Seniors Contest
Old March 10th 05, 03:34 PM
BB
I'd appreciate the details of any and all mishaps that you or others
know
about that you feel are a result of finish gates.
A small sample of serious finish accidents.
1.
NTSB Identification: FTW94LA237 .
The docket is stored in the Docket Management System (DMS). Please
contact Public Inquiries
14 CFR Part 91: General Aviation
Accident occurred Saturday, July 16, 1994 in LITTLEFIELD, TX
Probable Cause Approval Date: 1/12/1995
Aircraft: SCHWEIZER SGS 1-26E, registration: N33915
Injuries: 1 Serious.
WITNESSES SAID THE PILOT COMPLETED A GLIDER COMPETITION LOW AND SLOW AT
THE FINISH. THE PILOT TURNED LEFT ONTO THE DOWNWIND LEG, FOLLOWED BY A
STEEP LEFT TURN AND NOSE PITCH DOWN. IMPACT OCCURRED NOSE LOW STILL
TURNING LEFT.
2.
NTSB Identification: FTW86FRG30 .
The docket is stored on NTSB microfiche number 32434.
Accident occurred Monday, August 04, 1986 in UVALDE, TX
Aircraft: SCHLEICHER ASW-20, registration: N20TS
ACFT WAS COMPETING IN THE NATL SOARING CHAMPIONSHIPS AND HAD JUST
CROSSED THE FINISH LINE AT 50' AGL AND 85 KNS A/S WHEN IT ENTERED A
MANEUVER TO REVERSE DIRECTION AND CLIMB TO PATTERN ALT FOR LANDING.
DURING THE TURN THE ACFT STALLED AND STRUCK A POWER LINE DURING THE
SUBSEQUENT DESCENT. AFTER IMPACT, THE ACFT SLID INTO A VEHICLE. THE PLT
MAY HAVE BEEN DISTRACTED BY OTHER ACFT OPERATING IN THE PATTERN.
3.
NTSB Identification: LAX90FA310 .
The docket is stored on NTSB microfiche number 45117.
Accident occurred Sunday, September 02, 1990 in CALIFORNIA CITY, CA
Probable Cause Approval Date: 12/30/1992
Aircraft: Schempp-Hirth NIMBUS-2C, registration: N39285
Injuries: 1 Fatal.
THE PILOT WAS PARTICIPATING IN A ROUND-ROBIN SOARING CHAMPIONSHIP
CONTEST. WHEN THE GLIDER WAS ABOUT 2 MILES EAST OF THE FINISH LINE THE
PILOT RADIOED THAT HE WAS INBOUND. WHEN THE GLIDER WAS ABOUT 1/4 OF A
MILE EAST OF THE FINISH LINE WITNESSES OBSERVED ITS AIRSPEED APPEARED
TO BE LESS THAN NORMAL. AFTER CROSSING THE FINISH LINE THE GLIDER
ENTERED INTO A CLIMBING RIGHT TURN. WHEN THE GLIDER COMPLETED ABOUT A
180 DEGREE TURN, IT STALLED AND ENTERED INTO A SPIN. A GLIDER PILOT WHO
OVERTOOK THE ACCIDENT GLIDER REPORTED THAT THE ACCIDENT PILOT BEGAN TO
PREMATURELY DISPERSE HIS WATER BALLAST ABOUT 10 MILES EAST OF THE
AIRPORT FINISH LINE.
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
THE PILOT'S IMPROPER DECISION TO EXECUTE THE RAPID CLIMBING TURN
MANEUVER AT AN INSUFFICIENT AIRSPEED. CONTRIBUTING TO THIS ACCIDENT WAS
THE PREMATURE DUMPING OF THE GLIDER'S WATER BALLAST.
4.
NYC00LA171
On June 19, 2000, about 1630 Eastern Daylight Time, a Schempp-Hirth,
Ventus 2CM motorglider, N800PF, was substantially damaged while
maneuvering to land at the Warren-Sugarbush Airport, Warren, Vermont.
The certificated commercial pilot was seriously injured. Visual
meteorological conditions prevailed and no flight plan was filed for
the personal local flight conducted under 14 CFR Part 91.
According to a Federal Aviation Administration inspector, the pilot was
participating in a glider race at the airport. The race was to be
conducted without motorized power and the motorglider was towed to
altitude.
According to the pilot, after crossing the finish line at the end of
the race, he received a radio call from the airport that the winds had
changed direction and landings were being conducted on Runway 22. The
pilot executed a 180-degree turn and entered the traffic pattern for
the runway. While turning base to final, the pilot was unable to stop
the turn with full opposite aileron due to turbulence. As the
motorglider descended, the pilot was able to level the wings, but was
90 degrees to the runway and "into the trees." The pilot raised the
nose of the glider to decrease airspeed, and the motorglider stalled,
impacting trees short of the runway.
The winds reported by an airport located about 13 miles east of the
accident, at 1651, were from 350 degrees at 7 knots.
Two more, not contest participants, but fatalities doing contest
finishes.
5.
NYC01FA071
HISTORY OF FLIGHT
On January 28, 2001, a Schempp-Hirth, Discus CS glider, N814CU, was
substantially damaged while attempting to land at Wurtsboro Airport,
Wurtsboro, New York. The certificated private pilot was fatally
injured. Visual meteorological conditions prevailed for the personal
flight. No flight plan had been filed for the local flight conducted
The pilot performed a high-speed pass down runway 23, and either
touched the runway momentarily, or was very close to it. He then pulled
up to about 500 feet agl, and entered a left crosswind, followed by a
downwind for runway 23. The traffic pattern appeared normal to the
observers.
While on base leg, the glider was observed to enter a left turn prior
to having reached a position from which the turn to final would
normally have been made. The left turn increased in bank angle, the
nose dropped and the glider disappeared from view. Some of the
witnesses said the glider appeared slow and was in a nose up attitude.
The bank angle was estimated to be in excess of 60 degrees, and the
nose down attitude at least 45 degrees.
6. This was on the rest day of 15 meter nationals
NTSB Identification: FTW01LA179.
Accident occurred Sunday, August 12, 2001 in Uvalde, TX
Probable Cause Approval Date: 2/20/2002
Aircraft: PDPS PZL-Bielsko SZD-55-1, registration: N55VW
Injuries: 1 Fatal.
The commercial pilot was completing the third leg of a soaring 300 km
triangle. The glider owner, who was in contact with the pilot via
radio, reported that the pilot stated he had the field in sight
approximately 8 miles from the airport. The glider entered the traffic
pattern for runway 15 and was turning base when the owner observed it
enter a spin. A witness reported that the glider banked, "appeared to
have stalled, and spiraled counter-clockwise" in a nose low attitude
into the ground. Another witness, located approximately a block from
the accident site, stated that she "looked up and saw the glider
spinning counter clockwise very fast and falling nose first." The
glider impacted the ground and came to rest approximately 1/4 mile from
the approach end of runway. The pilot had accumulated approximately 270
total glider flight hours and 5 flight hours in the same make and model
as the accident aircraft. No pre-impact anomalies were noted with the
glider during the examination.
(There was a low pass here too, though not mentioned in the official
report. I guess pilots are smart enough not to talk too much to the FAA
and NTSB!)
John Cochrane
BB
Old March 11th 05, 03:49 AM
Kilo Charlie
Every single one of these is a stall spin accident. They are examples of
poor judgement and are not different than any other stall spin
accident....e.g. from base to final. To suggest that this is not related to
judgement but to the gate is a huge stretch. Some are not even contest
flights and are therefore unrelated to finish gates at all.
An example of an accident that is related to the finish gate is if there
were a midair at the gate.
So it brings back to attempting to legislate good judgement.
Casey Lenox
KC
Phoenix
Old March 11th 05, 05:17 AM
Marc Ramsey
So, stalling and spinning moments after what are clearly, in several
cases (including the most recent), botched gate finishes (i.e.,
insufficient energy) has absolutely nothing to do with the use of a
gate, while stalling and spinning at 600 feet while trying to sneak over
the edge of a finish cylinder, proves that cylinder finishes are
dangerous?
You've got it! I can choose not to finish at 50 feet, but I have no
control over the potential for a midair. I have had trouble several
times with having to land between gliders crossing my base leg low and
fast on their way to the finish gate. There was also the time someone
cut me off at the gate, by hooking it 100 feet in front of me. Maybe I
missed the finish calls, or maybe they didn't make them, it really
doesn't matter. Poor judgment and bad luck may well equal two dead
contest pilots one of these days.
The bottom line is this, whoever is fastest with a 50 foot gate, is also
going to be fastest with a 500 foot cylinder. So, why do some insist
upon trying to force use of a "fun" finish procedure that quite a few of
us find dangerous? As far as I'm concerned, if even one participant
objects, a gate shouldn't be used (and, yes, I have objected, and have
been overruled). If everyone agrees, have a good time...
Yeah, what a silly thing to do...
Marc
Old March 11th 05, 12:47 PM
I agree with Casey... but I'd rephrase it in a less politically correct
way:
There are some pilots who train for a racing environment and many who
don't. No surprise then that the latter are incompetent in some of the
basic skills of racing. Like taking off with water, centering thermals,
gaggle etiquette, and finishing. As finishes are highly regulated (a
requirement for safety), one way to short cut ignorance is to change
them into something we can all do. LCD. The inertia of ignorance and
lassitude will always overcome skill and enthusiasm (sadly, by shear
force of numbers).
There is nothing inherently dangerous in a line finish accomplished by
skillful pilots exercising good judgement. There IS unbounded risk in
any maneuver attempted by pilots who take the environment too lightly.
If you don't want to improve your skills, why compete? That's the point
of it, after all. To compare yourself to others... to enter into a
rivalry. When you meet someone better, you tip your hat to his or her
skills and accomplishments, then redouble your efforts to improve your
own. If that doesn't sound like your cup of tea, stop competing and
start attending soaring camps. They're fun too.
And, of course, there's the simplest solution of all. If you have to
race, but don't like finish lines, then finish high. You are allowed to
do that. If I thought that the finish line was inherently dangerous,
I'd be up there with you. God knows I do my level best to keep a good
distance between me and the prestart gaggle -- whenever I can. Now if
you want to improve safety, put some effort into that!
examples of
related to
contest
there
Casey Lenox
KC
Phoenix
Old March 11th 05, 01:19 PM
Fred Mueller
I'm kinda new at this, but here's my two cents worth. There is an
advantage to a finish line that we don't see with a cylinder finish.
Everyone is funneled through a fairly precise point so we know where to
look for traffic and we have a fairly good idea how their pattern to
land will look. In a cylinder finish, all bets are off and every type
of pattern entry known to man from every possible direction is
accomplished along with often unpredictable results, this is especially
bad during a MAT or when different classes are finishing from different
directions. There are ways to solve this but it makes things more
complicated than a simple finish line.
FM
remove nospam to reply
way:
force of numbers).
examples of
related to
contest
there
Casey Lenox
KC
Phoenix
Old March 11th 05, 02:01 PM
Bert Willing
The 5km finish cylinder procedure with 200m min agl which I am used to has
no traffic problems at all.
Bert Willing
ASW20 "TW"
"Fred Mueller" a écrit dans le message de
news: ...
look for traffic and we have a fairly good idea how their pattern to land
will look. In a cylinder finish, all bets are off and every type of
pattern entry known to man from every possible direction is accomplished
along with often unpredictable results, this is especially bad during a
MAT or when different classes are finishing from different directions.
There are ways to solve this but it makes things more complicated than a
simple finish line.
FM
way:
force of numbers).
examples of
related to
contest
there
Casey Lenox
KC
Phoenix
Old March 11th 05, 09:00 PM
Eric Greenwell
New enough that you haven't used a finish line with the ground at the
bottom? If you haven't, it might be harder to understand how it works
out in practice.
I don't see this happening in the contests I've flown with large, high
cylinder finishes. All the pilots that had a good finish have been able
to use the standard pattern to land. Pilots that did not have a good
finish often used non-standard patterns, such as rolling finishes or no
downwind leg, and so on.
this is especially
directions.
My experience is the low finish line is worse in these conditions,
because the pilots are NOT being "funneled" (brought along a small angle
sector) to a precise point: they arriving_ spread out more or less along
the line from many different directins, including 180 degrees apart,
with some hooking the gate and doing a very non-standard pattern entry.
I've even seen 180s after a finish, with the glider landing back into
the oncoming finishers.
Eric Greenwell
Washington State
USA
Old March 12th 05, 12:31 PM
Fred Mueller
out in practice.
Not that new.
Fred
Old March 14th 05, 08:27 PM
Papa3
My experience is th low finish line is worse in these conditions,
angle
along
entry.
Eric Greenwell
Washington State
USA
I'm still on the fence on this one, but here's my "philosophy" on
rules. I think the primary purpose of the rules should be to protect
me from you (the imperial you - not any of the current posters :-), not
to protect me from myself. With that in mind, I feel like mid-air
collision avoidance should be the primary purpose of the finishing
routine, whether it be gate or cylinder. Given my very selfish goal,
which finishing routine does a better job? I have to say that in my
first 15 years of racing using a high speed gate, I really never had
any close calls. I found the situational awareness to be relatively
manageable given good radio ettiquette and a reaonable level of
professionalism among the other competitors. I have a lot less
experience with the cylinder, but my recollection from the few that
I've flown was a slightly increased nervousness about people
approaching from numerous directions, resulting in more slumped
shoulders (ie. trying to make myself feel like a small target).
So, which finishing routine does a better job of facilitating the
avoidance of a midair?
Erik Mann
LS8-18 (P3)
Old March 11th 05, 03:01 PM
toad
I am a fairly new contest pilot, flying in sport's class in the
northeast.
If I had a competitive glider I might consider standard/15m class.
So take my comments as someone who has never had to do a gate finish
for real, but has considered them, practiced them and does consider
them inherently dangerous.
by
I consider them to be inherently dangerous because the solution for
the fastest time pushes the pilot towards a very dangerous flying
situation.
Flying at best speed to fly for the last thermal all the way to 50agl
at the finish line. For my Grob102, if I was in a 4 knot thermal
that's 79 knots.
Also it's a 25/1 glide ration so at 1 nm away I am at 290 feet, 2nm at
540 feet. This seems pretty dangerous to me. If I hit sink, then I am
landing wherever the sink hit me, without any chance for picking a
field, flying a pattern, etc. Even if don't hit sink, I am still only
set up to land straight ahead past the finish line.
So most pilots add some safety margin (in the form of extra potential
energy), they take the thermal higher than they should (from a speed
perspective). As they get closer to the finish line, they convert the
potential energy to speed. Then re-convert the speed to height for a
'normal' pattern.
The problem is that you score higher (faster) for a lower safety
margin.
Why not just set the minimum required safety margin for all pilots ?
The required finish altitude is just that, a minimum safety margin for
all contest pilots. The rules are saying "if you reduce the safety
margin less than this, you will not get a better score than this."
to
do that.
But the rules should not provide a scoring benefit to the pilots who
decide to reduce the safety margin. I don't want to be thinking "hey,
if I really push this final glide I might make up that 20point
advantage my competitor got yesterday."
Todd Smith
3S
2005 Region 7 Contest Paul Remde Soaring 0 August 13th 04 03:48 AM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
USA Double Seater Contest Thomas Knauff Soaring 1 April 13th 04 05:24 PM
30th Annual CCSC Soaring Contest Mario Crosina Soaring 0 March 17th 04 06:31 AM
2003 Air Sailing Contest pre-report synopsis Jim Price Soaring 0 July 10th 03 10:19 PM
