" required?
"Newps" wrote in message
REQUIRED
approaches...
Old February 17th 05, 01:08 AM
Newps:
Why use the OM as waypoint? The DME at BIL is at the VOR, isn't it??!!
Which approach are you referring to, the ILS 28R or VOR_DME 28R?
