Home aerial for an ICOM AC-A5?
Old December 10th 04, 04:13 PM
jls
Default Home aerial for an ICOM AC-A5?
"Avery Wagg" wrote in message
Hi folks,
I will often use my handheld ICOM IC-A5 transceiver as an ordinary
aviation
band scanner at home. However, the the small aerial on the unit doesn't do
too much food whilst I sit in the basement. I'd like to build an outside
aerial for it that is more effective.
Does anyone have any tips on making up a home aeraial for an IC-A5 that I
could implement. I do have an old TV aerial out back (with a 75 ohm cable
attached).
..Avery Wagg
Give Jim Weir time to reply; I believe he sells a kit for an outside
aerial.
Old December 10th 04, 06:06 PM
john smith
That and he has instructions for building one on his website.
aerial.
Old December 10th 04, 09:22 PM
Blueskies
"Jerry J. Wass" wrote in message ...
aerial.
That copper tube "J" Pole works nice, Be on lookout for 58 ohm co-ax
cable. Not The TV stuff. it's 75 ohm.
I think that is 50 ohm coax...
Old December 10th 04, 10:17 PM
Jerry J. Wass
aerial.
Old December 10th 04, 10:27 PM
GeorgeB
On Fri, 10 Dec 2004 14:17:27 -0800, "Jerry J. Wass"
aerial.
You may be thinking of RG58 ... thin 50 ohm coax.
J-pole antennas are very good, but not the best for aviation ,,, they
are fairly narrow band, and just the comm portion is around 15% wide
.... likely better off with somehting with better wideband
characteristics. A cheap vertical whip cut for band center would do
fine. Consider usinb larger caox, RG8 or similar, not for power
handling, but for loss. Find a local ham and have him help you come
up with a matching bridge and use low loss twin lead ...
Old December 11th 04, 05:00 PM
Jerry J. Wass
You're ALMOST RIGHT !! I'm quite a bit WRONG-- the handbooks give the
characteristic impedance of RG8/U, RG58/U, as 53 ohms- common usage has
gone to 50 ohms ---probably because this "looks" right --a ratio of 2 to
3..--??
aerial.
Old December 12th 04, 02:11 AM
Slip'er
characteristics.
I'll make some assumptions here. Since he says that he is using it for a
home base station, I suspect that he will most likely be listening to one
frequency most of the time. In this scenario, a J-pole is very good. He
can build it himself and tune if optimized for his frequency. RG-58 is the
type of coax you want to use. Also, buy or borrow a SWR bridge to optimize
the antenna.
If you don't want to use copper tubing, people also make tuned J-pole
antennas from twin lead antenna wire. I am making one to throw into my
survival gear bag tuned for 121.5.
A whip is good for walking around. Optimize length for your intended
frequency and mark so you know how far to extend it. If any section becomes
loose, replace the whip.
Slip'er
Old December 12th 04, 07:58 AM
Roger
aerial.
Purchase an SO-239 chassis connector. Get one that has 4 small screw
holes (one in each corner. I've forgotten the length of a quarter
wave on 122.8, (I'd have to look it up some where around here)
Cut a piece of thin brass brazing rod, or brass, or copper to a
quarter wave length. Solder that into the chassis side of the SO239
connector. This is the radiator/antenna. Cut 4 more pieces of the
brass (or what ever) rod about 10% longer than the radiator. Solder
one end of each into one of the corner holes. Bend these out at about
45 degrees so the thing can stand on them. You now have a good
antenna. It will stand on a flat roof, or straddle the peak. Use a
bit of Silastic RTV (TM) to hold the feet to the roof.
I used to use one of these at work with over a 100 feet of RG-58 and
it worked fine.
Don't worry about loss in the RG-58 unless you have a run of a 100
feet or more. The height of the antenna will more than make up for
the loss and you are using a receiver that is probably far more
sensitive than the average aviation receiver.
You can go to RG-8X which is slightly larger than RG-58, but a lot
smaller than standard RG-8 and more flexible.
Put a PL259 (male connector) on the end of the coax that goes to the
antenna. Put what ever is required for the end that goes to the
radio. I use PL-259s on each end with an adapter to fit the radio.
Hook up each end and you are in business.
I'm using a co-linear 144/440 MHz dual band antenna that isn't even
cut for the aviation frequencies and it works very well. The base is
at 25 feet and at the far end of about 120 feet of LMR-400 (RG-8
equivalent, but better) The reason for the large coax in this case is
the amount of power I run on those two bands.
I have another co-linear at 50 feet on the main tower with 144 and 440
beams at 130 feet (at the end of 228 feet of LMR-400. They also hear
ATC and aircraft just fine even though the signals are well outside
the range of the antennas.
www.rogerhalstead.com
Old December 12th 04, 05:36 PM
RST Engineering
Just be aware that the PL259/SO239 series of connectors is not waterproof,
not even water resistant. Don't use them where rain and such can
contaminate the coax.
Old December 12th 04, 10:39 PM
john smith
Makes a good lightning rod, too!
(Be sure to ground it with a separate grounding wire to earth ground.)
Best Home Base Work Reynard Home Built 0 November 9th 04 04:37 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Home Built 0 January 23rd 04 02:43 AM
