Archer Cowl needs work - Advice?
Old February 17th 05, 02:32 PM
Stealth Pilot
On Thu, 17 Feb 2005 08:16:21 -0500, Corky Scott
On Wed, 16 Feb 2005 13:19:39 -0600, "James M. Knox"
Stealth Pilot wrote in
m:
to get a smooth outer layer I used a paste of resin and johnsons baby
powder (talc) and squeegee'd this on to fill the weave but not much
more than that.
Run that one by me one more time? I haven't heard of this trick.
Most people use something like microballoons mixed with the resin to
create a sandable finish.
Corky Scott
thats it.
I just checked the ingredients to the baby powder.
talc, fragrance.
sometimes I just do it for the fragrance :-)
smells great while sanding it back.
Stealth Pilot
Old February 17th 05, 04:31 PM
George Patterson
talc, fragrance.
Wear a dust mask. They took talc out of sheet rock compound because of health
concerns over people breathing the dust.
George Patterson
He who tries to carry a cat by the tail learns something he can learn in
no other way.
Old February 17th 05, 04:45 PM
Ron Natalie
They still put talc in drywall. What they are careful now about is making
sure it's not contaminated with asbestos (much mined talc contains it).
NIOSH recommends a mask anyhow. Just about any of the silicate's dust
is bad to breath in quantity.
Old February 17th 05, 05:32 PM
George Patterson
Gene Kearns wrote:
I thought drywall was principally gypsum and quartz.....
Drywall is gypsum plaster between two layers of thick paper. The
taping/finishing compound is something else. Just read the label on the USG
stuff I use. Limestone, water, talc (Ron's right, as usual), mica, and vinyl
acetate polymer.
The reason I thought the talc had been removed is that in the mid-80s the cans
used to have a warning label that the compound contained talc. The label
disappeared in the 90s, so I thought the talc was gone too.
George Patterson
no other way.
Old February 18th 05, 01:40 AM
Morgans
USG
vinyl
acetate polymer.
It is primarily gypsum, with very small percentages of the other stuff.
Jim in NC
Old February 18th 05, 03:47 PM
George Patterson
USG
vinyl
acetate polymer.
Then it's interesting that gypsum does not appear in the ingredients list.
George Patterson
no other way.
Old February 18th 05, 09:11 PM
Morgans
George Patterson
That *is*interesting, since I have been to a plant where the stuff is mined,
separated from the rock, and baked, mixed and formed into the sheetrock. I
have no explanation.
Jim in NC
Old February 19th 05, 12:21 AM
UltraJohn
list.
George Patterson
mined,
I have no explanation.
Isn't gypsum = to limestone, water and talc ?
John
Old February 19th 05, 01:58 AM
George Patterson
George Patterson
You *do* realize that we are talking about joint compound, not sheet rock?
George Patterson
no other way.
Old February 19th 05, 06:26 AM
Morgans
George Patterson
Uhh, no. *That* could be the explanation! Somewhere I missed that.
Jim in NC
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
