In rec.aviation.owning Homesick Angel wrote:
: The bigger engine will drink more fuel, so it will cut down on the : amount of hours you can fly. Can't remember the exact numbers but : probably run out in about two hours. I don't normally buy this argument. With very few exceptions (planes that are horribly underpowered to begin with), more HP doesn't buy you appreciably more speed. Power required goes with the cube of the speed, so normally powered planes aren't much slower than souped-up ones. Just because you have more power, doesn't mean you need to use it. (and in most cases it's silly to do so). If you pull the power back on a bigger engine, it'll burn roughly the same amount of fuel as on a smaller engine. There are only a few things to counter this... - reduced efficiency running at really low power settings on a fixed pitch prop (CS running oversquared would help a lot) - Added weight of the larger engine (generally not too much anyway) : I usually fly conservatively, so I'd fly at say 50% power instead of : 75%. It was so much fun taking off and landing that about all I did ... So they should burn almost the same fuel... It's the same 75HP whether its 75% of 100 or 50% of 150... roughly 5.5gph. Of course climb/hauling is the real (and legitimate) reason to do it. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Dear Cory,
Any idea How do I get my 182 to cruise along at 5.5 GPH? (without burning something up cause it's leaned out too much? or falling out of the sky) It's a 1957 and real light for it's size and got a STOL kit. Getting hard to afford gas for it, but don't want to give in to my husband and get one of those old-fashioned taildraggers. He's rebuilding a Champ right now his 75 HP versus my 230 HP. When I have a Cub I want to fly fast and I fly the 182 like a Cub, poke along nice and slow. Guess growing up in the muscle car era brainwashes you. I figure in a few years I might have to change to sport pilot, but for now I'll keep the Beast from the East and pray for gas prices to go down so I can afford a trip to maybe Alaska or the Seaplane fly-in in Greenville and make it in a day or two instead of a week of two in a tail dragger (I have still trouble flying a straight course, wind, neat stuff to side track to, sightseeing and not pin point navigating). Still prefer the compass and map to my GPS. Just way behind the times I guess. Well take care. Good luck in your educational endeavors. Never could get into the book learning thing unless it was something I was interested in and back in the 1970s girls weren't engineers, pilots, mechanics, architects, etc which all interested me a lot. So I had to settle for second and third choices for a while until I just started to do what I wanted to do, working in a lumber mill running saws and planers, detailing and auto body work, manning remote firetowers in the woods of Maine, going out west to fight fires. Now stuff like that is fun. Right now its mostly farming and keeping our grass strip mowed (some times the goats are allowed out to graze and as the price of gas goes up the amount of time the goats will have possession of the runway will be directly proportion to any price increases). Until I get one of those electric robotic mowers and program it to do the job with less pollution and noise. Guess I need the plans for one of those if somebody's got them? Hope everybody's enjoying flying. I thought I was a math-head but some of you people are way out there. Just don't let that stuff distract you so much that you fly into something or fall out of the sky. Watch out for all the cell phone towers and other towers out there. Be safe and God bless. The Homesick Angel, Carol |
: Dear Cory, : Any idea How do I get my 182 to cruise along at 5.5 GPH? (without : burning something up cause it's leaned out too much? or falling out of : the sky) It's a 1957 and real light for it's size and got a STOL kit. : Getting hard to afford gas for it, but don't want to give in to my : husband and get one of those old-fashioned taildraggers. A 182's pretty heavy, but it'll probably stay aloft on 5.5 gph. Bottom line is: absolute best fuel economy is flying at best rate (since that's where induced+parasitic drag is minimized). That's usually too slow for most, and will be cooking the cylinders due to low airflow and high angle of attack, but strictly speaking, it's best fuel economy. Usually, (since the drag curve is pretty flat around best rate), you can increase the speed a fair bit above that without hitting the parasitic drag wall. For instance... I run my PA-28-180 at 65% in cruise, leaned to peak EGT, and run 120mph IAS at 8-8.5gph. For bopping around the local area (in no particular hurry), about 45% power leaned until it wheezes will give me 100mph IAS at about 5.5-6gph. CHT's stay at 375 or below... life is good. It also might be worth taking a look at some lean-of-peak information. Bottom line: below max cruise power, it's impossible to damage your engine with the red knob alone. Deakin (on avweb) is a big evangelist on this... if you run lower power, lean it 'till it wheezes and you won't hurt anything. Now, if CHT's get too hot doing this, it's enother matter. If you wheeze it at too high of power, you'll melt it quickly. Keep those things in check, and it's clean engine, clean plugs, good fuel economy, and acceptable speed... might not be the fastest, but it's it all about the flying anyway? ![]() -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() : Any idea How do I get my 182 to cruise along at 5.5 GPH? (without : burning something up cause it's leaned out too much? or falling out of : the sky) It's a 1957 and real light for it's size and got a STOL kit. : Getting hard to afford gas for it, but don't want to give in to my : husband and get one of those old-fashioned taildraggers. Don't know what altitude you're talking about but at 7500 and 20 squared you are looking at 9 gph. At 15 inches and 2000 you will get about 6.5 gph. At this point the nose will be pretty high and you will only be getting about 95-100 MPH IAS. To get to 5.5 gph wouldn't be any fun at all. If you have to have 5.5 then sell the plane and get something that can reasonably do that. It also might be worth taking a look at some lean-of-peak information. Bottom line: below max cruise power, it's impossible to damage your engine with the red knob alone. On the big bore Continentals you need to be below 65% before you try that. Plus having a carbed engine makes LOP impractical. |
![]() "Newps" wrote in message ... On the big bore Continentals you need to be below 65% before you try that. No. You don't. Karl Gami Serial# 19 |
In rec.aviation.owning Newps wrote:
: Don't know what altitude you're talking about but at 7500 and 20 squared : you are looking at 9 gph. At 15 inches and 2000 you will get about 6.5 : gph. At this point the nose will be pretty high and you will only be : getting about 95-100 MPH IAS. To get to 5.5 gph wouldn't be any fun at : all. If you have to have 5.5 then sell the plane and get something that : can reasonably do that. He didn't ask how to make it fun... just if it was possible to fly a 182 at 5.5 gph. I answered that it most likely was. Truth be told, if you're after pure fuel economy, you'd want to run oversquared as much as possible, too. : On the big bore Continentals you need to be below 65% before you try : that. Plus having a carbed engine makes LOP impractical. LOP on a carb'd engine is difficult/unlikely. Running at peak (as long as your CHT's aren't high) is fine as well... as long as your power is low. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran
fully leaned & with full carb heat when he was in his max range mode. Do you know of any reason not to, assuming a low power setting? It would improve the mixture distribution, something the O-470s are notoriously poor at. It would also reduce the inlet air density, allowing things to operate with less pumping loss. nrp |
In rec.aviation.owning nrp wrote:
: Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran : fully leaned & with full carb heat when he was in his max range mode. : Do you know of any reason not to, assuming a low power setting? It : would improve the mixture distribution, something the O-470s are : notoriously poor at. It would also reduce the inlet air density, : allowing things to operate with less pumping loss. Unless the CHT's get too high in that configuration (causing poor valve cooling and cylinder badness), there's not much that says it's bad except: - No filtration of the air with carb heat. Shouldn't be a big deal in cruise (unless you have a *really* dirty cowling). - If flying in cold enough weather, you could get carb ice when normally ice crystals would flow through unmelted. (I generally don't like to use carb heat until I know it's necessary) - Sudden power requirement will cause the engine to falter... get used to a quick red knob, then throttle. The real disadvantage of the arrangement on my fixed-pitch plane is 65% is only obtainable at that mixture up to about 7000-8000'. "Best power" of 50 ROP will get you 75% or so at that altitude. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() nrp wrote: Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran fully leaned & with full carb heat when he was in his max range mode. Do you know of any reason not to, assuming a low power setting? It would improve the mixture distribution, something the O-470s are notoriously poor at. It would also reduce the inlet air density, allowing things to operate with less pumping loss. On the 470's, in cruise, you give it whatever carb heat gets you a carb temp of 40-45F. Running at full carb heat makes no sense whatsoever. |
: Max Conrad (ferried Pipers all over the world in the 40s and 50s) ran : fully leaned & with full carb heat when he was in his max range mode. : Do you know of any reason not to, assuming a low power setting? It : would improve the mixture distribution, something the O-470s are : notoriously poor at. It would also reduce the inlet air density, : allowing things to operate with less pumping loss. I find that I can run my Cherokee's O-360 LOP quite effectively using full carb heat. Attempts to do so without carb heat lead to unacceptable engine roughness. With the carb heat on, I can reduce the RPM down several hundred RPM from peak RPM with good smoothness. Without the carb heat, the RPM peaks as the mixture gets leaner, then as the RPM begins to drop the engine gets progressively rougher. I have not run the engine LOP for any appreciable length of time as I have no CHT or EGT instrumentation. I have done it for a minute or so to see if it is possible. -- Aaron C. |
Need Information To Do A 150 Hp Conversion On My C-150 | spar | Owning | 25 | March 3rd 05 03:21 PM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
ANN: SoaringPilot 1.9.8 | Mark Hawkins | Soaring | 0 | April 21st 04 05:09 PM |
Japanese firm sold Libya uranium conversion plant | Dav1936531 | Military Aviation | 2 | March 17th 04 03:47 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
