A new direction for an old thread: Crosswind landings
Old February 20th 05, 10:03 PM
I would counter that the only way to maintain a track is by crabbing. I
think we confuse the role of the slip. In order to track straight down
the runway in a crosswind, we must adjust the direction of the glider
so the sin of the angle equals the crosswind component. This is
accomplished by turning, our yaw string ultimatley revealing our path
through the air. If you recover from your side slip, you will point at
that angle while continuing to track down the runway. Side slip,
recover, side slip, recover. The side slip has nothing to do with your
direction... it simply changes your heading so you can land with the
wheels straight.
And thus my quibble with calling crabs and side slips additive.
The advantage of using a side slip for alignment is that it reduces
variables: once the slip is established, the pilot uses the controls as
normal (or very nearly so).
My intent here is not to discern which approach is better... to me they
are pretty much the same... with preference for when the alignment
correction is made... early on final or just before touchdown. Instead,
I want to point out that there are some published, formal notions that
appear at least to cause confusion and at worst are simply WRONG.
Someone come to the defense of the sages of sport, the authors of the
Soaring Flight Manual!! How are a crab and side slip additive?
Old February 22nd 05, 06:15 AM
I don't agree that they aren't additive.
Say you are side slipping, but are still drifting off centerline. So
you turn into the wind (crab) and hold the same amount of slip. It
seems to me that you are combining, i.e. "adding", the crab component
to the slip component. Works with vector arithmetic, should work in the
air, too.
Tom
Tailwheel Crosswind Landing Piloting 32 December 6th 04 02:42 AM
Thermal right, land left John Soaring 195 April 1st 04 11:43 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
Dr. Jack's Wind Direction rjciii Soaring 14 October 5th 03 05:37 AM
