wing levelers
Old March 7th 05, 05:39 AM
Dan, U.S. Air Force, retired
UltraJohn wrote:
Dan, U.S. Air Force, retired wrote:
Blueskies wrote:
More than 'just a wing leveler'
http://www.trioavionics.com/
If I were me I'd go with something like that rather than homebrew.
Myaccommodatejection is its panel gulping size. It would be nice to have a
gyro/accelerometer package elsewhere and a small panel you can pace as
you please.
I don't know Dan you must be flying a pretty tight plane. The unit
referenced is only 3.25" square by 2.75" deep for the panel mount part, the
servo which isn't panel mounted is a bit bigger. Most homebuilts can
accommodate that. Now all I need to do is get to work on this KR-2 in the
garage!
John
I'm building an airplane I personally will never fly (can't pass the
physical). The only thing I could do to install the system in question
is remove the TAS indicator.
Dan, U.S. Aie Force, retired
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
