"John T" wrote: wrote: Most of the plane's damage was on the underbelly of the craft when the landing gear failed to deploy, Riverside County Deputy Sheriff Ryan Renick said. So this genius compounded the problem of running out of fuel with forgetting to retract his landing gear for the emergency landing... Fortunately for him, Darwin's attempt to remove him from the population pool failed. Careful. Failing to retract the landing gear wouldn't have meant a grassy belly. Before nominating the pilot for near-Darwin awards, maybe it would be good to wait for an investigation into the cause(s). Yes -- but the described circumstances would probably call for an FAA checkride. If he overflew the airport at 6000 feet and lost his engine and couldn't make the airport, there is something radically wrong with his technique. 10 to 1 he never practiced power off approaches. |
Orval Fairbairn wrote:
Yes -- but the described circumstances would probably call for an FAA checkride. If he overflew the airport at 6000 feet and lost his engine and couldn't make the airport, there is something radically wrong with his technique. 10 to 1 he never practiced power off approaches. Maybe, but my point was if you're going to start casting aspersions on other pilots, make sure you're accurate in your own statements. "Forgetting to *retract*" landing gear, as "cosmo_kramer" suggested, would not result in a belly landing as described in the OP. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
A Killer Bonanza | Orval Fairbairn | General Aviation | 20 | January 28th 04 10:07 PM |
A36 Bonanza turbo prop | Jeff | Owning | 46 | January 7th 04 02:37 PM |
Bonanza Alternator Light | Peter Shurman | Owning | 0 | July 27th 03 07:42 PM |
Early Bonanza or Apache? | Brinks | Owning | 11 | July 16th 03 06:01 PM |
Bonanza Seat Mod | Ron Natalie | Piloting | 3 | July 10th 03 01:57 PM |
