![]() "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. -- Jim in NC |
On Tue, 8 Mar 2005 17:24:46 -0500, "Morgans"
wrote: "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. Another "coffin corner" I have heard discussed is the convergence of Vne and Vs as altitude increases. I think it went something like this: 1. Vne is a TAS, so its IAS decreases with increasing altitude. Vs is an IAS, so as IAS, it remains the same with increasing altitude. Therefore, Vne, in IAS converges with Vs in IAS as altitude increases. 2. Seen the other way, the TAS of Vs increases with altitude, converging with the fixed TAS of Vne. Or something like that I guess. |
"Morgans" wrote
No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Nope! Mike got it right. "Jim" wrote Another "coffin corner" I have heard discussed is the convergence of Vne and Vs as altitude increases. Nope! Mike got it right. Coffin corner From Wikipedia Coffin corner is a dangerous portion of the flight envelope that must be carefully approached by high altitude high subsonic speed aircraft, such as the Lockheed U-2 aircraft. Mach Limit A subsonic aircraft must not exceed its Mach limit, some fraction of the speed of sound near, but not at 1.0. At the low air densities encountered at high altitude the speed of sound is lower. Exceeding the Mach limit can cause loss of control and/or structural failure. Stall Limit At high altitudes the low density air is less capable of supporting the aircraft and so the stall speed increases (as expressed in true air speed). The Corner At some limiting altitude these speeds converge, and the aircraft cannot be flown, as a slight pitch down will cause the Mach limit to be exceeded while a slight pitch up will cause an aircraft stall with a subsequent pitch down. I've been to "coffin corner" in a Navy T2-V and very near to it in a Boeing 707 and neither time was I close to Vne..Critical Mach Number..yes, but not Vne. Bob Moore ATP B-707 B-727 |
![]() "Bob Moore" wrote Nope! Mike got it right. Ok, so what is the thing that Bruce , in the Exxon Tiger experienced? I'm quite sure that is what he called it, and could look back in the Magazines, to the interview. Some of my descriptions may have been off, but those were his words. I have no doubt that what you described is accurate, but am also as confident that there are other ways, in other aircraft, to get there. Possible? -- Jim in NC |
![]() "Morgans" wrote in message ... "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. -- Jim in NC I've never heard of Vne being related to TAS, only IAS. It makes no sense to me. Could you provide a reference? Mike MU-2 |
On Wed, 09 Mar 2005 14:58:38 GMT, "Mike Rapoport"
wrote: "Morgans" wrote in message ... "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. -- Jim in NC I've never heard of Vne being related to TAS, only IAS. It makes no sense to me. Could you provide a reference? Mike MU-2 I'm not sure this is addressed to me, but just in case it is: I guess the notion about Vne as a TAS is that Vne may be specified for a given aircraft as an airspeed that depends on altitude. I guess it could as easily be specified as an IAS at sea level and gross weight, with a written notice to the pilot that Vne would then be at a lower IAS as altitude increases. Does this make any sense? |
![]() "Jim" wrote in message ... On Wed, 09 Mar 2005 14:58:38 GMT, "Mike Rapoport" wrote: "Morgans" wrote in message ... "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. -- Jim in NC I've never heard of Vne being related to TAS, only IAS. It makes no sense to me. Could you provide a reference? Mike MU-2 I'm not sure this is addressed to me, but just in case it is: I guess the notion about Vne as a TAS is that Vne may be specified for a given aircraft as an airspeed that depends on altitude. I guess it could as easily be specified as an IAS at sea level and gross weight, with a written notice to the pilot that Vne would then be at a lower IAS as altitude increases. Does this make any sense? Yes and no. What you are describing is Mmo which is the limiting Mach number. It is not Vne. Vne is a fixed mark on the airspeed indicator and, as such, doesn't move. Mmo is a red "barber pole" on the airspeed indicator which moves down as altitude increases. Mike MU-2 |
On Wed, 09 Mar 2005 16:29:46 GMT, "Mike Rapoport"
wrote: "Jim" wrote in message .. . On Wed, 09 Mar 2005 14:58:38 GMT, "Mike Rapoport" wrote: "Morgans" wrote in message ... "Mike Rapoport" wrote I always thought that the "coffin corner" was where stall speed met the Mach limit. I didn't think that it even applied to non-jet aircraft. Mike No, I think the post above yours got it pretty much right..Vne is significant, in that it demonstrates itself by nasty things like flutter, or control reversal. Pull back on the stick to maneuver, or slow down, and stall, or at least buffet like hell. It is true, however, that it is pretty tough for a non jet aircraft to get to the coffin corner. The Exxon tiger (can't think of the guy's name) that has been trying to get the piston altitude record, has said that he is really close to getting into coffin corner. -- Jim in NC I've never heard of Vne being related to TAS, only IAS. It makes no sense to me. Could you provide a reference? Mike MU-2 I'm not sure this is addressed to me, but just in case it is: I guess the notion about Vne as a TAS is that Vne may be specified for a given aircraft as an airspeed that depends on altitude. I guess it could as easily be specified as an IAS at sea level and gross weight, with a written notice to the pilot that Vne would then be at a lower IAS as altitude increases. Does this make any sense? Yes and no. What you are describing is Mmo which is the limiting Mach number. It is not Vne. Vne is a fixed mark on the airspeed indicator and, as such, doesn't move. Mmo is a red "barber pole" on the airspeed indicator which moves down as altitude increases. Mike MU-2 Well, yes Vne is marked on the ASI, and as such a mark it does not move. On the other hand, for several of the gliders I fly the manufacturers make a point in the POH of directing the pilot to reduce the marked Vne as flight altitude increases. So I take the marked Vne as relating to sea level and adjust it downward at increasing altitudes. |
![]() "Mike Rapoport" wrote I've never heard of Vne being related to TAS, only IAS. It makes no sense to me. Could you provide a reference? Mike True. My mistake. -- Jim in NC |
Interesting wind experience | Roger Long | Piloting | 3 | November 15th 04 05:34 PM |
Two non-aviation questions | Ramapriya | Piloting | 12 | November 10th 04 12:51 AM |
LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 04:33 AM |
Weathervaning | Koopas Ly | Piloting | 50 | November 15th 03 07:56 AM |
Kestral 1000 Wind Speed Meter NEW IN BOX | Cecil E. Chapman | Products | 0 | November 7th 03 06:56 PM |
