Martin, you are entirely wrong. I'm not obsessed. Really. No, I mean
it. ;-) I use slips as a matter of course because I understand their USE and RISKS and I am competent. What I am obsessed with is finding the language that will let me explain clearly, succinctly, that crabbing and slipping are not means to the same end. Perhaps I should refocus attention on the word crabbing... which give the impression that it is a maneuver as opposed to being normal wings level flight. Maybe the better way to discuss this is to talk about approaches being coordinated or uncoordinated. We all agree that in order to transition to the ground in a crosswind situation, we must move from coordinated to uncoordinated flight. You have a choice when to apply controls to establish uncoordinated flight. You can do it just before touch down (in which case the turn that accompanies a skid is manageable), or you may do it earlier on final. What I want to knock down is this notion of either a crab or a slip as it infects our understanding of the purpose of the slip. In order to establish a new ground track, you must turn. A side slip is not a turn. All forces are balanced. As I've already described, many pilots are confused about this difference. They explain that the side slip works because the tilted left vector points into the crosswind, dragging the glider sideways and compensating for wind drift. This works in practice, but is wrong in fact because the tilted lift vector is exactly matched by fuselage drag. If there were an unbalance force, the glider's direction would continue to change... that is, circle. The point is to find a better way of saying this. The place I'm trying to get to is that when we compensate for crosswind on final, what we are really doing when we initiate the side slip is a turn... what is in the first instant a coordinated turn (remember which way the nose goes if we don't use coordinating rudder while we roll into the bank), which becomes a slipped turn as we reverse the progressively rudder against the turn to keep heading aligned with runway, until we reach a beta where the wing turning force is exactly compensated by the fuselage force. A better way to teach this and practice it is to keep the turn coordinated until the desired ground track is achieved. This demonstrates clearly the only way to establish a new ground track... by turning to what we typcially call a crabbed approach. Then, at the pilot's option, he may enter a slip, which will align the gliders heading with its ground track. This crearly demonstrates that the slip's only purpuse is alignment, just as the only purpose for the rudder kick before touchdown is alignment (the only purpose of which is to reduce side loading on the gear). The advantage of the slip is that, unlike the rudder kick, all foreces are balanced. If the touch down is delayed, you are much less likely to have to make large corrections in direction. In your experience, how many pilots stick with this sport. I've heard commercial operators say it's about 1 in 5. Twenty percent get it. Eighty percent don't. And of the 20% that get, how many really get it? I already know how to do it. Now I'm trying to "get it" in a way that I can easily explain, and maybe help that other 80% figure things out. Martin Eiler wrote: The following is a snip from one of Fiveniner's early posts regarding the use of side slips for dealing with wind drift while on final. At 00:00 20 February 2005, wrote: But the notion that the tilted lift vector is compensating for wind drift is flawed. Useful, but flawed. Having read all of his posts in this thread, it is apparent that he has supplied no real data capable of substantiating his position that side slips cannot compensate for wind drift. Yes, there is a portion of the soaring community that are die-hard crab pilots. That does not mean that their choice automatically validates his opinion that side slips can't compensate for cross wind. Those pilots who are experienced with side slips seem to agree with the SSA's Soaring Manual, in that a side slip does have some limitations, and consequently at some point, some amount of crab may be needed to be added to the side slip to achieve the desired result. Interestingly, after rereading his other posts, it becomes quite obvious that he is obsessed with the opinion that pilots should only be allowed to fly coordinated while at or below pattern altitude. Although he is entitled to his opinion, few other pilots would support the concept that a pilot who intentionally flies uncoordinated on final is operating dangerously. Generally speaking having lofty ideals is admirable, however it is more warmly accepted when an individual signs his post with his real name. M Eiler |
.... that the slip's only purpuse is alignment, just as the only purpose
for the rudder kick before touchdown is alignment (the only purpose of which is to reduce side loading on the gear). The advantage of the slip is that, unlike the rudder kick, all foreces are balanced. ... etcetera ... etcetera it is not that complex. or that subtle approaching it with the "it is hard to understand" attitude maybe one reason why the pilots at your club go all "eyes glaze over" when you offer to run through the 'subtleties of the slip/crab interaction at point of flight/landing interface' with them 'just one more time'. p.s. why not discuss ground erffect again - I *love* that one. - what I know about ground effect from things pilots have told me: * the vortex at the tips gets cut in half so the drag is reduced * list improved relative to the 'thicker' air squashed under the wings hello & love to all who rig and then de-rig without flying jonny. Jonny. Jonny ;-) |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Thermal right, land left | John | Soaring | 195 | April 1st 04 11:43 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) | Matt Wiser | Military Aviation | 0 | December 7th 03 08:20 PM |
Dr. Jack's Wind Direction | rjciii | Soaring | 14 | October 5th 03 05:37 AM |
