Useless airplane. With full fuel, which is what, about 28 gallons; you
have a payload of less than 150 pounds. wrote: Looking for an interesting Taildragger without Horton stol kit. Bill Oparowski |
Newps wrote:
Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. 26 gallons. Full fuel gives you much more than 150 lbs. Empty weights of around 1000 and a gross of 1500 gives you two FAA standard people and full fuel. |
Ron Natalie wrote:
Newps wrote: Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. 26 gallons. Full fuel gives you much more than 150 lbs. Empty weights of around 1000 and a gross of 1500 gives you two FAA standard people and full fuel. I'm still waiting to meet an FAA standard person over about 35. -- Jim Pennino Remove -spam-sux to reply. |
If the FAA says I weigh 170lbs, who am I to argue.
wrote in message ... Ron Natalie wrote: Newps wrote: Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. 26 gallons. Full fuel gives you much more than 150 lbs. Empty weights of around 1000 and a gross of 1500 gives you two FAA standard people and full fuel. I'm still waiting to meet an FAA standard person over about 35. -- Jim Pennino Remove -spam-sux to reply. |
![]() Ron Natalie wrote: Newps wrote: Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. 26 gallons. Full fuel gives you much more than 150 lbs. Empty weights of around 1000 and a gross of 1500 gives you two FAA standard people and full fuel. Gross on the 150 is 1600 pounds, but empty weight is 1060 with the O-200. Add some radios and an Imron paint job, and we're over 1100. Stick an O-320 in it and you've just added about 100 pounds to the empty weight. George Patterson I prefer Heaven for climate but Hell for company. |
![]() Ron Natalie wrote: Newps wrote: Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. 26 gallons. Full fuel gives you much more than 150 lbs. Empty weights of around 1000 and a gross of 1500 gives you two FAA standard people and full fuel. Not in the 150/150. That could be a great plane but desperately needs a gross weight increase. |
![]() Newps wrote: Useless airplane. With full fuel, which is what, about 28 gallons; you have a payload of less than 150 pounds. Should be more like 250 pounds. George Patterson I prefer Heaven for climate but Hell for company. |
Taildragger tail dragging? | ShawnD2112 | Piloting | 27 | January 20th 05 02:42 PM |
Things Wanted Cheap | MRQB | Restoration | 0 | March 18th 04 11:01 PM |
Things Wanted Cheap | MRQB | Aviation Marketplace | 0 | March 17th 04 08:46 AM |
WANTED: Lycoming IO-320 | Matt S. | Aviation Marketplace | 0 | September 22nd 03 05:11 PM |
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
