Global Flyer
Old March 7th 05, 02:52 PM
Dan Nafe
Ron Wanttaja wrote:
On Sun, 06 Mar 2005 23:33:48 -0500, Dan Nafe wrote:
[snip]
Doesn't the vehicle get lighter as fuel and oxidizer are consumed,
requiring less thrust, lowering the consumption rate...
Exactly, but the basic rocket equation takes that into account:
Fuel = Initial Mass * (1 - 1/(e^(Delta-V/(ISP * g)))
I guess that is why you are a rocket scientist.
Dan "Damn-it-Jim,-I'm-a-doctor" Nafe
  #62
Old March 8th 05, 02:20 PM
Darrel Toepfer
Rich S. wrote:
P.S. I like that idea about recycling boomers!
They were hovercrafts in "The Matrix" or very close to it...
  #63
Old March 10th 05, 03:05 AM
StellaStarr
Ron Wanttaja wrote:
they powered Honolulu with
the output of *one* of these subs.
Cooling them in space, where you don't have access to billions of tons of cold
sea water, is left to the good offices of your local thermal engineer.
Help me out with this one. While all the sci-fi I sopped up as a kid
referred to the "cold of outer space," isn't vacuum a perfect insulator?
How WOULD you cool the reactors (or whatever engine) with no atmosphere
or handy heavy liquid at lower temp? Wouldn't it take a long time for
the excited molecules to settle down?
I love this thread.
  #64
Old March 10th 05, 03:50 AM
UltraJohn
cold sea water, is left to the good offices of your local thermal
engineer.
I love this thread.
Yea I already have my moon station built and the prefab's ready to ship,
life supports finished now all I need is to complete the rockets to get
them there! As soon as I'm finish with the KR-2 ( at current rate that will
take another 30 years!).
John
wishin and dreamin
  #65
Old March 10th 05, 04:12 AM
Yes, it would. The vacuum of space is an excellent insulator, but there's a lot
of "nothing" to suck your heat away. Operational spacecraft usually have
problems with TOO much heat, but if stuff shuts down, things get cold. If the
Space Shuttle doesn't get the doors open soon after orbital insertion, it has to
land, fast...the spacecraft's radiators are on the inside of the doors. On the
flip side, remember the movie, with the power-conserving astronauts freezing.
You get rid of heat with, basically, radiators. Point 'em at black space and
that's about the best you can do.
Cooling a submarine reactor in space is going to be difficult, since IIRC
correctly the reactor is basically a heat source for the creation of steam,
which then turns the turbines that rotates the screws or spins the generators.
You might end up with a big external radiator, kind of like a conventional solar
array only you keep it turned FROM the sun. I don't like this solution, as a
leak is not only going to spew your precious coolant into space, but act as a
thruster upsetting your attitude.
I kind of like the thought of "rafting" three sub hulls side-by side, with the
two outer ones lacking a reactor but stringing radiator tubes on the inside of
the hulls. You might even run radiator lines all through the hulls, then fill
the whole hull with water and freeze them before launch. But like I said, I
ain't a thermal engineer.
Old March 10th 05, 05:40 AM
Agghhh, I was a bit rushed and edited this wrong. Insert "Apollo 13" after
"...remember the movie,".
Old March 10th 05, 03:27 PM
Gary Thomas
Ron Wanttaja wrote:
snip
snip
If we're going to take along precious coolant I vote for Newcastle Brown
Ale ;^) And if you lose it there will be an upset attitude G
  #68
Old March 10th 05, 05:04 PM
Rich S.
"Blueskies" wrote in message
. com...
Big bouncy spring thing hopping between the craters...
At first I laughed - but now that Ron has 'splained things to me, you might
have been right after all!
Rich "If you have to have something to push against, why not the Moon?" S.
  #69
Old March 10th 05, 05:10 PM
Rich S.
"Gary Thomas" wrote in message
Hmmm...... What would be the thrust numbers (ft/sec) for Muzzleloader, I
wonder? What would you carry as an oxidizer? Can it be synthesized from
locally available materials?
Chuck - could you run some experiments with an Earth-bound
Muzzleloader-propelled ultralight and give us some numbers?
Rich S.
  #70
Old March 10th 05, 09:31 PM
Morgans
Yep, I know of the perfect oxidizer. Grind up a bit of BoB U, and combine
them, for the perfect result. From what I hear, they do burn out rather
quickly, but *can* be revived to burn again. Bfg
Jim in NC
About the Global Flyer robert arndt Military Aviation 0 January 11th 04 03:46 AM
Call your local TV station, get Wright Flyer on the air Mark James Boyd Soaring 0 December 17th 03 05:09 PM
Wright Flyer won't fly! Trent Moorehead Piloting 31 October 18th 03 04:37 PM
Wright Flyer Dave Hyde Home Built 9 September 29th 03 05:20 PM
Arming Global Hawk Draws Conflicting Comments From Pentagon Larry Dighera Military Aviation 5 July 14th 03 08:51 PM
