Paraglider spiral dive, throws chute and ends up in the trees
Old February 26th 05, 01:11 AM
Stewart Kissel
Default Paraglider spiral dive, throws chute and ends up in the trees
http://dhost.info/Paragliding/Pages/...elandingmexico
2005.htm
Stunning POV vid of this accident sequence...
Old February 26th 05, 01:33 PM
David Kinsell
Stewart Kissel wrote:
http://dhost.info/Paragliding/Pages/...mexico2005.htm
Yep, really makes you want to stick with plastic wings, doesn't it?
-Dave
P.S. Your word wrap is set really tight, making for annoying chopped-up links.
It's fixed in this posting.
Old February 26th 05, 02:22 PM
Paul Remde
That is a very interesting video. What would cause a spiral dive like that?
Paul Remde
"David Kinsell" wrote in message
-Dave
links.
Old February 26th 05, 03:36 PM
David Kinsell
-Dave
links.
Paul Remde
I assume the canopy collapsed due to turbulence, and the shroud lines got
twisted and kept it collaped in the spiral. I'm sure he wasn't flying in
his normal configuration in the spiral, like a rigid wing craft does. I
suppose it was more of a spin than a spiral dive. That's always made me
nervous about ballistic chutes for regular gliders. If you're going to
deploy the chute, you may well be in a spin, making the successful deployment
of the chute questionable.
-Dave
Old February 26th 05, 11:26 PM
Paul Remde
Hi Dave,
I don't think spins are a problem for ballistic recovery systems.
Paul Remde
news
-Dave
links.
that?
Paul Remde
deployment
-Dave
Old February 28th 05, 04:29 PM
Iwo Mergler
In most cases the pilot. Deliberately. :^)
Paragliders don't have elevators, so a spiral is
the fastest way down.
It wasn't very clear from the video, but my guess
is that this was a tuck caused by turbulence which
lead to this very steep spiral.
The canopies are only tested at spiral descend speeds
of upt to 14m/s and what they do beyond that is not
very predictable. Some even steepen the spiral. It
doesn't help that thinking is harder at 4G.
Regards,
Iwo
Old March 1st 05, 07:01 AM
For anyone interested in this incident, there is quite a bit of
discussion on paraglidingforum.com:
http://paraglidingforum.com/viewtopic.php?t=1405
The consensus seems to be that the pilot applied and held brakes when
entering a thermal and this caused the wing to stall and deflate which
resulted in a cravat (tip stuck in the lines). The wing was spinning so
the pilot tossed the reserve chute. The pilot landed in a tall tree
with the wing draped over the tree and, while hanging there and picking
twigs out of the lines, he then fell to the ground basically unhurt.
His lucky day I suppose!
Steve
Old March 1st 05, 08:57 AM
Iwo Mergler
Steve
That is the exact oposite of my guess. I'll go and
watch the video again. Thanks for the link.
Iwo
Old March 1st 05, 10:04 PM
Mark
Incidentally Joe is flying again now that his broken rib has healed.
Mark Andrews
when
which
spinning so
picking
unhurt.
Steve
Iwo
