"George Patterson" wrote in message
... Are you required to perform weight and balance checks before every flight? No. If I'm flying alone in an aircraft that has a useful load of over 800 pounds, it would be pretty silly to calculate W&B. Sort of. The "weight" part is obviously satisfied, but the "balance" part is not. Of course, in most cases, a pilot will have done enough sample W&B calculations to know when they need to consider the "balance" part for solo or lightly loaded operations. This is probably true in your case as well. But that doesn't mean you didn't do the "balance" part...it just means you did it once (or a few times) and have applied the results to many subsequent flights. Even for the "weight" part, the few seconds it takes you to consider that you're alone and well under the useful load of the aircraft would certainly qualify as "perfoming a weight check". Just because you didn't write it down or do formal calculations, that doesn't mean you didn't verify that you were within the weight and balance envelope of the aircraft for that flight. IMHO, the correct answer is "yes, you are required to perform weight and balance checks before every flight". What those checks entail varies according to the flight and prior experience with the aircraft. But a pilot who can say, without making a (another) weight and balance calculation, whether the aircraft is within limits or not has made a de facto check of the weight and balance for that flight, whether or not they have made a formal calculation using the exact fuel, oocupant, and cargo load for that flight. (And conversely, a pilot who cannot make such a statement has not fulfilled the preflight duties required of that pilot). Bottom line: if you *know* that the aircraft is within the required limits, then you've made the preflight weight and balance checks. And you ARE required to *know* that the aircraft is within the required limits. Pete |
Same BA 747 loses engine again, Violated U.S. regulations | Big John | Piloting | 3 | March 8th 05 10:38 PM |
Ultra light Glider regulations | Denis G | Soaring | 5 | May 24th 04 06:19 PM |
ANN: WingX Version 1.2 - Federal Aviation Regulations on your PDA! | Hilton Software LLC | Piloting | 7 | October 17th 03 04:51 PM |
New UK Regulations | Soaring | 5 | October 2nd 03 12:13 AM | |
FAR:Safety Pilot & High Performance/Complex? | John T | Piloting | 53 | August 18th 03 04:04 PM |
