IFR GPS certification
Old February 24th 05, 05:45 PM
nobody
Default IFR GPS certification
I guess I've been living under a rock. I wanted to update the VFR GPS in
the panel to an IFR model. I started getting quotes on recon GNC 300XLs.
The units themselves were about 2,500-3,000. I was shocked to find out that
I had to install an annunciator, a new indicator and approx 30 hrs labor
bringing the total cost to around 8,000. I checked several shops and got
the same story. Is it typical to spend 25% of the value of the aircraft on
just the IFR GPS? If I installed a 530, the receiver and install would
probably cost close to 80% of the value of the aircraft.
Eddie
Old February 24th 05, 06:05 PM
Dave Butler
Your absolute expense dollars sound about right. The percentage of the value of
the aircraft will, of course, depend on the value of the aircraft.
IMO, and as other have also pointed out here, the additional capability over and
above a non-certified moving map is not that great, either, unless you
frequently fly to a runway that's served only by a GPS approach. Most of the
benefit of certified GPS can be had without the certification.
Old February 25th 05, 06:14 AM
nobody
"...the additional capability over and above a non-certified moving map is
not that great..."
That's just it. Without certification, you can't file /G, and you can't use
GPS as the primary navigation instrument. In my case, I can't legally use
the speed/dist functions for the DME portion of the approach either. I'm in
the same place with a much cheaper (portable) VFR GPS.
Ed
"Dave Butler" wrote in message
news:1109264569.720642@sj-nntpcache-5...
that I had to install an annunciator, a new indicator and approx 30 hrs
labor bringing the total cost to around 8,000. I checked several shops
and got the same story. Is it typical to spend 25% of the value of the
aircraft on just the IFR GPS? If I installed a 530, the receiver and
install would probably cost close to 80% of the value of the aircraft.
value of the aircraft will, of course, depend on the value of the
aircraft.
over and above a non-certified moving map is not that great, either,
unless you frequently fly to a runway that's served only by a GPS
approach. Most of the benefit of certified GPS can be had without the
certification.
Old March 15th 05, 12:43 AM
M
I made the same decision against getting a IFR GPS and statyed with /U
on my plane. I did get a Garmin 196 and it works fabulously along with
my onboard VOR on IFR flights. I made this choice because nearly all
the airports that I fly IFR into have ILS.
Old March 15th 05, 01:14 AM
Doug Carter
Nothing wrong with this but more and more airports are getting GPS
approaches for the opposite and crossing directions to the ILS runways.
So if the wind doesn't work for the ILS runway you can make a straight
in approach instead the more dangerous circle to land from the ILS
option; lower minimums to boot.
Old March 15th 05, 03:16 PM
Dave Butler
I haven't done a survey, but my impression is that the average straight in GPS
approach has higher minimums than the average ILS circling approach. I agree I'd
rather land straight in if possible, though.
DGB
Old March 16th 05, 12:19 AM
M
Interestingly enough, it seems that on the days when the ceiling/vis is
low enough to make circling approach difficult are also likely to be
the days when the wind is either very light or lined up with the ILS
straight-in direction.
runways.
straight
Old February 24th 05, 07:26 PM
Marco Leon
Your numbers seem right. IMHO, the Garmin 430 is the better value. At an
approximately $9,300 install price, you get an ILS and save space on the
annunciators (they are included within the unit itself). You will also see a
better addition to the aircraft's resale value compared to a GNC300XL but
don't expect a $9,300 increase. Oh, and you will be able to get a terrain
database for an extra $500 available in a few months.
All that being said, it will only make fiscal sense if you plan on keeping
the plane a while.
Marco Leon
N36616
"nobody" wrote in message
om...
that
on
Eddie
Old February 25th 05, 01:32 PM
Thomas Borchert
Nobody,
If you did that, I don't think you'd need an external annunciator.
There are some GPS units that don't. Aviation Consumer has done several
stories on when an upgrade makes financial sense and what kind of
upgrade does. Their archive (for a fee/subscription) is online at
www.aviationconsumer.com
Thomas Borchert (EDDH)
Old March 1st 05, 10:15 PM
Robert M. Gary
That's why people buy Garmin 430s. They are the only GPS units to my
knowledge that have everything built it. You can find them pretty
inexpensive on ebay from those upgrading to 480s or 530s. Installation
will knock your socks off in any case.
-Robert
Adding IFR Plane Certification To Planes Without It Blanche Cohen Owning 10 November 29th 04 07:37 PM
Aircraft certification questions. psyshrike Home Built 40 November 22nd 04 07:10 PM
Aircraft certification questions. psyshrike Owning 42 November 22nd 04 07:10 PM
certification of composite aircraft sebastian Home Built 6 March 25th 04 04:48 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
