Not to be a putz, but if you had talked with the people in the old
days who started putting "car" engines in boats, they would have told you that automotive manual transmissions were tried and generally found wanting. Marine transmissions have spring or elastic couplings, similar to those on auto clutches but bigger, and the gears are oversize. A torsion damper of some type-either a spring or elastic coupling, a quillshaft, or a belt or chain with a little stretch-is an absolute necessity. There's a simple way of measuring the torsion flexion which can be quickly used to troubleshoot the problems: on either side of the coupling, a "tone wheel" or regularly spaced magnetic or optical 'mark' is placed and a pickup-a LED/sensor or a simple solenoid coil (think electric guitar or Hammond organ)is placed. The phase relationship between the two signals is monitored and as the engine/load are cycled, where the two signals "wobbles" is where the flexion is happening. It's a simple test to rig up. OMC and Mercury have been doing this for years. I know because I worked in a music store in Wisconsin and they would buy a certain type of internally amplified guitar pickup for this purpose. |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 06:51 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
