Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Vibration Monitor (Hyde, Wanttaja?)
Old March 13th 05, 01:35 PM
Morgans
"sleepy6" wrote
That notch causes a much larger timing blip in the signal than any
crank movement will cause. By measureing the time between the timing
blips you can determine the amount of rotation after a timing blip that
you see an up or down crank movement event.
What sort of technology does a proxomity detector use? Magnetics, sonic,
radio waves?
Jim in NC
Old March 13th 05, 05:11 PM
RST Engineering
Yes, all of the below.
Sometimes you drill a hole in a small magnet and use a small screw to hold
it to the propeller backing plate. Sometimes you use a strip of reflective
tape on the prop itself. Sometimes you use a pulse from the #1 magneto
lead.
"Morgans" wrote in message
radio waves?
Jim in NC
Old March 14th 05, 12:49 AM
Morgans
"RST Engineering" wrote in message
reflective
lead.
This guy was talking about a notch and proximity detector for the phase
detection. I know about all of the things you mentioned, but the proximity
detector's workings are new to me.
Jim in NC
Old March 14th 05, 04:06 AM
Robert Bonomi
reflective
lead.
Think of a proximity detector as 'ultra short-range radar'. grin
It may use reflected RF energy, or 'optical'.
where the 'excursions' you're trying to measure are smaller than the
wavelength of the measuring 'beam', you can use simple phase-shift
between outgoing and returning signal, to determine distance.
where the distance is much larger than the wavelength, you have to
impress a carrier on the beam, and measure phase-shift in the carrier
frequency. this gets an 'approximate' distance, that can be further
refined by phase angle measurements of the beam itself.
Capacitance tracking is also a possible approach.
and/or "Hall effect".
These can get 'messy', due to inherent non-linearity in the technology,
that has to be compensated for, in 'reading' the signals.
Capacitance tracking works best where there are *very*small* vibrations
involved, and a very _smooth_ surface to measure against. The technique
is capable of mapping individual atoms/molecules in a crystal lattice.
Scientific American had a write-up -- at least 15 years ago -- about
a new 'super microscope' (successor generation to the scanning electron
microscope) that worked in that manner. a _very_fine_ 'needle' was
carefully moved, raster-style, across the object being 'scanned', and
the capacitance changes between the needle and the object were mapped.
Old March 14th 05, 04:54 AM
mindenpilot
"Robert Bonomi" wrote in message
hold
reflective
lead.
proximity
Actually, the proximity probes I am familiar with work on the "eddy current"
principle.
That is, RF energy is directed at the shaft through a coil. Some of the
energy is lost into the shaft in the eddy currents.
The energy that is coupled back into the coil is the measured signal.
Since the amount of energy dissipated in the shaft is proportional to the
distance between the shaft and probe, the result is a displacement
measurment.
Adam
Old March 14th 05, 05:15 AM
Robert Bonomi
hold
reflective
lead.
proximity
principle.
measurment.
No doubt about it, there are *LOTS* of ways to measure proximity.
Eddy current detectors have somewhat limited application.
1) the material of the item measured must be uniform in composition where
it is 'presented' to the detector.
2) the material has to be electrically conductive to a degree. If the item
under test is a good insulator, you don't get eddy currents, If the item
is _too_good_ a conductor, you don't get eddy currents.
For engine shafts, etc. those items are a "non-issue", agreed.
They don't work worth a d*mn if you're trying to measure motion in a rubber/-
polyethylene/vinyl/whatever drive belt, though. grin
Old March 14th 05, 08:23 AM
Morgans
and some others contributed lots
And I think I'm almost sorry I asked! g?
Jim in NC
Vibration Monitor (Hyde, Wanttaja?) RST Engineering Home Built 71 April 4th 05 04:44 PM
Pinging Ron Wanttaja - "Unporting?" Bob Chilcoat Home Built 13 November 24th 04 07:28 PM
Vibration Testing Jim Weir Home Built 20 October 10th 04 07:22 AM
Vibration Testing Jim Weir Owning 21 October 10th 04 07:22 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
