wing levelers
Old March 8th 05, 04:31 PM
Evan Carew
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Ron,
Try adding in some cross controll input & acelerometer error Bzzzzt. The
deal is that over time, any acelerometer, even 3 axix will accumulate
error, and ignoring your idea of non-realtime GPS directional input for
the moment, what you need is a leaky integrator. To accomplish this, you
need to be able to sense the horizon in an accelerated frame of
reference. You can accomplish this in a number of ways. The two that
come readily to mind are magnetometers & solid state or otherwise steam
gage type gyros. Sadly, this last requirement for instrumentation is
often where the expense for your system will come in to play.
Evan Carew
Ron Webb wrote:
Your GPS can't tell you whether you're straight and level, only whether
you're straight.
Agreed.
But if the GPS says I'm straight (over a 10 second average) and the
accelerometer says the roll axis vector is pointed toward the floor of the
aircraft, then it seems to me I'm straight (otherwise the heading would be
changing) and level - since if there is no heading change the only vector
remaining is G.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFCLdNmpxCQXwV2bJARAo9QAJ9IMxPQ/igwTJZ+enML69Su6SRd9QCfbHYp
VCxBa5Nc6LdrmsK+D3W6/Tc=
=JQDQ
-----END PGP SIGNATURE-----
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
