Based upon my experience, lithium batteries has a steeper voltage decrease
curve when the voltage does start to decline than alkaline. If that is the case, then once the voltage decreased to the voltage required to set off the low voltage warning, it may have much less time until it is no longer usable than a standard alkaline battery. Thus, the warning time may be less for a lithium battery than the alkaline. Also, I have learned another lesson about lithium batteries. I was servicing a piece of battery operated equipment. It was off and I checked the lithium battery and it measured about 9 volts. I then proceeded to waste a half hour looking for other problems and decided to install another battery. Presto, it worked fine. Then I noted that a depleted lithium battery will measure almost full voltage when there is no load. Under a slight load, it dropped down to 3 volts. Alkalines are very good about measuring voltage, even without a load. Always measure the voltage of the lithium battery under the intended load. Colin N12HS |
![]() "COLIN LAMB" wrote in message ink.net... Based upon my experience, lithium batteries has a steeper voltage decrease curve when the voltage does start to decline than alkaline. If that is the case, then once the voltage decreased to the voltage required to set off the low voltage warning, it may have much less time until it is no longer usable than a standard alkaline battery. Thus, the warning time may be less for a lithium battery than the alkaline. Also, I have learned another lesson about lithium batteries. I was servicing a piece of battery operated equipment. It was off and I checked the lithium battery and it measured about 9 volts. I then proceeded to waste a half hour looking for other problems and decided to install another battery. Presto, it worked fine. Then I noted that a depleted lithium battery will measure almost full voltage when there is no load. Under a slight load, it dropped down to 3 volts. Alkalines are very good about measuring voltage, even without a load. Always measure the voltage of the lithium battery under the intended load. Colin N12HS It's not unusual for any battery chemistry to show a higher voltage when a discharged cell is tested against a high impedance DVM. That's why all battery testers check a cell against a load. Based on interpolation of the Energizer 9V Lithium 5mA discharge data curve, it appears that the 6 .5V warning flash will begin somewhere after 230 hours in service and the cutoff at 5V will occur 20 hours later. MH states that you should expect only 4 hours of alkaline battery life after the low battery warning flashes start. This strongly suggests that you should expect 5 times the battery life with a lithium 9V after the warning. That's not a particularly steep discharge curve. It actually should be better since MH states that the mean draw of the EDS is 3.5 mA and the Energizer discharge data is for 5mA draw. See: http://data.energizer.com/PDFs/l522.pdf I think I can live with that. I'll be using a lithium 9V and replace it at the beginning of each season. Bill Daniels |
Air defense (naval and air force) | Mike | Military Aviation | 0 | September 18th 04 04:42 PM |
Naval air defense | Mike | Naval Aviation | 0 | September 18th 04 04:42 PM |
Air Force Helper 2000 | tomcat | Naval Aviation | 0 | June 9th 04 11:54 PM |
Air Force Helper 2000 | tomcat | Military Aviation | 0 | June 9th 04 11:54 PM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
