FS2002 - crash tolerance
Old February 15th 05, 07:01 PM
Randy Wentzel
latet wrote:
Hi,
Is it really so hard to crash C172?
On FS2002, I land with quite high vertical speed (-2 or -3),
the bump and the sound is rather "hard", but the plane is OK.
Of course, I have set "crash tollerance" to max. reality.
I even once lande successfuly with vertical speed -5.
Is that possible on a real plane?
Thanks,
latet
By -5, do you mean -500 feet/minute? A normal descent rate from traffic
pattern altitude to the last part of the final leg is about -500/feet
per minute. However, as you prepare for the landing flare that number
dwindles and final touch down is normally made at just a few negative
feet per minute. I would think that touching down at -500 feet/minute
would destroy just about anything except some military aircraft.
Best,
Randy
Old February 15th 05, 08:08 PM
latet
pattern altitude to the last part of the final leg is about -500/feet per
minute. However, as you prepare for the landing flare that number dwindles
and final touch down is normally made at just a few negative feet per
minute. I would think that touching down at -500 feet/minute would destroy
That's what I thought. Then FS2002 sucks :-(
Can't one make some changes in the config files to make
crash tollerance more realistic?
Greets,
latet
Old February 15th 05, 09:59 PM
codecpage
500 ft/min are like a free fall from 1 ft. It would not destroy the
airplane, at least if you land on the main gear.
Try 1000 ft/min, this is like a fall from 4 ft. and more likely to
cause permanent damage.
Cheers
http://www.codecpage.com
update on Montrose crash Bob Moore Piloting 3 November 29th 04 02:38 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
FS2002 Compass Anomaly - PLEASE HELP GM EWA Simulators 0 January 13th 04 11:20 PM
Sunday's Crash in LI Sound Marco Leon Piloting 0 November 5th 03 04:34 PM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 10:20 PM
