"Robert Bonomi" wrote in message
... Well, *except* for the fact that the U.S. government was already a signatory to an international treaty _disclaiming_ any such claims of territorial ownership "in space". But what I *really* wanted to explore was design ideas for a homebuilt "airborne" Moon vehicle. Here's the scene: You're living on Luna, having retired from ______ (fill in blanks at your pleasure). It's the year ____ and low-gravity retirement has become the "in" thing. You live longer, the old aches and pains are less, etc. Your Social Security private trust fund has built up to the point that you just *have* to start spending some of it! The one thing you miss since moving out here is roaring around in your homebuilt on Saturday afternoons. So, absent any regulation to the contrary, you decide to build a Lunar replacement. First thing to decide on is a name for the critter. Hmmm..... Moonraker sounds appropriate. Wonder if anybody has used that one? Oh heck with that, let's get on to the design parameters. Seats - One, two??? Pressurization - (?) if not, then a big enough seat to accommodate a space suit. Range - There's fuel and air caches every 1,800 miles, so let's add ~10% and say 2,000 miles. Speed - Let's say 600 knots. (What I'm doing is multiplying typical terran specs by 6. Why? I dunno) Payload - (?) We can let the Mass/Weight guys duke that one out. Visible means of support (Lift) - Wonder if NASA has an airfoil for an airless environment? If not, we'll have to come up with something. I wouldn't want to go ballistic - it's not as much fun as low & slow. Thrust - Open for suggestions. . . Primary source of power - Anybody got a design for something better than a Chinese sparkler? C'mon guys. There's got to be another Rutan out there. What are we going to do when he's history? Rich S. |
![]() "Rich S." wrote But what I *really* wanted to explore was design ideas for a homebuilt "airborne" Moon vehicle. First, with all that extra disposable income from Social Security (Yea, who said you couldn't dream big) you have to think terraforming first, and create an atmosphere. I know! Get Zoom and Yaun up there! They are both full of hot air, and we can worry about cooling it off, later! Let's see, if we get it up to 1/5th density, then we could fly at the same speeds we see here on Earth, right? -- Jim in NC |
On Sat, 5 Mar 2005 07:29:57 -0800, "Rich S."
wrote: But what I *really* wanted to explore was design ideas for a homebuilt "airborne" Moon vehicle. Here's the scene: You're living on Luna, having retired from ______ (fill in blanks at your pleasure). It's the year ____ and low-gravity retirement has become the "in" thing. You live longer, the old aches and pains are less, etc. Your Social Security private trust fund has built up to the point that you just *have* to start spending some of it! The one thing you miss since moving out here is roaring around in your homebuilt on Saturday afternoons. So, absent any regulation to the contrary, you decide to build a Lunar replacement. "Moon Zero Two", 1969, starring James Olson. First thing to decide on is a name for the critter. Hmmm..... Moonraker sounds appropriate. Wonder if anybody has used that one? Been there, done that: http://www.bowersflybaby.com/stories/leoraker.JPG Oh heck with that, let's get on to the design parameters. Seats - One, two??? With a weight increase, the amount of fuel needed increases disproportionately. Also, if you add a second seat, you're always going to have to have a body or ballast in the spot to keep the beast in balance. Pressurization - (?) if not, then a big enough seat to accommodate a space suit. It's tough to do precision work in a space suit. The gloves give you next to no tactile feel...in fact, the fingertips are usually covered with hard rubber shells. http://www.hightechscience.org/orlan_space_glove.htm You're not going to be able to work a keyboard, and if you have buttons and whatnot to push, they're going to have to be well separated to ensure you don't punch the wrong one. It's gonna be tough to fly without a pressurized cabin. But...again, pressurization is going to add a lot of weight. You not only need a pressure hull with windows and an openable door, but you're going to need the typical air conditioning functions such as oxygen replacement, CO2 removal, humidity control, etc. Since these problems are ALREADY solved with a space suit, you might as well just go open cockpit...after all, you'll need a space suit onboard anyway for the walk from the landing field to the cafe for that $100,000,000 hamburger. Hmmmm, single seat, open cockpit. The Luna Baby? :-) Range - There's fuel and air caches every 1,800 miles, so let's add ~10% and say 2,000 miles. 2000 miles is about 1/3 the way around the entire moon...2/3rds the maximum distance you'd want to fly, anyway. It's been years since I did any sort of lunar orbit work (and even that was only for a week or so...damned if I can even remember what program it was). To get some answers, I modified one of my orbit analysis tools to do Moon orbits (changed the values for G, planetary radius, and gravitational constant). In other words, lotsa approximations here. For a 2000-mile ballistic trajectory on the Moon that gets at least 10 NM high, you'll need about 5000 FPS of acceleration. And if you want to touch down with near-zero speed, you'll need about the same for deceleration. We'll call it a total of 10,000 FPS. Flight time less than a half hour, including accel and decel. Let's assume an open-cockpit single-seater. Call it 200 lbs for the pilot, another 100 lbs for his suit, 500 pounds of airframe, 20 pounds of avionics, and 50 pounds for batteries and life support supplied. Let's assume our rocket fuel has a specific impulse of 250 seconds. That's a dry weight of about 870 pounds. The fuel comes out to another 2150 pounds. Like Robert said, though, we could use a mass driver or other ground-based system to throw the vehicle, and just rely on onboard fuel to land. This drops the required onboard fuel to about 750 pounds. Not too bad. Speed - Let's say 600 knots. (What I'm doing is multiplying typical terran specs by 6. Why? I dunno) Visible means of support (Lift) - Wonder if NASA has an airfoil for an airless environment? If not, we'll have to come up with something. I wouldn't want to go ballistic - it's not as much fun as low & slow. Yep, ballistic wouldn't be much fun. You want a "Hollywood" moon flight: Take off, climb to a given altitude, cruise at that altitude through the entire flight, then descend to land. If we don't have antigravity, what's it going to take? Let's look at the cruise speed first. 600 knots is about 1000 FPS, and we'll need both acceleration and deceleration fuel. Total 2000 FPS. Give it another 500 FPS to cover the climb (coming down is free!). To fly at the constant altitude, we'll need constant downward thrust to counteract the force of gravity. Since we're flying 2000 NM at 600 knots, we have to do this for about 3.3 hours. Call it four hours with VFR reserves. :-) So...we have to burn our downward thrusters for four hours. "G" on the Moon is about 5.6 ft/Sec^2. We'd need to burn the same to counter that. Total acceleration required is 5.6 ft/sec^2 x 4 hours x 3600 seconds/hour... about 80,000 FPS, about sixteen times more than a ballistic S/C using a mass driver for launch, and, as a point of interest, almost three times what a spacecraft launch from the *Earth* needs. With the accel/decel Delta-V, our 870-pound spacecraft requires 24.9 *million* pounds of fuel. C'mon guys. There's got to be another Rutan out there. What are we going to do when he's history? Live far more boring lives, I reckon.... Ron Wanttaja |
Ron Wanttaja wrote:
On Sat, 5 Mar 2005 07:29:57 -0800, "Rich S." wrote: But what I *really* wanted to explore was design ideas for a homebuilt "airborne" Moon vehicle. Here's the scene: You're living on Luna, having retired from ______ (fill in blanks at your pleasure). It's the year ____ and low-gravity retirement has become the "in" thing. You live longer, the old aches and pains are less, etc. Your Social Security private trust fund has built up to the point that you just *have* to start spending some of it! The one thing you miss since moving out here is roaring around in your homebuilt on Saturday afternoons. So, absent any regulation to the contrary, you decide to build a Lunar replacement. "Moon Zero Two", 1969, starring James Olson. First thing to decide on is a name for the critter. Hmmm..... Moonraker sounds appropriate. Wonder if anybody has used that one? Been there, done that: http://www.bowersflybaby.com/stories/leoraker.JPG Oh heck with that, let's get on to the design parameters. Seats - One, two??? With a weight increase, the amount of fuel needed increases disproportionately. Also, if you add a second seat, you're always going to have to have a body or ballast in the spot to keep the beast in balance. Pressurization - (?) if not, then a big enough seat to accommodate a space suit. It's tough to do precision work in a space suit. The gloves give you next to no tactile feel...in fact, the fingertips are usually covered with hard rubber shells. http://www.hightechscience.org/orlan_space_glove.htm You're not going to be able to work a keyboard, and if you have buttons and whatnot to push, they're going to have to be well separated to ensure you don't punch the wrong one. It's gonna be tough to fly without a pressurized cabin. But...again, pressurization is going to add a lot of weight. You not only need a pressure hull with windows and an openable door, but you're going to need the typical air conditioning functions such as oxygen replacement, CO2 removal, humidity control, etc. Since these problems are ALREADY solved with a space suit, you might as well just go open cockpit...after all, you'll need a space suit onboard anyway for the walk from the landing field to the cafe for that $100,000,000 hamburger. Hmmmm, single seat, open cockpit. The Luna Baby? :-) Range - There's fuel and air caches every 1,800 miles, so let's add ~10% and say 2,000 miles. 2000 miles is about 1/3 the way around the entire moon...2/3rds the maximum distance you'd want to fly, anyway. It's been years since I did any sort of lunar orbit work (and even that was only for a week or so...damned if I can even remember what program it was). To get some answers, I modified one of my orbit analysis tools to do Moon orbits (changed the values for G, planetary radius, and gravitational constant). In other words, lotsa approximations here. For a 2000-mile ballistic trajectory on the Moon that gets at least 10 NM high, you'll need about 5000 FPS of acceleration. And if you want to touch down with near-zero speed, you'll need about the same for deceleration. We'll call it a total of 10,000 FPS. Flight time less than a half hour, including accel and decel. Let's assume an open-cockpit single-seater. Call it 200 lbs for the pilot, another 100 lbs for his suit, 500 pounds of airframe, 20 pounds of avionics, and 50 pounds for batteries and life support supplied. Let's assume our rocket fuel has a specific impulse of 250 seconds. That's a dry weight of about 870 pounds. The fuel comes out to another 2150 pounds. Like Robert said, though, we could use a mass driver or other ground-based system to throw the vehicle, and just rely on onboard fuel to land. This drops the required onboard fuel to about 750 pounds. Not too bad. Speed - Let's say 600 knots. (What I'm doing is multiplying typical terran specs by 6. Why? I dunno) Visible means of support (Lift) - Wonder if NASA has an airfoil for an airless environment? If not, we'll have to come up with something. I wouldn't want to go ballistic - it's not as much fun as low & slow. Yep, ballistic wouldn't be much fun. You want a "Hollywood" moon flight: Take off, climb to a given altitude, cruise at that altitude through the entire flight, then descend to land. If we don't have antigravity, what's it going to take? Let's look at the cruise speed first. 600 knots is about 1000 FPS, and we'll need both acceleration and deceleration fuel. Total 2000 FPS. Give it another 500 FPS to cover the climb (coming down is free!). To fly at the constant altitude, we'll need constant downward thrust to counteract the force of gravity. Since we're flying 2000 NM at 600 knots, we have to do this for about 3.3 hours. Call it four hours with VFR reserves. :-) So...we have to burn our downward thrusters for four hours. "G" on the Moon is about 5.6 ft/Sec^2. We'd need to burn the same to counter that. Total acceleration required is 5.6 ft/sec^2 x 4 hours x 3600 seconds/hour... about 80,000 FPS, about sixteen times more than a ballistic S/C using a mass driver for launch, and, as a point of interest, almost three times what a spacecraft launch from the *Earth* needs. With the accel/decel Delta-V, our 870-pound spacecraft requires 24.9 *million* pounds of fuel. C'mon guys. There's got to be another Rutan out there. What are we going to do when he's history? Live far more boring lives, I reckon.... Ron Wanttaja Hey, they didn't do it that way in "2001 a Space Odyssey" when they cruised across the surface ofthe moon in the moon bus. Dan "who thinks Ron has shot down my dreams", U.S. Air Force, retired |
"Dan, U.S. Air Force, retired" wrote in message
news:rGsWd.24184$Sn6.22376@lakeread03... Hey, they didn't do it that way in "2001 a Space Odyssey" when they cruised across the surface ofthe moon in the moon bus. Wasn't that a monorail or cable-suspended car? Rich "running low on memory" S. |
Rich S. wrote:
"Dan, U.S. Air Force, retired" wrote in message news:rGsWd.24184$Sn6.22376@lakeread03... Hey, they didn't do it that way in "2001 a Space Odyssey" when they cruised across the surface ofthe moon in the moon bus. Wasn't that a monorail or cable-suspended car? Rich "running low on memory" S. No, it had 6 (?) rocket engines aimed downwards. I had the model whan I was in highschool. Dan, U.S. Air Force, retired |
On Sat, 05 Mar 2005 19:11:22 GMT, Ron Wanttaja
wrote: Let's assume an open-cockpit single-seater. Call it 200 lbs for the pilot, another 100 lbs for his suit, 500 pounds of airframe, 20 pounds of avionics, and 50 pounds for batteries and life support supplied. Let's assume our rocket fuel has a specific impulse of 250 seconds. That's a dry weight of about 870 pounds. forgive my iggorance. are we talking earth pounds, moon pounds or mass? and if we are talking mass is it roman catholic, anglican or engineering? you get that for ruining dreams :-) what is actually needed is for someone to do a Wright Brothers on gravity. aviation would go another quantum leap forward if we could just negate the aircraft weight without all that drag. it is amazing that with all our progress we havent made one single inroad into understanding or controlling gravity. Star Wars episode 1, The phantom menace was shown on local telly last night. I'm amazed at how correct the understanding of an antigravity world was in that film. Stealth (ok, antigravity liftoff, now how do we get thrust?) Pilot |
On Sun, 06 Mar 2005 14:03:42 +0800, Stealth Pilot wrote:
On Sat, 05 Mar 2005 19:11:22 GMT, Ron Wanttaja wrote: Let's assume an open-cockpit single-seater. Call it 200 lbs for the pilot, another 100 lbs for his suit, 500 pounds of airframe, 20 pounds of avionics, and 50 pounds for batteries and life support supplied. Let's assume our rocket fuel has a specific impulse of 250 seconds. That's a dry weight of about 870 pounds. forgive my iggorance. are we talking earth pounds, moon pounds or mass? and if we are talking mass is it roman catholic, anglican or engineering? Now stop that. :-) what is actually needed is for someone to do a Wright Brothers on gravity. aviation would go another quantum leap forward if we could just negate the aircraft weight without all that drag. it is amazing that with all our progress we havent made one single inroad into understanding or controlling gravity. You've hit the nail right on the head. Right now, space travel is at the equivalent level of the Montgolfier brothers. Chemical rockets are a dead end; the moral equivalent of de Rozier's combination hot air/hydrogen balloon. Heavier than air flight wasn't possible until the invention of the internal combustion engine. Similarly, the true exploitation of space is waiting for a system that will produce good acceleration without the need of tons of fuel. It's sort of in our grasp, now. Chemical fueled engines have Specific Impulses (Isp) in the range of 200-300 seconds. Modern electric propulsion units see ISPs up to about 3000 seconds. What does that mean? Well, I used an Isp of 250 for the thrust-hovering moon buggy. If you recall, it needed 25 million pounds of fuel for Rich's cross-country. With an ISP of 3000, the fuel requirement drops from 25,000,000 pounds...to a bit over 1,000. Yes, about four orders of magnitude. These units are operational *now*...they're used on communications satellites. They produce a lot of thrust for very little fuel, but the actual amount of thrust they produce is minuscule. The commsats use them to compensate for the north-south wobble their orbits get from the uneven distribution of mass within the earth. They need 150 FPS of delta-V per year, and they run the electric propulsion nearly constantly. As you might expect, they require a lot of power. But a dozen miles from Rich's house, a number of airtight spacecraft hulls complete with operational nuclear power plants lie in storage. The Navy calls them, "mothballed submarines." Back when a tsunami hit Hawaii forty or so years ago, they powered Honolulu with the output of *one* of these subs. Cooling them in space, where you don't have access to billions of tons of cold sea water, is left to the good offices of your local thermal engineer. Ron Wanttaja |
Ron Wanttaja wrote:
they powered Honolulu with the output of *one* of these subs. Cooling them in space, where you don't have access to billions of tons of cold sea water, is left to the good offices of your local thermal engineer. Ron Wanttaja Help me out with this one. While all the sci-fi I sopped up as a kid referred to the "cold of outer space," isn't vacuum a perfect insulator? How WOULD you cool the reactors (or whatever engine) with no atmosphere or handy heavy liquid at lower temp? Wouldn't it take a long time for the excited molecules to settle down? I love this thread. |
StellaStarr wrote:
Ron Wanttaja wrote: they powered Honolulu with the output of *one* of these subs. Cooling them in space, where you don't have access to billions of tons of cold sea water, is left to the good offices of your local thermal engineer. Ron Wanttaja Help me out with this one. While all the sci-fi I sopped up as a kid referred to the "cold of outer space," isn't vacuum a perfect insulator? How WOULD you cool the reactors (or whatever engine) with no atmosphere or handy heavy liquid at lower temp? Wouldn't it take a long time for the excited molecules to settle down? I love this thread. Yea I already have my moon station built and the prefab's ready to ship, life supports finished now all I need is to complete the rockets to get them there! As soon as I'm finish with the KR-2 ( at current rate that will take another 30 years!). John wishin and dreamin |
About the Global Flyer | robert arndt | Military Aviation | 0 | January 11th 04 03:46 AM |
Call your local TV station, get Wright Flyer on the air | Mark James Boyd | Soaring | 0 | December 17th 03 05:09 PM |
Wright Flyer won't fly! | Trent Moorehead | Piloting | 31 | October 18th 03 04:37 PM |
Wright Flyer | Dave Hyde | Home Built | 9 | September 29th 03 05:20 PM |
Arming Global Hawk Draws Conflicting Comments From Pentagon | Larry Dighera | Military Aviation | 5 | July 14th 03 08:51 PM |
