Strike Fighter Squadron OPTEMPO factors
Old March 2nd 05, 03:58 PM
Bob
Hi Jacek,
The question might be will switching to an all-Hornet airwing actually
result in a lower MMH/FH number for the involed squadrons? Bean
counters and analysts would probably agree that benefits of scale, less
duplicity, and better support concentration should result in a lower
MMH/FH. I doubt it. On the other hand, having four or five squadrons
with the same airplane might very well net you better availability just
from the improved competitive environment. Guys would try harder to be
number one in all quantifiable aspects of their efforts. There would
be a distinct tendenency for your supply system to anticipate lower
inventory need and give you fewer high failure parts per embarked
airplane. Reshuffling a carrier's supply inventory takes a major
effort so it would be unlikely all the non-Hornet parts would be off
loaded. Carriers spare parts lockers are space limited. Most often
the most used parts are in short supply with the least called for being
the majority. No matter how you provision expected MTBF's will not
equal actual usage. Peter principle. The longer your AOCP times
become, the lower your availability and higher the MMH/FH. Long AOCP
times result in squadron ratholing and resulting lower supply parts
availabilty. Any guy who would be smart enough to solve this should be
transferred to working on world peace.
Old March 3rd 05, 12:14 PM
Actually, we are talking about not one type, but two - because we can
say about a great degree of commonality between F/A-18A+ and C, or
between F/A-18E, F/A-18F and (future) EA-18G. That is why every "older"
CV (I mean: except CVN-75 and CVN-76) which is gonna to deploy with
F/A-18E or F (or both), has to undergo some modifications first.
CVW-9 in 2003 - with four F/A-18C squadrons (VFA-22, VFA-146, VFA-147,
plus VMFA-314) - yes, that was commonality indeed, but capabilities
(combat radius, on-station time, cycles lenght etc) must have suffered.
Surely, putting Rhinos on carriers should be a progress when compared
to MMH-eating F-14 and A-6s. But there will be a time some day when now
brand-new F/A-18E/Fs also get older, and IF consider them "stealth"
aircraft, they may require more maintenance to be kept as radar-clean
as possible after being exposed to AAA/SAM fire and/or harsh weather
conditions?...
Regards,
Jacek
U.S. Air Force to purchase 1,763 LOCKHEED MARTIN F-35 Joint Strike Fighter jets for $245 billion Larry Dighera Military Aviation 0 July 22nd 04 06:06 AM
Spangdahlem-based fighter squadron performs 3-week exercise in preparation for deployment Otis Willie Military Aviation 0 July 3rd 04 11:19 PM
Joint Strike Fighter focus sparks concern Otis Willie Military Aviation 0 March 19th 04 09:19 PM
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 03:59 AM
