Thats what is done on RC Heli's, the rate gyro directly sums into the
normal command. The only control you have is the gain on the gyro and I'd guess you'd have to adjust this to particular aircraft and preference of the pilot. I assume the gyro(s) would be pretty near the center of motion along with the pilot, but why is this a requirement? Doesn't any ridged part of the aircraft experience the same yaw,pitch,roll accelerations? One possible implimentation could be a gryo co-located with the actuator (servo) that controls that axis. I think this would replace manual trim because if you could do the stability control, you sure as heck could make it move back and forth in response to a 3 position toggle switch. If it breaks you fly without trim till you land. I think there is some rule that the aircraft must be controllable with any trim to it's full limit. |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
