MJC wrote:
... or it that's a "problem" for you, do what I did. RV7-A Quickbuild kit. Poof; lot's less rivets :-) I thought the design was the same and hence the same number of rivets .... just fewer for you to set! :-) Matt |
Well yea, but that's what I thought Brian had a problem with, i.e., not
how many rivets are in the aircraft, but how many he personally had to set. With the QB kit, the number of rivets the builder has to set is inconsequential. MJC "Matt Whiting" wrote in message ... MJC wrote: ... or it that's a "problem" for you, do what I did. RV7-A Quickbuild kit. Poof; lot's less rivets :-) I thought the design was the same and hence the same number of rivets ... just fewer for you to set! :-) Matt |
"C-175 SoCal Beware" Original Poster Replies | Bill Berle | Home Built | 3 | July 8th 04 07:01 AM |
Poppers Revisted and the Return of the Teenie Two | Veeduber | Home Built | 0 | March 29th 04 09:57 AM |
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? | jls | Home Built | 3 | February 3rd 04 12:15 AM |
Bonded aluminum aircraft structures | asennad | Home Built | 9 | December 31st 03 02:58 PM |
Dimpling and riveting pressures | Max Krippler | Home Built | 5 | November 11th 03 08:03 PM |
