![]() wrote in message ups.com... Michael Horowitz wrote: I may have an opportunity to move to a hanger at a private strip; no facilities, so I'll have to tote in my own gasoline in 2 1/2 gal plastic containors. When refueling, do I only need to worry about grounding the a/c? How would static be generated? - Mike ************************************************** ********************* REPLY: Mike; Just moving the plastic can around will develop a static charge on the can. When you get the nozzle close to the metal of the plane , a static spark jumps across the gap.. If this is at the tank - there goes the fire !!!! I use a plastic can -BUT- I have a little chain wired to the filler neck of the can with an alligator clip on the loose end. I then ground the can to a tie down ring BEFORE I open the tank and fill it. Bob Olds RV-4 Charleston,Arkansas ************************************************** ********************* Excellent advice. Plus, keeping a halon fire extinguisher handy is good too. Which reminds me. Unlicensed owner of a newly rebuilt Cessna with overhauled engine started it for the first time at midnight, apparently to fly it away from a large public airport where rampchecks occur to a private field. It spit back through the Marvel carb and caught fire. He was alone without a fire extinguisher and the plane burnt almost to a crisp before the fire department arrived. Moral of the story: rugged independence and shooting from the hip can get you into trouble. |
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) | J.R. Sinclair | Aviation Marketplace | 0 | August 16th 04 05:59 AM |
The answer to the gasoline problem | Veeduber | Home Built | 4 | May 22nd 04 08:58 PM |
FAR Reference - Self Fueling | Ben Smith | Owning | 8 | April 8th 04 11:07 PM |
$3.00 a gallon gasoline by summer(read all of this, it just might work) | Fastglasair | Home Built | 8 | March 10th 04 12:12 AM |
Repairing Plastic | Jay Honeck | Owning | 5 | February 2nd 04 09:20 PM |
