Chuck Slusarczyk wrote: I seem to remember somebody taking the BD fuse and wing and building twin booms for it .Is there a photo on E bay? I thought it was a one off that was at Osh back then. I Chuck S The ebay plane is composite fuselage not aluminum. Bernadette |
In article , Doc Font says...
The ebay plane is composite fuselage not aluminum. As Rosanne Rosannadana used to say " Oh! That's something entirely different.." Maybe the seller can shed some light on where some of the articles on the plane might be located. Good luck Chuck S |
ChuckSlusarczyk wrote:
In article , Doc Font says... The ebay plane is composite fuselage not aluminum. As Rosanne Rosannadana used to say " Oh! That's something entirely different.." Maybe the seller can shed some light on where some of the articles on the plane might be located. Good luck Chuck S There is an article in the September 1970 Sport Aviation by Marshall White titled, Profile of a Homebuilt "Der Jaeger". That seems too early for the airplane described on ebay but the name is the same. Does someone have a copy of the magazine to see if it's the same? Gary Thomas |
Good luck With a empty weight of 275 lbs and a wing sq footage of 30.9, I am not sure luck will be sufficient g. Rob ..ps allow 125 lbs for the 582 and that leaves you 150 lbs for the airframe. |
In article , Robert Schieck says...
ChuckSlusarczyk wrote: Good luck With a empty weight of 275 lbs and a wing sq footage of 30.9, I am not sure luck will be sufficient g. Rob .ps allow 125 lbs for the 582 and that leaves you 150 lbs for the airframe. As the Loving Spoonfull used to sing "Do you believe in Magic?" :-) Ahhh....the optimism of some designers will be tempered with the first weigh in of the prototype LOL!! See ya Chuck S |
"Robert Schieck" . wrote With a empty weight of 275 lbs and a wing sq footage of 30.9, I am not sure luck will be sufficient g. Rob .ps allow 125 lbs for the 582 and that leaves you 150 lbs for the airframe. Hell, that ain't so hard! Just fill the fuselage and wing with helium! -- Jim in NC |
On Tue, 8 Mar 2005 16:04:14 -0500, "Morgans"
wrote: "Robert Schieck" . wrote With a empty weight of 275 lbs and a wing sq footage of 30.9, I am not sure luck will be sufficient g. What's wrong with 9# per sq ft? I'm working on 30# per sq ft. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Rob .ps allow 125 lbs for the 582 and that leaves you 150 lbs for the airframe. Hell, that ain't so hard! Just fill the fuselage and wing with helium! |
| Thread Tools | |
| Display Modes | |
