"Mike Rapoport" wrote
Thanks, it does. The question of what the red mark on powered airplanes means remains. Is it Vne at the aircraft's ceiling? If it is Vne at sea level then there should be some language in the flight manual warning of this. Mike... this is from 23.1545 (c) If VNE or VNO vary with altitude, there must be means to indicate to the pilot the appropriate limitations throughout the operating altitude range. (d) Paragraphs (b)(1) through (b)(3) and paragraph (c) of this section do not apply to aircraft for which a maximum operating speed VMO/MMO is established under §23.1505(c). For those aircraft there must either be a maximum allowable airspeed indication showing the variation of VMO/MMO with altitude or compressibility limitations (as appropriate), or a radial red line marking for VMO/MMO must be made at lowest value of VMO/MMO established for any altitude up to the maximum operating altitude for the airplane. Bob Moore |
![]() "Bob Moore" wrote in message . 121... "Mike Rapoport" wrote Thanks, it does. The question of what the red mark on powered airplanes means remains. Is it Vne at the aircraft's ceiling? If it is Vne at sea level then there should be some language in the flight manual warning of this. Mike... this is from 23.1545 (c) If VNE or VNO vary with altitude, there must be means to indicate to the pilot the appropriate limitations throughout the operating altitude range. (d) Paragraphs (b)(1) through (b)(3) and paragraph (c) of this section do not apply to aircraft for which a maximum operating speed VMO/MMO is established under §23.1505(c). For those aircraft there must either be a maximum allowable airspeed indication showing the variation of VMO/MMO with altitude or compressibility limitations (as appropriate), or a radial red line marking for VMO/MMO must be made at lowest value of VMO/MMO established for any altitude up to the maximum operating altitude for the airplane. Bob Moore Thanks for the reference. It makes sense now. Mike MU-2 |
Interesting wind experience | Roger Long | Piloting | 3 | November 15th 04 05:34 PM |
Two non-aviation questions | Ramapriya | Piloting | 12 | November 10th 04 12:51 AM |
LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 04:33 AM |
Weathervaning | Koopas Ly | Piloting | 50 | November 15th 03 07:56 AM |
Kestral 1000 Wind Speed Meter NEW IN BOX | Cecil E. Chapman | Products | 0 | November 7th 03 06:56 PM |
