On Mon, 14 Feb 2005 18:58:00 GMT, "Allen"
wrote in :: "Larry Dighera" wrote in message .. . Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 Go to www.cannon.af.mil . There is a 421 page .pdf of the proposed areas. The proposal creates a new MOA on the flight path. Many thanks for that link. Here are some excerpts from the USAF EIS with my comments interspersed: DRAFT ENVIRONMENTAL IMPACT STATEMENT FOR NEW MEXICO TRAINING RANGE INITIATIVE a. Responsible Agency: United States Air Force b. Cooperating Agency: Federal Aviation Administration c. Proposals and Actions: This Draft Environmental Impact Statement (EIS) analyzes the potential environmental consequences of a proposal to modify the training airspace near Cannon Air Force Base (AFB), New Mexico. The proposal would improve airspace for training primarily New Mexico-based pilots. The existing airspace no longer suffices to train aircrews in all of the tactics they will be expected to use in combat. The Proposed Action and two action alternatives are comprised of four elements: modifying the configuration of existing airspace (including expanding the size, operational altitudes, and usefulness of the Pecos Military Operations Area [MOA] and associated Air Traffic Control Assigned Airspace [ATCAA], and moving Jet Route J-74 [J-74] and deconflicting commercial traffic five to seven nautical miles (nm) north of the modified training airspace); creating new airspace (the Capitan MOA/ATCAA to connect the existing Beak MOA and the expanded Pecos MOA); flying at supersonic speeds above 10,000 feet above mean sea level (MSL) or approximately 5,000 to 6,000 feet above ground level (AGL) in the airspace; and extending the use of defensive countermeasures (chaff and flares) to the new and modified airspace. Alternative A modifies the airspace configuration, establishes the Capitan MOA/ATCAA, includes supersonic flight above 10,000 feet MSL, and expands defensive chaff and flares use. Alternative A does not move J-74. Under Alternative A, other deconfliction methods could be instituted to route commercial traffic around active Pecos North ATCAA airspace. Alternative B modifies the Pecos MOA/ATCAA airspace, reroutes J-74 traffic, includes supersonic flight above 10,000 feet MSL, and extends use of defensive chaff and flares. The Capitan MOA/ATCAA would not be created under Alternative B. Under the No-Action Alternative, aircrews would continue to train in the existing airspace, fly at supersonic speeds above 30,000 feet MSL, and use defensive chaff and flares. If proposed alternative A or B were implemented, would the military airspace above 10,000' be returned to civil use? d. Comments and Inquiries: Written comments on this document should be directed to Ms. Brenda Cook, New Mexico Training Range Initiative EIS Project Manager, HQ ACC/CEVP, 129 Andrews Street, Suite 102, Langley AFB, VA 23665-2769. Telephone inquiries may be made to Cannon AFB Public Affairs at (505) 784-4131. ... Under No-Action, aircrews would be required to travel to bases or locations with adequately sized airspace for training with current weapons and tactics. This would both reduce training opportunities and increase costs. ... Under the Proposed Action and Alternative B, rerouting commercial traffic from the current J-74 and other directly routed civilian aircraft would add one to two minutes of additional flight time for a re-routed aircraft. ... The increase in sonic booms from one per five days under No-Action to two per three days under the Proposed Action or Alternatives A or B would not be expected to affect wildlife or livestock behavior. ... Predicted peak overpressure noise from sonic booms would not be strong enough to cause damage to structures in good condition. ... Sonic booms are not expected to occur at pressure levels that could damage structures, although older windows or objects on shelves could be vibrated or damaged. Change in sonic booms from one per five days to two per three days or any chaff or flare residual materials would not be in amounts that would affect property values or land use. The added risk of flare-induced fire in the affected area, compared to other potential sources of fire, would be very low. Therefore, no effects on socioeconomic resource are expected from the Proposed Action or Alternative A or B. In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 An annual total of 60,770 chaff bundles and 40,286 flares would continue to be authorized throughout the new, modified, and existing airspace. ... About 5 million chaff strands are dispensed in each bundle of chaff. ... These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! ... Under the airspace, 14 percent is lands managed by the Bureau of Land Management (BLM), 16 percent is state land, and 69 percent is private. ... There are seven counties underlying or partially underlying the training airspace. ... Record searches of both the New Mexico State Register of Cultural Properties and the NRHP indicate that there are NRHP-listed properties in one county underlying project MOAs and proposed expansion areas. As Table 3.6-1 indicates, listed properties in De Baca county include the De Baca County Courthouse, which was constructed in 1917; the Fort Sumner Railroad Bridge, which was constructed in 1906; the Rodrick Drug Store; the Fort Sumner Women’s Club; and the Fort Sumner Ruins. ... Towns within the study area range in population from less than 200 to about 1,900 (University of New Mexico [UNM] 2000). The majority (78 percent) of the land under the airspace is privately held. The majority of the public land that would be affected by the Proposed Action is administered by the BLM. ... Approximately 71 percent of all land under the restricted airspace is held in private ownership, 21 percent are state lands, and 8 percent is administered by the Air Force (Air Force 2001e). ... One high-altitude Jet Route, J-74 (J-74), provides direct east-to-west routing between the Texico VORTAC and the Corona VORTAC. Jet routes are established under Federal Aviation Regulation (FAR) Part 71 in Class A airspace to designate frequently used routings. Jet routes extend from FL 180 to FL 450, inclusive. They have no specified width; width varies depending on many aeronautical factors (FAA Order 7400.2 2000). J-74 passes over the Pecos North High MOA, through the northern portion of the Pecos ATCAA, and over the restricted airspace associated with Melrose AFR. Currently, the Pecos ATCAA is capped at FL 300, and does not conflict with civil traffic generally at FL 310 or higher. Commercial traffic routed via direct or using J-74 fluctuates from light to heavy, depending on the time of day. Most traffic involves operations to and from Dallas-Fort Worth, Texas. Peaks normally occur during mid-morning and mid to late afternoon (personal communication, Semanek 2004). The 27 FW seldom requests authorization to use this airspace because it is unavailable for military use even though it is greatly needed for training. The lack of access has “conditioned” the 27 FW to constantly work around this capped airspace, which diminishes the area for realistic training. ... IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. ... Currently, J-74 provides routing between the Texico Very High Frequency Omni-directional Radio Range and Tactical Air Navigation Aid (VORTAC) (east of the New Mexico Training Range Initiative [NMTRI] airspace) and the Corona VORTAC (west of the NMTRI airspace). This route passes through the northern portion of the Pecos ATCAA. Conflicting use of this airspace is resolved by Air Traffic Control (ATC). J-74 would be moved under the Proposed Action. This could be accomplished by establishing a way-point north of the ATCAA, and the route would be divided into two segments. ... Rerouting J-74 and direct traffic to the north encroaches on the utilization of another jet route further to the north. This is the area of J-72 ... ... The average time between aircraft ranges from 2.7 minutes to 20.9 minutes. The peak hour demand, which occurs on Thursday from 11:00 a.m. to noon, would increase peak traffic from 19 flights per hour to 30 flights per hour (see Table 4.1-1). The Air Force believes that scheduling and coordination are required to prevent over-extension of the National Airspace system. ... The Air Force believes the likely number of aircraft requiring air traffic control service from FAA controllers falls within their ability and expertise to deconflict in the area north of the Pecos MOA/ATCAA complex. To fully unencumber active available airspace for military training, IFR traffic transiting this active airspace must file their flight plans to avoid the Pecos airspace complex through the Aeronautical Information System Replacement system. The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? The proposed westward expansion of the Pecos complex would result in the MOA overlying portions of one Federal Airway, V-291. This airway provides routing between the Corona VORTAC and Roswell. The proposed MOA expansion would not totally prohibit use of this airway. ... The proposed southerly expansion of the Pecos South Low MOA, into the area of the previously defined “Roswell Shelf,” would result in lowering MOA airspace in that region from 11,000 feet MSL to 500 feet AGL. ... Expansion of the Pecos MOA complex could interact with traffic on the “Worth-3” SID. ... Depending on which airspace were active for training, rerouting could require flying around the entire Pecos MOA/ATCAA complex. The more likely effect to private pilots would be to schedule a flight at a time other than the hours during the typical two days per month when the Capitan MOA/ATCAA was in use. As is always the case, if an emergency, such as a life-flight were required, the Air Force would immediately shift or end training to accommodate the emergency. ... The increase in sonic booms from supersonic activity would be noticeable and can be intrusive. They will occur on average two times in three days ... Public concerns expressed during scoping include annoyance of people who are startled by booms, possible damage to structures (particularly brittle objects like older windows) and potential adverse effects on domestic and wild animals. ... Sonic booms under the Proposed Action are not expected to damage viable structures, such as foundations, buildings, windmills, radio towers, or water tanks. ... Not all structures are in good condition. Brittle elements such as windows and plaster can weaken with age, and become susceptible to breakage at low boom levels. ... Nonetheless, the presence of susceptible structures, for whatever reason, means that some damage attributable to sonic booms is to be expected. ... Short-term reactions to new noises may include temporary shifts in habitat use or activities. For example, prairie dogs and swift foxes might spend more time in their burrows, where they would be somewhat insulated from noises (Francine et al. 1995). Lesser prairie-chickens are known to cease lekking activities for several minutes to several hours in response to noise disturbances (Giesen and Connelly 1993); therefore, a sudden onset low-level noise event from an aircraft overflight could disturb lekking prairie-chickens. ... Under the Proposed Action, a greater number of sorties would include supersonic flight and supersonic flight would occur at lower altitudes than under existing conditions. Consequently, animals would be exposed to louder noise levels from sonic booms than they are at present. ... Several special-status species are rare in New Mexico, but could be present during spring and fall migration, particularly along the Pecos River (NMDGF 2002a, 2002b). These are brown pelican, piping plover, mountain plover, black tern (Chlidonias niger), interior least tern, peregrine falcon, bald eagle, and Baird’s sparrow. These temporary visitors may not be habituated to aircraft noise. Migrating birds require quality stopover habitat to rest and eat. Noise disturbance, therefore, could cause individual special-status birds and other migratory birds (e.g., ducks and geese) to leave their stopover area prematurely. However, negative impacts to special-status populations would not be expected. ... Wintering bald eagles are sensitive to noise disturbance (Grubb and King 1991) and may be disturbed by aircraft noise However, because of the short duration of a noise event occurring at a particular location on the ground, any resulting physiological or behavioral disturbance would be short-lived. ... Noise from supersonic flight would increase in all parts of the airspace, but at levels that would not be expected to significantly impact biological resources. Resident wild animals and livestock experiencing new noise levels may initially experience negative effects and may temporarily shift habitat use or activities as a result (Harrington and Veitch 1991). ... Under the Proposed Action, the number of supersonic events throughout the airspace would increase relative to current conditions. Supersonic flights at 10,000 feet MSL could increase the frequency and intensity of sonic booms. ... The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? |
On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera
wrote: I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. Look out the window and don't bump into things in front of you. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Corrective action to eliminate those accidents in the future is part of the process. The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
Much as it pains me to agree with a fighter dood, I have to go along with that remark. Dick Former MATS/MAC AC |
On 16 Feb 2005 12:39:23 -0800, "Dick L." wrote
in . com:: Oh, and lest I forget....screw you, Larry. You're clueless. Much as it pains me to agree with a fighter dood, I have to go along with that remark. Dick Former MATS/MAC AC I'll take your agreement with Ed's remark as an admission, that you have no valid argument to present on the subject proposed MOA expansion. |
On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus
wrote in :: On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera wrote: In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The USAF's statement regarding claims procedures for "damage due to Air Force activity" is probably inadequate to replace Ms. Oliveier's late husband. The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at subsonic speed. I believe the expansion of the MOA relates to low-level supersonic military operations within "5,000 to 6,000 feet above ground level (AGL)". These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, Perhaps you'll be good enough to assist me in calculating the number of F-16C non-combat mishaps per month given the USAF's statement, that 120 Class A mishaps have occurred to date (Jan. 2005) since the 1985 Fiscal Year. but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. Be that as it may, I was commenting on the number of F-16C non-combat mishaps per month. The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. I agree, that it tends to confirm the danger involved in flying USAF F-16C's in a non-combat environment. Whether or not additional reserved airspace for low-level supersonic military operations will improved the F-16C's non-combat Class A bimonthly mishap rate is a speculative matter at best. IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Yes. It is the 'law' of VFR operations, however in this case it was suggested as a _viable_ means of transiting the proposed MOA while low-level supersonic military operations are in progress! Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. The NAS is a system. As such, it is dependent on each aspect of its implementation to be functional in order for the whole to function properly. FARs are part of that system. The prohibiting of flight in excess of 250 knots below 10,000 feet is a FAR. The military has exploited the "SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states: The regulation grants an exception to aircraft having flight characteristics which preclude safe operation at speeds below 250 knots by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at that minimum safe airspeed. When the speed of aircraft below 10,000 feet exceeds 250 knots as mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised as evidenced by at least two of the three military/civil mishaps, and corroborated by the military's own study which concluded, that out of each 20 seconds of flight below 250 knots, 17 seconds must be dedicated to scanning for conflicting traffic and 3 seconds remained for scanning cockpit gages; this was for "highly trained" military pilots. So it is evident that see-and-avoid is completely impracticable for maintaining aircraft separation when aircraft are traveling in excess of Mach one. * http://ecfr.gpoaccess.gov/cgi/t/text....2.4.9&idno=14 Look out the window and don't bump into things in front of you. Oh, if it were only so simple. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. Of course, the military has found a way around that speed restriction. (see above) The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. That may be due to the relative number of aircraft and the number of operational hours between the military and civil fleets. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Actually, the same thing occurs for civil mishaps; the NTSB finds and reports probable cause. The specific action taken by the FAA against a civil pilot is a matter of public record. Here's what occurred in the case of the November 16, 2000 fatal MAC in Florida: Air Force officials said the mistakes [sic] Lt. Col. Parker made leading up to the crash over Manatee County deserved only "administrative action" — a written or verbal reprimand. He will also retain his officer's pension. The decision regarding Parker was made by Brig. Gen. John Rosa, commander of Moody Air Force Base in south Georgia, where the F-16 pilots were stationed at the time of the crash. Citing confidentiality laws, Air Force officials would not elaborate on what form of administrative action was taken. They also would not say which of the mistakes he made the day of the crash led to the reprimand, the Sarasota Herald-Tribune reported... -- Associated Press Corrective action to eliminate those accidents in the future is part of the process. Well, at least the USAF tries to give the impression that that occurs: Thursday, June 21, 2001 Associated Press BRADENTON — Military aircraft on low-level training missions in civilian air space should fly at the slowest possible speed, the Air Force says following an F-16 crash that killed a civilian pilot. The Air Force has updated flight manuals and safety procedures on high-speed, low-altitude flights after reviewing the collision of the F-16 Fighting Falcon and a Cessna 172 over Manatee County on Nov. 16, military officials said Tuesday. Pilots on training maneuvers in civilian air space now are required to fly at the slowest possible speed although not less than 250 knots, or 287.5 miles per hour. In an official review of the crash, released in March, the Air Force downplayed the F-16's 480 mph speed as a factor. The pilot was flying 180 mph faster than federal and Air Force guidelines then allowed for military jets in air space near Sarasota-Bradenton International Airport. The updates are written in general terms and refer to slowing the aircraft and reviewing training routes near congested flying areas. The report, overseen and released by Air Force Chief of Staff Gen. Michael Ryan, comes more than seven months after the F-16, flown by Capt. Greg Kreuder, collided with the Cessna, killing its pilot, Jacques Olivier, 57, a [ATP rated] flight instructor from Hernando County. "We can't speculate on whether these recommendations would have affected the outcome of the crash had they already been in place," said Air Force spokeswoman Maj. Cheryl Law. "We always consider safety as our highest priority." ... The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The proposed MOA enlargement is to permit supersonic operations at between 5,000' and 6,000' as stated in the USAF EIS. Why are you referring to 30,000' feet? That is the current, not proposed, altitude floor in the MOA for supersonic operations. The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
On Wed, 16 Feb 2005 22:02:08 GMT, Larry Dighera
wrote: On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus wrote in :: On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera wrote: In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The USAF's statement regarding claims procedures for "damage due to Air Force activity" is probably inadequate to replace Ms. Oliveier's late husband. And, your arguments citing a mishap in Florida relating to a MOA change in New Mexico are inadequate to address the training requirements of combat forces in high performance tactical jet aircraft. I'm deeply sympathetic to Ms Olivier or Oliveier, but I'm also sympathetic to the surviving wives and families of quite literally hundreds of USAF, USN and USMC tactical aviators who died or were imprisoned when lost in military flight operations in the service of their country. The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at subsonic speed. I believe the expansion of the MOA relates to low-level supersonic military operations within "5,000 to 6,000 feet above ground level (AGL)". So, creating a MOA which would advise all aircraft operators of the intended operations would not be as good as operating in non-special use airspace as was being done in the Florida accident? These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, Perhaps you'll be good enough to assist me in calculating the number of F-16C non-combat mishaps per month given the USAF's statement, that 120 Class A mishaps have occurred to date (Jan. 2005) since the 1985 Fiscal Year. My point was that 3.3 MILLION hours per 120 mishaps (which aren't all mid-airs or even aircraft losses and which didn't all occur in special sue airspace) is a statistic that is better viewed as mishaps/100k flight hours rather than mishaps/month. but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. Be that as it may, I was commenting on the number of F-16C non-combat mishaps per month. Which means what relative to training airspace in NM? The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. I agree, that it tends to confirm the danger involved in flying USAF F-16C's in a non-combat environment. In ANY environment. Whether or not additional reserved airspace for low-level supersonic military operations will improved the F-16C's non-combat Class A bimonthly mishap rate is a speculative matter at best. Precisely! The mishap rate and the need for training airspace are not related to each other! IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Yes. It is the 'law' of VFR operations, however in this case it was suggested as a _viable_ means of transiting the proposed MOA while low-level supersonic military operations are in progress! First, note that the tactical applicability of supersonic operations at high or low altitude is very limited. Second, note that most PLANNED supersonic operation is done at high altitude, such as high-speed intercept training. Third, note that UNPLANNED supersonic operation can occur momentarily during air combat maneuver/BFM training and that might be at relatively low altitude (although most tactical training employs a 10k or 5k AGL "floor"). Fourth, note that most training in which supersonic operations are planned or highly likely will be conducted in restricted airspace rather than MOA. Fifth, note that transiting of MOAs by VFR traffic while allowed is discourage; by IFR traffic is not allowed when the MOA is in use. Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. The NAS is a system. As such, it is dependent on each aspect of its implementation to be functional in order for the whole to function properly. FARs are part of that system. The prohibiting of flight in excess of 250 knots below 10,000 feet is a FAR. The military has exploited the "SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states: The regulation grants an exception to aircraft having flight characteristics which preclude safe operation at speeds below 250 knots by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at that minimum safe airspeed. When the speed of aircraft below 10,000 feet exceeds 250 knots as mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised as evidenced by at least two of the three military/civil mishaps, and corroborated by the military's own study which concluded, that out of each 20 seconds of flight below 250 knots, 17 seconds must be dedicated to scanning for conflicting traffic and 3 seconds remained for scanning cockpit gages; this was for "highly trained" military pilots. So it is evident that see-and-avoid is completely impracticable for maintaining aircraft separation when aircraft are traveling in excess of Mach one. You confirm my asssertion of cluelessness. Some military aircraft don't function very well at 250 KIAS unless in landing configuration. They burn fuel at high rates and are restricted in their agility. For that reason the FARs have waivered the 250 max exactly for the reason you quote "minimum SAFE airspseed". Let's take this to an example you are probably more familiar with: driving your car. How much time when driving do you spend looking out the window versus staring at your speedometer? Ditto for airplanes. Look out the window and don't bump into things in front of you. Oh, if it were only so simple. Don't knock it if you haven't tried it. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. Of course, the military has found a way around that speed restriction. (see above) And, you can take it to the bank that they will continue to do so. Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. Did you read previous posts? Walker AFB, Roswell NM. Williams AFB, Chandler AZ. Webb AFB, Big Spring TX. Wendover AFB, Wendover UT. Wurtsmith AFB....and those are just W's--all closed within the last 30 years, all with airspace which was no longer needed. That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. That may be due to the relative number of aircraft and the number of operational hours between the military and civil fleets. And, it may even be due to private pilots being clueless about where they are. Or maybe they are talking on their cell phones. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Actually, the same thing occurs for civil mishaps; the NTSB finds and reports probable cause. The specific action taken by the FAA against a civil pilot is a matter of public record. Here's what occurred in the case of the November 16, 2000 fatal MAC in Florida: Air Force officials said the mistakes [sic] Lt. Col. Parker made leading up to the crash over Manatee County deserved only "administrative action" — a written or verbal reprimand. He will also retain his officer's pension. The decision regarding Parker was made by Brig. Gen. John Rosa, commander of Moody Air Force Base in south Georgia, where the F-16 pilots were stationed at the time of the crash. Citing confidentiality laws, Air Force officials would not elaborate on what form of administrative action was taken. They also would not say which of the mistakes he made the day of the crash led to the reprimand, the Sarasota Herald-Tribune reported... -- Associated Press If you read the accident report you would find a clear detailing of the "mistakes" and you would learn whether they were primary, secondary or lesser causes. As for the "administrative action" it could range from corrective training to removal from flight status to loss of pay to mandatory retirement. But, the mere fact that he didn't have his sword broken, his buttons cut off and his epaulets removed before hanging in the public square MIGHT mean he wasn't guilty of anything significant! The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. Injustice? Going through a public hearing process before designating special use airspace is now "injustice"? And, reread my sentence above: "unwillingness to acknowledge any of the alternatives to your pronouncements"--that's not "alternative 'prounouncement'". Posters have given you blocks of information regarding special use airspace refuting your basic position opposing expansion of the MOA. You continue to throw stuff at the wall hoping that some sticks, regardless of relevance. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The proposed MOA enlargement is to permit supersonic operations at between 5,000' and 6,000' as stated in the USAF EIS. Why are you referring to 30,000' feet? That is the current, not proposed, altitude floor in the MOA for supersonic operations. I'm referring to 30,000 feet BECAUSE YOU REFERRED TO 30,000 FEET!!!!! That's YOUR quote above mine. Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Excuse me? I've got more time in the Beak MOA inverted than you've apparently got in military jets. And, if you've missed my presentation of "reasonable arguments" you can't read. Oh, and "screw you" isn't profaning you, it's exercising restraint despite the frustration at your apparent inability to make any sense of all of this. If you want profaning of "a fellow airman", I suggest you scan recent posts from Dudley--he's proven a master at it. But, I can stoop if need be. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
On Wed, 16 Feb 2005 16:28:37 -0700, Ed Rasimus
wrote in :: On Wed, 16 Feb 2005 22:02:08 GMT, Larry Dighera wrote: On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus wrote in :: On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera wrote: In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The USAF's statement regarding claims procedures for "damage due to Air Force activity" is probably inadequate to replace Ms. Oliveier's late husband. And, your arguments citing a mishap in Florida relating to a MOA change in New Mexico are inadequate to address the training requirements of combat forces in high performance tactical jet aircraft. My argument was with the USAF's statement _in_ the proposed MOA Environmental Impact Statement (EIS) about claims procedures for "damage due to Air Force activity." If the USAF hadn't raised the issue in conjunction with their proposal to increase the size of the MOA, I wouldn't have referred to their failure to criminally prosecute Parker for the death of Oliveier. I'm deeply sympathetic to Ms Olivier or Oliveier, The USAF wasn't when they heard that she was going to sue them. An Air Force spokesman was reported to have said, that they'd seek compensation for the F-16 that killed her husband due to Lead Parker's deliberate decision to descend into congested terminal airspace without the required ATC clearance. but I'm also sympathetic to the surviving wives and families of quite literally hundreds of USAF, USN and USMC tactical aviators who died or were imprisoned when lost in military flight operations in the service of their country. How is that relevant to the current discussion of MOA expansion? The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at subsonic speed. I believe the expansion of the MOA relates to low-level supersonic military operations within "5,000 to 6,000 feet above ground level (AGL)". So, creating a MOA which would advise all aircraft operators of the intended operations would not be as good as operating in non-special use airspace as was being done in the Florida accident? From that statement, it seems you might be a bit confused about the proposed MOA enlargement as well as the Florida mishap. The USAF proposes not to establish a MOA, but to increase the size of the one currently in existence, so that they can conduct supersonic operations within 5,000' to 6,000' of the surface instead of at 30,000' as is currently occurring. Please read the USAF EIS, so that you'll at least know what we are discussing. Here's a link to it: www.cannon.af.mil These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, Perhaps you'll be good enough to assist me in calculating the number of F-16C non-combat mishaps per month given the USAF's statement, that 120 Class A mishaps have occurred to date (Jan. 2005) since the 1985 Fiscal Year. My point was that 3.3 MILLION hours per 120 mishaps (which aren't all mid-airs or even aircraft losses and which didn't all occur in special sue airspace) is a statistic that is better viewed as mishaps/100k flight hours rather than mishaps/month. So, you agree with my math now? but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. Be that as it may, I was commenting on the number of F-16C non-combat mishaps per month. Which means what relative to training airspace in NM? Not much. But a non-combat Class A mishap every two months continuing for a period of 20 years is significant in its own right, in my opinion. [...] IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Yes. It is the 'law' of VFR operations, however in this case it was suggested as a _viable_ means of transiting the proposed MOA while low-level supersonic military operations are in progress! First, note that the tactical applicability of supersonic operations at high or low altitude is very limited. Second, note that most PLANNED supersonic operation is done at high altitude, such as high-speed intercept training. Third, note that UNPLANNED supersonic operation can occur momentarily during air combat maneuver/BFM training and that might be at relatively low altitude (although most tactical training employs a 10k or 5k AGL "floor"). Fourth, note that most training in which supersonic operations are planned or highly likely will be conducted in restricted airspace rather than MOA. Fifth, note that transiting of MOAs by VFR traffic while allowed is discourage; by IFR traffic is not allowed when the MOA is in use. Those statements reveal the fact that you haven't read the USAF EIS statement proposing the increase in size of the MOA. The reason the USAF is seeking to increase the size of the MOA is so that they can conduct supersonic operations within 5,000' to 6,000' of the surface instead of at 30,000' as is currently occurring. Please read the USAF EIS, so that you'll at least know what we are discussing. Here's a link to it: www.cannon.af.mil Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. The NAS is a system. As such, it is dependent on each aspect of its implementation to be functional in order for the whole to function properly. FARs are part of that system. The prohibiting of flight in excess of 250 knots below 10,000 feet is a FAR. The military has exploited the "SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states: The regulation grants an exception to aircraft having flight characteristics which preclude safe operation at speeds below 250 knots by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at that minimum safe airspeed. When the speed of aircraft below 10,000 feet exceeds 250 knots as mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised as evidenced by at least two of the three military/civil mishaps, and corroborated by the military's own study which concluded, that out of each 20 seconds of flight below 250 knots, 17 seconds must be dedicated to scanning for conflicting traffic and 3 seconds remained for scanning cockpit gages; this was for "highly trained" military pilots. So it is evident that see-and-avoid is completely impracticable for maintaining aircraft separation when aircraft are traveling in excess of Mach one. You confirm my asssertion of cluelessness. Some military aircraft don't function very well at 250 KIAS unless in landing configuration. They burn fuel at high rates and are restricted in their agility. For that reason the FARs have waivered the 250 max exactly for the reason you quote "minimum SAFE airspseed". I didn't say there was no reason for the DOD exemption from the 250 knot maximum speed below 10,000' feet. I said it brakes the NAS, and is unsafe. There is not enough time to see-and-avoid at speeds in excess of 250 knots. You're saying military aircraft need to go faster than 250 knots below 10,000'; who am I to dispute that. I'm saying regardless of that need, it creates a flight hazard to civil aviation when it occurs outside of Restricted airspace (such as MTRs and MOAs). Let's take this to an example you are probably more familiar with: driving your car. How much time when driving do you spend looking out the window versus staring at your speedometer? Ditto for airplanes. How much time does a military pilot spend with his head down in the cockpit studying charts, tuning radios, setting up navigation equipment and not scanning for conflicting traffic? If it's more than three seconds out of every 20, he's causing a safety hazard by virtue of a military research study. If you have the flight experience you claim, you know I'm correct. Look out the window and don't bump into things in front of you. Oh, if it were only so simple. Don't knock it if you haven't tried it. I've tried it. Trust me, it's not that easy to spot an aircraft ATC has pointed out that is only a mile or two distant. Now, at supersonic speeds of ~11.5 miles a minute, it would only take 5 seconds for a 2 mile distant supersonic aircraft to reach you! You have to agree, that's not a reasonable amount of time to see-and-avoid. [...] Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. Did you read previous posts? Walker AFB, Roswell NM. Williams AFB, Chandler AZ. Webb AFB, Big Spring TX. Wendover AFB, Wendover UT. Wurtsmith AFB....and those are just W's--all closed within the last 30 years, all with airspace which was no longer needed. No, I did not read the articles that mentioned those closures. Does it require the closure of an airbase to get the military to relinquish its SUA? Aren't there situations where they no longer train in the same way, and can relinquish it without closing the a base? That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. That may be due to the relative number of aircraft and the number of operational hours between the military and civil fleets. And, it may even be due to private pilots being clueless about where they are. Or maybe they are talking on their cell phones. There are more civil aircraft flying more hours. That's the reason. Your attempt to make light of the grim realities of MACs, reveals your less than sincere and cavalier attitude. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Actually, the same thing occurs for civil mishaps; the NTSB finds and reports probable cause. The specific action taken by the FAA against a civil pilot is a matter of public record. Here's what occurred in the case of the November 16, 2000 fatal MAC in Florida: Air Force officials said the mistakes [sic] Lt. Col. Parker made leading up to the crash over Manatee County deserved only "administrative action" — a written or verbal reprimand. He will also retain his officer's pension. The decision regarding Parker was made by Brig. Gen. John Rosa, commander of Moody Air Force Base in south Georgia, where the F-16 pilots were stationed at the time of the crash. Citing confidentiality laws, Air Force officials would not elaborate on what form of administrative action was taken. They also would not say which of the mistakes he made the day of the crash led to the reprimand, the Sarasota Herald-Tribune reported... -- Associated Press If you read the accident report you would find a clear detailing of the "mistakes" and you would learn whether they were primary, secondary or lesser causes. I have read both the military AIB and the NTSB reports. (I'd be happy to provide copies via e-mail to anyone interested.) It's clear that flight lead Parker deliberately chose to descend into congested terminal airspace at high speed without the required ATC clearance, and lead his wingman into the fatal collision. As for the "administrative action" it could range from corrective training to removal from flight status to loss of pay to mandatory retirement. It was reported to be a verbal reprimand. So while the accident report was made public, the details of the "punishment" Parker received were confidential, unlike those in FAA certificate actions. The military does not disclose as much information as the FAA. But, the mere fact that he didn't have his sword broken, his buttons cut off and his epaulets removed before hanging in the public square MIGHT mean he wasn't guilty of anything significant! His deliberate decision to descend into congested terminal airspace at high-speed without the required ATC clearance resulted in the death of an innocent civilian, a fellow American. I consider that not only significant, but worthy of criminal action. The USAF allowed Parker to retire as planned with full pension and rank; that is not just. The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. Injustice? Going through a public hearing process before designating special use airspace is now "injustice"? At that point, I was referring to the lack of criminal prosecution in the fatal November 16, 2000 Florida MAC, not the military airspace grab. And, reread my sentence above: "unwillingness to acknowledge any of the alternatives to your pronouncements"--that's not "alternative 'prounouncement'". How is it different? Posters have given you blocks of information regarding special use airspace refuting your basic position opposing expansion of the MOA. You continue to throw stuff at the wall hoping that some sticks, regardless of relevance. Perhaps, but at least I read the USAF EIS, and am aware that the airspace they are seeking is to enable them to train at supersonic speed within 5,000' to 6,000' of the surface, unlike you. [...] Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Excuse me? I've got more time in the Beak MOA inverted than you've apparently got in military jets. How is that revenant to the USAF's attempted airspace grab? And, if you've missed my presentation of "reasonable arguments" you can't read. That's me, illiterate. :-) Oh, and "screw you" isn't profaning you, You obviously don't know the meaning of the word: Main Entry:1 profane Pronunciation ![]() Function:transitive verb Inflected Form ![]() Etymology:Middle English prophanen, from Latin profanare, from profanus Date:14th century 1 : to treat (something sacred) with abuse, irreverence, or contempt : DESECRATE 2 : to debase by a wrong, unworthy, or vulgar use –profaner noun it's exercising restraint despite the frustration at your apparent inability to make any sense of all of this. The record is clear; you haven't read the USAF EIS and weren't aware they want to enlarge the MOA to permit low-level supersonic operations north of Roswell, NM. You may not like my lack of objectivity and overt criticism of the military, but it is you who apparently has no clue about this airspace grab. If you want profaning of "a fellow airman", I suggest you scan recent posts from Dudley--he's proven a master at it. But, I can stoop if need be. You not only can stoop, you have publicly. I hope you're indiscretion isn't typical of most military airmen. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
On Thu, 17 Feb 2005 02:02:28 GMT, Larry Dighera
wrote: On Wed, 16 Feb 2005 16:28:37 -0700, Ed Rasimus wrote in :: And, your arguments citing a mishap in Florida relating to a MOA change in New Mexico are inadequate to address the training requirements of combat forces in high performance tactical jet aircraft. My argument was with the USAF's statement _in_ the proposed MOA Environmental Impact Statement (EIS) about claims procedures for "damage due to Air Force activity." If the USAF hadn't raised the issue in conjunction with their proposal to increase the size of the MOA, I wouldn't have referred to their failure to criminally prosecute Parker for the death of Oliveier. What part of "accident" is so difficult to understand. For what crime would you prosecute the flight lead? Murder? Did he premeditate? What crime? I'm deeply sympathetic to Ms Olivier or Oliveier, The USAF wasn't when they heard that she was going to sue them. An Air Force spokesman was reported to have said, that they'd seek compensation for the F-16 that killed her husband due to Lead Parker's deliberate decision to descend into congested terminal airspace without the required ATC clearance. We live in a litigious society. Folks threaten to sue when the spill hot coffee in their laps and to avoid the costs of the litigation, the prospective defendant will often reach a settlement. No criminal charges were brought, because no prosecuter with an ounce of judgement would be able to define a "crime" and no civil action was brought, because Ms Olivier really couldn't prove that a flight lead decision was in any way malicious toward her husband. So, creating a MOA which would advise all aircraft operators of the intended operations would not be as good as operating in non-special use airspace as was being done in the Florida accident? From that statement, it seems you might be a bit confused about the proposed MOA enlargement as well as the Florida mishap. The USAF proposes not to establish a MOA, but to increase the size of the one currently in existence, so that they can conduct supersonic operations within 5,000' to 6,000' of the surface instead of at 30,000' as is currently occurring. Please read the USAF EIS, so that you'll at least know what we are discussing. Here's a link to it: www.cannon.af.mil I read it and I know what we are discussing. We are talking about a proposal to increase available training airspace for Cannon AFB and to change the limits of permissible operations. That is considerably different than a descent in non-special use airspace a continent away. My point was that 3.3 MILLION hours per 120 mishaps (which aren't all mid-airs or even aircraft losses and which didn't all occur in special sue airspace) is a statistic that is better viewed as mishaps/100k flight hours rather than mishaps/month. So, you agree with my math now? I'm suggesting that extrapolating 20 years experience into a "mishap/month" stat is misleading. The rate is not constant over the period. And, the rate for mishaps is measured traditionally as mishaps per 100k flying hours, not as a function of calendar months. Not much. But a non-combat Class A mishap every two months continuing for a period of 20 years is significant in its own right, in my opinion. That's the error--the mishaps don't occur at a constant rate through the period and the assumption that they do is erroneous. The extension of mishaps to equate with loss of aircraft, association with special use airspace, supersonic operation and mid-air collisions are all further errors related to the statistic. First, note that the tactical applicability of supersonic operations at high or low altitude is very limited. Second, note that most PLANNED supersonic operation is done at high altitude, such as high-speed intercept training. Third, note that UNPLANNED supersonic operation can occur momentarily during air combat maneuver/BFM training and that might be at relatively low altitude (although most tactical training employs a 10k or 5k AGL "floor"). Fourth, note that most training in which supersonic operations are planned or highly likely will be conducted in restricted airspace rather than MOA. Fifth, note that transiting of MOAs by VFR traffic while allowed is discourage; by IFR traffic is not allowed when the MOA is in use. Those statements reveal the fact that you haven't read the USAF EIS statement proposing the increase in size of the MOA. The reason the USAF is seeking to increase the size of the MOA is so that they can conduct supersonic operations within 5,000' to 6,000' of the surface instead of at 30,000' as is currently occurring. Please read the USAF EIS, so that you'll at least know what we are discussing. Here's a link to it: www.cannon.af.mil You're redundant and beginning to carp. My list of five factors is to point out that simply because an airspace is AUTHORIZED for supersonic operation does not mean that is what is going on within. Being AUTHORIZED simply means that if tactically necessary, you can exceed the mach without filling out reams of paperwork and having an investigation or potential violation. Most operations are subsonic--there is little tactical appliacation for supersonic flight. It can and does occur, usually inadvertently, during engagement. Get it? You don't use supersonic AUTHORIZED airspace to go blasting back and forth with your hair on fire. You confirm my asssertion of cluelessness. Some military aircraft don't function very well at 250 KIAS unless in landing configuration. They burn fuel at high rates and are restricted in their agility. For that reason the FARs have waivered the 250 max exactly for the reason you quote "minimum SAFE airspseed". I didn't say there was no reason for the DOD exemption from the 250 knot maximum speed below 10,000' feet. I said it brakes the NAS, and is unsafe. There is not enough time to see-and-avoid at speeds in excess of 250 knots. You're saying military aircraft need to go faster than 250 knots below 10,000'; who am I to dispute that. I'm saying regardless of that need, it creates a flight hazard to civil aviation when it occurs outside of Restricted airspace (such as MTRs and MOAs). Excuse me? If my airplane is drastically hampered in its ability to safely maneuver by going slower than 250 KIAS below 10k feet MSL, then it "creates a flight hazard" to me, my flight members, other aircraft and folks on the ground. How much time does a military pilot spend with his head down in the cockpit studying charts, tuning radios, setting up navigation equipment and not scanning for conflicting traffic? If it's more than three seconds out of every 20, he's causing a safety hazard by virtue of a military research study. If you have the flight experience you claim, you know I'm correct. Lessee a channel change every fifteen minutes takes about four second. Charts? If VFR, I'm navigating by pilotage--i.e. looking at landmarks out the window. If IFR, I'm head-down (or actually looking at the HUD which is looking out the window) anyway if in the clouds, or navigating by pilotage if in VMC. And, "setting up nav equipment" is once again something that isn't done continually and in many systems is done pre-flight through cartridge programming which then updates. And, I have the flight experience I claim. Look out the window and don't bump into things in front of you. Oh, if it were only so simple. Don't knock it if you haven't tried it. I've tried it. Trust me, it's not that easy to spot an aircraft ATC has pointed out that is only a mile or two distant. Now, at supersonic speeds of ~11.5 miles a minute, it would only take 5 seconds for a 2 mile distant supersonic aircraft to reach you! You have to agree, that's not a reasonable amount of time to see-and-avoid. Then you need to get your eyes checked. As stated repeatedly, there is little utility to supersonic operation and very little reason to have other than very momentary excursions into the supersonic regime at low altitude. Even so, the shift in visual acquistion range between what you see at 500 kts and what you see at 660 kts is insignificant. As for your acquistion ranges, I've regularly seen F-5 sized targets at 10-15 miles, tanker sized targets at 20 miles and light civil airplanes at 10 miles--particularly if cued by a radar return, ATC advisory or other input. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. Did you read previous posts? Walker AFB, Roswell NM. Williams AFB, Chandler AZ. Webb AFB, Big Spring TX. Wendover AFB, Wendover UT. Wurtsmith AFB....and those are just W's--all closed within the last 30 years, all with airspace which was no longer needed. No, I did not read the articles that mentioned those closures. Google BRAC. Are you unaware that in the last thirty years the military has been significantly reduced? Does it require the closure of an airbase to get the military to relinquish its SUA? Aren't there situations where they no longer train in the same way, and can relinquish it without closing the a base? Yes there are. There are also changes of mission. If you go back in history to the '50s and '60s you will find a special use airspace category called MCC (Military Climb Corridor) at the end of virtually every runway of every major airport in the US. This was used for departure of Cold War jet interceptors on scramble departure. They are no longer used and you won't find them anywhere. There are more civil aircraft flying more hours. That's the reason. So, for civil aircraft mishaps, the rate per 100k flying hours might be a good statistic? Not mishaps per month? I have read both the military AIB and the NTSB reports. (I'd be happy to provide copies via e-mail to anyone interested.) It's clear that flight lead Parker deliberately chose to descend into congested terminal airspace at high speed without the required ATC clearance, and lead his wingman into the fatal collision. That's called "flight lead discretion". It's one of literally hundreds of decisions a flight lead is required to make in each and every flight. It was reported to be a verbal reprimand. So while the accident report was made public, the details of the "punishment" Parker received were confidential, unlike those in FAA certificate actions. The military does not disclose as much information as the FAA. What part of "verbal reprimand" is so difficult to understand. For "details" do you require a transcript of the counseling session? His deliberate decision to descend into congested terminal airspace at high-speed without the required ATC clearance resulted in the death of an innocent civilian, a fellow American. I consider that not only significant, but worthy of criminal action. The USAF allowed Parker to retire as planned with full pension and rank; that is not just. Again we come to the terminology of "accident" and "crime". Yes, someone died. No, there was no criminal intent and while there might have been an arguably poor decision, it wasn't actionable after a detailed investigation. The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. And, reread my sentence above: "unwillingness to acknowledge any of the alternatives to your pronouncements"--that's not "alternative 'prounouncement'". How is it different? I didn't say you made an "alternative pronouncement". I said you haven't acknowledged that numerous posters have provided alternative information which conflicts with the pronouncements you made. Perhaps, but at least I read the USAF EIS, and am aware that the airspace they are seeking is to enable them to train at supersonic speed within 5,000' to 6,000' of the surface, unlike you. That's three times redundant. And, see above for the discussion. Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Excuse me? I've got more time in the Beak MOA inverted than you've apparently got in military jets. How is that revenant to the USAF's attempted airspace grab? It is relevant to my experience in the airspace in question (have you read the EIS to see the prominent mentions of Beak MOA and Capitan MOA?) It is further relevant to your claim to be a "fellow airman"--can you tell me what you've flown and where that gives you this status of peer? 1 : to treat (something sacred) with abuse, irreverence, or contempt : DESECRATE 2 : to debase by a wrong, unworthy, or vulgar use –profaner noun If I said you were an asshole, that would be vulgar. If I said **** you that would be vulgar as well. And, since I don't consider you as "something sacred", I can't very well be irreverant. The record is clear; you haven't read the USAF EIS and weren't aware they want to enlarge the MOA to permit low-level supersonic operations north of Roswell, NM. You may not like my lack of objectivity and overt criticism of the military, but it is you who apparently has no clue about this airspace grab. That's four and still redundant. But, if you've got little to say, saying it often will serve equally as well. I've been refuting your major issue of "airpace grab" with regard to a very small extension of the MOAs used by both Cannon and Holloman AFBs and the applicability of the supersonic authorization. (And you might want to get out a map to check that both Beak and Capitan are W. of Roswell.) If you want profaning of "a fellow airman", I suggest you scan recent posts from Dudley--he's proven a master at it. But, I can stoop if need be. You not only can stoop, you have publicly. I hope you're indiscretion isn't typical of most military airmen. You'll have to familiarize yourself with a lot more military airmen to make the decision on whether or not I'm typical. But, I'd advise you to do it online and at a distance. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
On Thu, 17 Feb 2005 08:50:44 -0700, Ed Rasimus
wrote in :: On Thu, 17 Feb 2005 02:02:28 GMT, Larry Dighera wrote: On Wed, 16 Feb 2005 16:28:37 -0700, Ed Rasimus wrote in :: And, your arguments citing a mishap in Florida relating to a MOA change in New Mexico are inadequate to address the training requirements of combat forces in high performance tactical jet aircraft. My argument was with the USAF's statement _in_ the proposed MOA Environmental Impact Statement (EIS) about claims procedures for "damage due to Air Force activity." If the USAF hadn't raised the issue in conjunction with their proposal to increase the size of the MOA, I wouldn't have referred to their failure to criminally prosecute Parker for the death of Oliveier. What part of "accident" is so difficult to understand. When a pilot deliberately descends into congested terminal airspace with the required ATC clearance, it's not an accident; it's reckless endangerment of all the aircraft operating legally within the terminal airspace. If you disagree, please explain how Parker could have _accidentally_ descended into the Class B and C airspace, perform a G Check, and search for the MTR? For what crime would you prosecute the flight lead? Murder? Florida law defines third-degree murder as the killing of a person without intent or premeditation, a terminology that in other states would closely match the interpretation of manslaughter crimes. Did he premeditate? Actually, Parker's preparation for the fatal sortie was flawed. Here's an excerpt from the USAF Accident Investigation Board report: (1) Most of the mission planning was accomplished the evening prior to the mishap. Based on fuel considerations, the pilots determined that VR-1098 would be the best low-level route for their mission. Lieutenant Colonel Parker tasked Captain Kreuder to produce a low-level route map and schedule the route with the appropriate scheduling agency. Neither pilot had flown VR-1098 before. As part of his mission planning, Lieutenant Colonel Parker referred to a FLIP L-19 Instrument Flight Rules (IFR) Enroute Low Altitude Chart and determined that their planned route of flight would keep them clear of the Tampa Class B and the Sarasota-Bradenton Class C airspace (hereafter referred to as Sarasota Class C airspace). Lieutenant Colonel Parker also planned the simulated attack for the Avon Park targets and prepared the briefing room for the next day’s mission. The next morning, Captain Kreuder reviewed the weather and NOTAMs prior to the flight briefing and filed a composite IFR/VFR/IFR flight plan in accordance with unit procedures. He also checked the Bird Avoidance Model (BAM) for forecast bird activity in the Florida area. (2) The mission briefing included a mission overview, scenario of simulated threats for the mission, routing to the low-level entry point, and possible divert airfields along the route of flight. Additionally, the flight lead covered wingman responsibilities and formation positions. The pilots discussed the specific details of VR-1098, the planned attacks on Avon Park, and tactical considerations during the simulated. I'll set this part below out so you won't miss it: -------------------------------------------------------------------- Lieutenant Colonel Parker did not specifically brief Class B and Class C airspace restrictions in the Tampa area during the flight briefing. Air Force directives require the flight lead to brief applicable airspace restrictions. -------------------------------------------------------------------- Although Lieutenant Colonel Parker checked to make sure their planned route to the low-level would not enter these areas, they would be flying in close proximity to them. This information would have enhanced the wingman’s awareness of the boundaries of these controlled airspaces and their accompanying altitude restrictions. All other appropriate items were covered in adequate detail in accordance with Air Force directives. According to Captain Kreuder, the briefing was thorough and understood by him. Parker's failure to brief airspace restrictions as required by Air Force directives, casts doubt on his ability to adequately premeditate at all in the mental state he was in at the time. Here's a question for you experienced AF pilots: Given the fact, that the top of Tampa Class B is 10,000' in all sectors, and the entry point for VR1098 is located only one NM south of the Tampa Class B southern boundary, and Parker's Ninja flight was southbound above Tampa Class B, how did he plan to enter low level VR1098 Military Training Route without entering Tampa Class B airspace? Was he planning on descending nearly 10,000' in less than a mile? What crime? Third-degree murder. What would the FAA and Florida authorities have called it if Parker had been a civilian GA pilot and caused the death of another pilot, because he violated FAA regulations? I'm deeply sympathetic to Ms Olivier or Oliveier, The USAF wasn't when they heard that she was going to sue them. An Air Force spokesman was reported to have said, that they'd seek compensation for the F-16 that killed her husband due to Lead Parker's deliberate decision to descend into congested terminal airspace without the required ATC clearance. We live in a litigious society. Folks threaten to sue when the spill hot coffee in their laps and to avoid the costs of the litigation, the prospective defendant will often reach a settlement. That doesn't excuse the USAF spokesman's callous comment. No criminal charges were brought, because no prosecuter with an ounce of judgement would be able to define a "crime" We disagree about that. and no civil action was brought, because Ms Olivier really couldn't prove that a flight lead decision was in any way malicious toward her husband. All she (or the DA) would have had to prove was negligence, which should have been easy. I'm not sure if she ever filed a suit, but here's what the newspaper had to say: http://www.sptimes.com/News/120100/n...t_faults.shtml Widow of pilot faults Air Force and FAA By ALEX LEARY and BILL VARIAN © St. Petersburg Times, published December 1, 2000 CRYSTAL RIVER -- The wife of a Cessna pilot killed in a collision with an F-16 fighter plane over Manatee County earlier this month has filed wrongful death claims against the Air Force and the Federal Aviation Administration. The claims allege "illegal airspeed and altitude" of the F-16 and a failure of FAA air traffic controllers to prevent the Nov. 16 crash. Danielle Olivier, 50, of Citrus County, is seeking up to $10-million in the death of her husband, 57-year-old Jacques Olivier. ... Kreuder said he never saw the Cessna, only a blur, "like a sheet of white." He ejected and was not injured. Radar data indicates the military planes were traveling faster than 480 mph before one of them struck the Cessna 172 piloted by Jacques Olivier. Planes below 10,000 feet are limited to flying no faster than 300 mph unless they are in a special military area, which the F-16s were not. ... "Air traffic controllers employed by the Federal Aviation Administration negligently failed to maintain separation between the two aircraft," Danielle Olivier's claim states. "These guys were going too fast, they were too low and they weren't communicating," Coker said in an interview Thursday. "There is no question it shouldn't have occurred," Coker added. "It really is an unfortunate tragedy." ... Submitting the Standard Form 95, as the claim Olivier filed is known, is a precursor to filing a lawsuit, said Michael Pangia, former head trial lawyer for the FAA who now works in private legal practice specializing in aviation matters in Washington. Two things generally happen after a claim is filed: It can be denied, or the agency in question can simply sit on it, Pangia said. If it is denied, the person filing the claim then has six months to file a lawsuit to seek damages. If the agency does not respond, the person may take up to six years from the incident that resulted in the claim to file suit, as if the claim were denied. The agency may also decide a claim has merit, in which case it typically would seek more information to justify damages. ... First, note that the tactical applicability of supersonic operations at high or low altitude is very limited. Second, note that most PLANNED supersonic operation is done at high altitude, such as high-speed intercept training. Third, note that UNPLANNED supersonic operation can occur momentarily during air combat maneuver/BFM training and that might be at relatively low altitude (although most tactical training employs a 10k or 5k AGL "floor"). Fourth, note that most training in which supersonic operations are planned or highly likely will be conducted in restricted airspace rather than MOA. Fifth, note that transiting of MOAs by VFR traffic while allowed is discourage; by IFR traffic is not allowed when the MOA is in use. Those statements reveal the fact that you haven't read the USAF EIS statement proposing the increase in size of the MOA. The reason the USAF is seeking to increase the size of the MOA is so that they can conduct supersonic operations within 5,000' to 6,000' of the surface instead of at 30,000' as is currently occurring. Please read the USAF EIS, so that you'll at least know what we are discussing. Here's a link to it: www.cannon.af.mil You're redundant and beginning to carp. Because you repeatedly failed to understand what was stated in the Air Force EIS, I thought it necessary to get it through your head. My list of five factors is to point out that simply because an airspace is AUTHORIZED for supersonic operation does not mean that is what is going on within. Being AUTHORIZED simply means that if tactically necessary, you can exceed the mach without filling out reams of paperwork and having an investigation or potential violation. Most operations are subsonic--there is little tactical appliacation for supersonic flight. It can and does occur, usually inadvertently, during engagement. Get it? You don't use supersonic AUTHORIZED airspace to go blasting back and forth with your hair on fire. What you state is not relevant to the planned MOA expansion. If you had read the Air Force EIS, you'd have noted that one of the four elements of the proposed MOA expansion is: ... flying at supersonic speeds above 10,000 feet above mean sea level (MSL) or approximately 5,000 to 6,000 feet above ground level (AGL) in the airspace ... And the Air Force EIS further states: The increase in sonic booms from one per five days under No-Action to two per three days under the Proposed Action or Alternatives A or B would not be expected to affect wildlife or livestock behavior. So it is apparent that the Air Force deliberately intends (not inadvertently) to conduct two supersonic operations per every three days within the proposed expanded MOA despite your contention to the contrary. You confirm my asssertion of cluelessness. Some military aircraft don't function very well at 250 KIAS unless in landing configuration. They burn fuel at high rates and are restricted in their agility. For that reason the FARs have waivered the 250 max exactly for the reason you quote "minimum SAFE airspseed". I didn't say there was no reason for the DOD exemption from the 250 knot maximum speed below 10,000' feet. I said it brakes the NAS, and is unsafe. There is not enough time to see-and-avoid at speeds in excess of 250 knots. You're saying military aircraft need to go faster than 250 knots below 10,000'; who am I to dispute that. I'm saying regardless of that need, it creates a flight hazard to civil aviation when it occurs outside of Restricted airspace (such as MTRs and MOAs). Excuse me? If my airplane is drastically hampered in its ability to safely maneuver by going slower than 250 KIAS below 10k feet MSL, then it "creates a flight hazard" to me, my flight members, other aircraft and folks on the ground. I'm sorry you failed to understand my meaning. Let me try again. If the NAS was designed for a maximum speed of 250 knots below 10,000', and you operate at a speed in excess of that, the NAS will not function as designed; such excessive speed reduces the time available for see-and-avoid separation to the point that it is absurd, and thus causes a safety hazard. Apparently the FAA has chosen to grant the military exemption based on need rather than safety. [...] Then you need to get your eyes checked. Unlike you, I currently hold a valid Medical Certificate. As stated repeatedly, there is little utility to supersonic operation and very little reason to have other than very momentary excursions into the supersonic regime at low altitude. Yes, you have stated that repeatedly, however that "information" is in direct opposition to the USAF's stated use for the MOA if its enlargement is granted. Even so, the shift in visual acquistion range between what you see at 500 kts and what you see at 660 kts is insignificant. How significant is the visual acquisition range difference between 250 knots and 660 knots? As for your acquistion ranges, I've regularly seen F-5 sized targets at 10-15 miles, tanker sized targets at 20 miles and light civil airplanes at 10 miles--particularly if cued by a radar return, ATC advisory or other input. As a percentage of total attempts, what would be your estimate of the number of times you have been unable to visually acquire F-5 sized targets in 3 mile visibility VFR operations? [...] I have read both the military AIB and the NTSB reports. (I'd be happy to provide copies via e-mail to anyone interested.) It's clear that flight lead Parker deliberately chose to descend into congested terminal airspace at high speed without the required ATC clearance, and lead his wingman into the fatal collision. That's called "flight lead discretion". It's one of literally hundreds of decisions a flight lead is required to make in each and every flight. Are you attempting to imply that the USAF condones the noncompliance with its directives? Even the chief AIB investigator admitted the Ninja flight lead had made mistakes: The chief Air Force investigator said at a news conference Tuesday that two F-16 pilots from Moody Air Force Base in Valdosta, Ga., were not where they were supposed to be, were flying too fast and were out of radio contact with air-traffic controllers when one of them collided with a Cessna 172 that had just taken off from Sarasota bound for Citrus County. Parker was leading a _training_ mission. He had no compelling _need_ to go rocketing through congested terminal airspace and jeopardize the safety of all the airline passengers therein as well as those people on the ground. There is little question, that it was reckless for him to deliberately chose to descend into congested terminal airspace at high speed without the required ATC clearance. [...] His deliberate decision to descend into congested terminal airspace at high-speed without the required ATC clearance resulted in the death of an innocent civilian, a fellow American. I consider that not only significant, but worthy of criminal action. The USAF allowed Parker to retire as planned with full pension and rank; that is not just. Again we come to the terminology of "accident" and "crime". Yes, someone died. No, there was no criminal intent and while there might have been an arguably poor decision, If you have no intent of killing a motorist, but do so as a result of violating traffic laws while driving, do you think you will not be criminally prosecuted? Get real. it wasn't actionable after a detailed investigation. Perhaps your conclusion is accurate. Or perhaps the military has influence over the DA in such matters. Or perhaps the DA doesn't have jurisdiction over military personnel. Neither of us knows why Parker wasn't criminally prosecuted, but it doesn't seem just to me. If a civilian pilot had done what Parker did, you can bet he'd be in jail now. [...] |
![]() "Ed Rasimus" wrote in message ... What part of "accident" is so difficult to understand. For what crime would you prosecute the flight lead? Murder? Did he premeditate? What crime? The flight lead clearly did not intend for anyone to be killed, but his unlawful actions did result in the death of another human being. Sounds like manslaughter to me. We live in a litigious society. Folks threaten to sue when the spill hot coffee in their laps and to avoid the costs of the litigation, the prospective defendant will often reach a settlement. No criminal charges were brought, because no prosecuter with an ounce of judgement would be able to define a "crime" and no civil action was brought, because Ms Olivier really couldn't prove that a flight lead decision was in any way malicious toward her husband. Does malice have to be shown? Wouldn't malice make it murder and not manslaughter? |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 06:12 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
