Night flying in the mountians in a cessna 150,
Old February 26th 05, 05:22 PM
Ron Garret
"Peter Duniho" wrote:
Of course your odds of having an engine failure with two engines is
double of what it would be with one, and quadruple with four.
Only approximately. The only reason doubling (or quadrupling) the number of
engines doubles (or quadruples) the chance of an engine failure
(approximately) is that the failure rate is so low. For example, if the
failure rate were 50%, a doubling of that would cause you to expect an
engine to fail each flight (a 100% chance of failure), when in fact the
chance is actually only 75%.
It is somewhat ironic that you should be the one to point this out in
light of the argument we are having in another branch of this thread
because this is precisely the point I was making. The condition of the
probability of failure on a single trial P being low is precisely the
condition that allows you to approximate the formula for cumulative
failure 1-(1-P)^N as P*N. If you think about it, there is absolutely no
difference in the risk calculation between making one flight with four
engines and four flights with one engine (except insofar as the
probability of failure for one engine over four flights are not quite
independent of each other if it's the same engine each time).
rg
Old February 27th 05, 02:06 AM
Peter Duniho
"Ron Garret" wrote in message
[...] If you think about it, there is absolutely no
The difference is that when you make a flight with four engines, you know up
front that you're carrying four engines. The calculation based on making
four flights with one engine is only useful when you know in advance you're
making four flights.
I certainly hope to make at least four more flights during my flying career,
but it's not certain that I will.
Sorry you can't see the difference. It's a crucial element to the question
of whether it makes sense to worry about the cumulative odds of an engine
failure.
Pete
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Night Flying Tips BoDEAN Piloting 7 May 4th 04 03:22 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Products 1 November 4th 03 12:57 AM
Headlight for night flying Paul Tomblin Piloting 22 September 27th 03 09:32 AM
