Sharing static and pitot line
Old March 7th 05, 02:59 PM
BB
I have run in to problems sharing a pitot between ASI and Cambridge
302, resulting in several very frustrating days at Hobbs one year where
it seemed as if I had forgotten to thermal. Separate pitots for the two
instruments solved the problem. Luckily, I have a tail pitot and a nose
pitot so each can have its own. The 302 seems particularly fussy about
having its own pitot and static sources however.
John Cochrane
Old March 7th 05, 09:39 PM
1MoClimb
where
two
nose
about
John Cochrane
John,
I'm flying a 302 in my LS8 and cannot recall any problems in having it
attached to the same pitot that supplies pressure to the ASI. How
would you describe the behavior of the 302, just weird
deflections/audio signals?
Herb, J7
Old March 7th 05, 10:39 PM
I went through that learning curve with the 302 in Hobbs last summer.
The working combination was to have the 302's static and TE/static
ports connected to the same source, and (very important!) changing the
302's internal setup to use electronic TE. Once I did that, the 302's
vario and my B-40 danced to the same tune.
2NO
Old March 7th 05, 11:49 PM
Eric Greenwell
Based on my experience with my 302, I don't think it was the 302. On my
ASH 26 E, I went from a tail mounted TE feed to the 302 to using the ASI
pitot/static (electronic TE) with no detectable change in ASI or 302
operation. Just guessing: perhaps your connection involved a leak, or
maybe the 302 was not happy using a nose pitot and a TE probe and static
at the rear of the glider.
Eric Greenwell
Washington State
USA
Old March 8th 05, 12:08 PM
Istvan Csonka
Hello,
Maybe there was a misunderstanding.
I am asking advices for the following:
On a PIK20D, there are 4(four) tubes comming up from the cockpit at the panel:
1. Pitot from the nose
2. TE from the fin
3. Left rear fuselage static
4. Right rear fuselage static
What would be the best (optimal) tubing for the following instruments ?
1. Simple ASI
2. Simple Altimeter
3. Simple PZL mech vario
4. Peschges VP9
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Fine example of Tarver Engineering release for service running with scissors Military Aviation 79 March 3rd 04 01:48 PM
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 64 March 3rd 04 05:01 AM
Chuck Yeager-pitot tube Ron Military Aviation 44 October 9th 03 03:13 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
