![]() "Roy Smith" wrote in message ... The distance shown on the profile view from the FAF (JONNY) to the MAP should be changed from 4.9 NM to 4.57 (bottom-right of the plate). They leave it to you to work out new timings. At 90 kts, it's a change from 3:16 to 3:03. There's no information as to *WHY* they moved the MAP, but if you're still using the old timing, you're going to drive 15 seconds past the MAP before starting your missed. They moved the MAP because they moved the runway threshold, runway 2/20 has been lengthened. The plate still shows the length as 6503 feet but AirNav shows it to be 8012 feet. I have to wonder why that isn't included in the NOTAM. These changes are "WIth Effect Until Further Notice.". That's probably the reason Jepp decided to issue a new chart. My guess is that the S-ILS minimums will come back some day, perhaps after some transmitter or antenna is repaired, and/or some flight testing can be done. But there's no date scheduled. I'd expect the S-ILS minima will be back after the glideslope is moved a quarter mile north. |
ATTN: Anyone from the Marion Club | Slick | Soaring | 0 | November 30th 04 12:21 PM |
What Col Killian really said :) | Cub Driver | Military Aviation | 38 | September 26th 04 05:30 PM |
