Felt like a sink, but I've never heard that term, only windshear.
![]() "Bravo8500" wrote in message oups.com... Felt like a sink, but I've never heard that term, only windshear. We use it mostly in gliders -- sometimes referred to as a downdraft by power pilots. Glider guiders call updrafts "lift." Typically measured on a vario(meter) in fps or knots. The only difference between a vario and an VSI is the vario usually beeps. The pitch and period of the beeps sort of indicate the velocity. Lift and sink work together -- somewhere in the vicinity there was a rising volume of air. You were unlucky enough to fly into the negative half. Sorry if that seems patronizing or pedantic. That brings up an autopilot question you might answer for me. If you had not disconnected the autopilot, could it have taken you into a stall? |
Downdraft, shear, microburst - bad! The ap I use (kfc200) only knows to
hold altitude, it doesn't care about airspeed, so it will gladly stall it for you. |
I say that, but in reality it may just apply so much back pressure, or
trim, and then it would simply fail to hold altitude. I've never tested it. |
On Fri, 04 Mar 2005 01:53:44 GMT, "Casey Wilson" N2310D @ gmail.com
wrote: "Bravo8500" wrote in message roups.com... Felt like a sink, but I've never heard that term, only windshear. We use it mostly in gliders -- sometimes referred to as a downdraft by power pilots. Glider guiders call updrafts "lift." Typically measured on a vario(meter) in fps or knots. The only difference between a vario and an VSI is the vario usually beeps. The pitch and period of the beeps sort of indicate the velocity. Lift and sink work together -- somewhere in the vicinity there was a rising volume of air. You were unlucky enough to fly into the negative half. Sorry if that seems patronizing or pedantic. That brings up an autopilot question you might answer for me. If you had not disconnected the autopilot, could it have taken you into a stall? That depends on the AP, but mine (IF set to altitude hold) will just keep pulling the nose up until it quits flying. That means you need to know your power settings when doing a step down approach,.Altitude hold off, power back (by the numbers), gear down (depends), flaps (maybe), lead the altitude with power, with the power back to the proper setting for the approach, turn the altutude hold back on. BTW, the FAA defines wind shear as *any* abrupt change in wind direction or speed. That includes up and down. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Weird Experimental Certificate wording - Normal? | Noel Luneau | Soaring | 7 | January 11th 05 02:53 PM |
On windshear | Ramapriya | Piloting | 8 | January 8th 05 08:02 PM |
Weird stuff over New Jersey | G.R. Patterson III | Piloting | 5 | October 23rd 04 06:49 PM |
Weird Emergencies | SelwayKid | Rotorcraft | 18 | April 19th 04 11:33 PM |
Weird radio "problem" | Michael 182 | Owning | 2 | August 20th 03 06:29 PM |
