I know you can't get an RV-10 for $85K. Used engine, and bare min VFR
panel, maybe. Neither can you get an IFR Velocity XL for that. But I think you can build an IFR Velocity SE or KIS Cruiser for that amount, fixed-pitch prop, new engine. "Paul Folbrecht" wrote in message ... You are sadly mistaken if you think that there is a four seater IFR platform with 3 hours (really almost 4) of fuel flying 150 KTAS out there. Just Well, I suppose, then, that the RV-10 and Velocity XL do not actually exist. Or that their designers GREATLY exaggerate their performance figures. Or that, based on your definition of an IFR platform (I can only imagine), they don't qualify. For $85K you are dreaming. Clyde Torres |
Paul, apologies accepted on the other email.
My point is, though, that $85K is a low number for a true four seater IFR platform that performs the way you want it to. The numbers I've seen are way up in the $135K range. Every bird I've seen that used an O-360/O-320 and had four seats was not really a four seater capable of carrying four people comfortably with some bags and enough fuel to fly four hours. You need a bigger airframe and a bigger engine, thus driving the costs up. Every person that has done this analysis before you either gave up or settled for a two person airplane that has four seats. Many of these aircraft are wonderful aircraft - better than production models. They will haul two people very comfortably with plenty of room for fuel and bags, but as soon as you put two people in the back, you are very limited in what you can carry. Clyde "Paul Folbrecht" wrote in message ... I know you can't get an RV-10 for $85K. Used engine, and bare min VFR panel, maybe. Neither can you get an IFR Velocity XL for that. But I think you can build an IFR Velocity SE or KIS Cruiser for that amount, fixed-pitch prop, new engine. "Paul Folbrecht" wrote in message ... You are sadly mistaken if you think that there is a four seater IFR platform with 3 hours (really almost 4) of fuel flying 150 KTAS out there. Just Well, I suppose, then, that the RV-10 and Velocity XL do not actually exist. Or that their designers GREATLY exaggerate their performance figures. Or that, based on your definition of an IFR platform (I can only imagine), they don't qualify. For $85K you are dreaming. Clyde Torres |
![]() Paul, apologies accepted on the other email. My point is, though, that $85K is a low number for a true four seater IFR platform that performs the way you want it to. The numbers I've seen are way up in the $135K range. Don't know who's numbers you have seen but yes, the $135K range is not unusual but not required either. The difference is in the details and I do mean in the details. If you do the work yourself and don't have the panel custom fabricated, custom interiors, constant speed props, FADEC systems, and a host of other very expensive options, the costs come down considerably. So before you say it "can't" be done, do the detail research to determine the cost breakdown and what could be done. Every bird I've seen that used an O-360/O-320 and had four seats was not really a four seater capable of carrying four people comfortably with some bags and enough fuel to fly four hours. You have seen and detailed all the four place aircraft? Don't believe so. You need a bigger airframe and a bigger engine, thus driving the costs up. Depends on mission profile. If you intend to fly four and a lot of baggage all the time, I might agree but if that is NOT your mission, I totally disagree. Every person that has done this analysis before you either gave up or settled for a two person airplane that has four seats. TOTALLY WRONG! And you don't speak for everyone. By the way, I have flown two different KIS Cruisers with four people on board and in one case it was also loaded with baggage. Both flights were fairly comfortable and the performance was great. Many of these aircraft are wonderful aircraft - better than production models. They will haul two people very comfortably with plenty of room for fuel and bags, but as soon as you put two people in the back, you are very limited in what you can carry. Clyde Hell, I know of many twins that suffer the same fate so should we say that all twins are equally limited? Sorry Clyde but you need to do a little more homework. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
