X-no-archive: yes
In article , Eric Greenwell writes ContestID67 wrote: I have some fuses in my glider. One is on the main battery itself. The other fuses are in the instrument panel and are for individual devices (radio, computer, vario). I got it in my head that I should replace the panel fuses with breakers. There are several advantages, like being able to reset the breaker in flight and being able to "pull" the breaker. I have been told that all new breakers must be able to be manually pulled (tripped) in case of emergency. Older breakers could be reset but not pulled. Obviously fuses can be pulled also but I have an image of my fumbling the loose glass fuse in the cockpit which isn't a pretty picture. Looking at a particular brand of breaker, the Texas Instrument Klixon 7277 line (http://www.ti.com/snc/products/controls/acb-7277.htm) from Aircraft Spruce, I found that at low current draws you can loose a volt or more from your primary. 1/2A 2.00 Vdc drop my vario 3/4A 1.45 Vdc drop 1A 1.10 Vdc drop my computer 2A 0.70 Vdc drop 3A 0.33 Vdc drop my radio 4A 0.30 Vdc drop 5A 0.25 Vdc drop This is not good. It got me thinking that a glass fuse isn't too bad after all especially considering a fuse is $1 each and the breaker is $25 each. In 5000 hours of flying gliders, I've only had to replace a fuse once in flight (fuse actually went bad), and disconnect only one fuse (gear warning going off at the wrong time). I think electrical problems where a breaker would be handy are so rare, I like to keep it simple: I have a master switch to disconnect the battery if there is smoke, and then just fuses on the usual things. I carry a fuse of each type in a little baggie in the pocket so I can replace fuse if I need to. That may be so Eric, but breakers stop the incorrect value fuse being used if it is the only one available. One option worth considering is the use of Self Resetting Fuses. These electronic devices work like breakers but reset themselves when the load is removed. Tim Newport-Peace "Indecision is the Key to Flexibility." |
"zero" versus "oscar" versus "sierra" | Ron Garret | Piloting | 30 | December 20th 04 08:49 AM |
Buying a plane versus renting | RD | Owning | 35 | March 5th 04 09:42 PM |
leaving alternator breakers on all the time | Frank Ch. Eigler | Owning | 9 | October 24th 03 06:14 AM |
Aircraft circuit breakers | Bill Staley | Soaring | 5 | October 6th 03 03:06 AM |
Cessna 340 Tie down versus Hangar | endre | Owning | 11 | July 17th 03 01:49 AM |
