Fueling from plastic gasoline containors
Old February 27th 05, 02:33 PM
Michael Horowitz wrote:
I may have an opportunity to move to a hanger at a private strip; no
facilities, so I'll have to tote in my own gasoline in 2 1/2 gal
plastic containors.
When refueling, do I only need to worry about grounding the a/c?
How would static be generated? - Mike
REPLY:
Mike;
Just moving the plastic can around will develop a static charge on the
can. When you get the nozzle close to the metal of the plane , a
static spark jumps across the gap.. If this is at the tank - there goes
the fire !!!!
I use a plastic can -BUT- I have a little chain wired to the filler
neck of the can with an alligator clip on the loose end. I then ground
the can to a tie down ring BEFORE I open the tank and fill it.
Bob Olds RV-4
Charleston,Arkansas
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) J.R. Sinclair Aviation Marketplace 0 August 16th 04 05:59 AM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
