I made the same decision against getting a IFR GPS and statyed with /U
on my plane. I did get a Garmin 196 and it works fabulously along with my onboard VOR on IFR flights. I made this choice because nearly all the airports that I fly IFR into have ILS. |
M wrote:
I made the same decision against getting a IFR GPS and statyed with /U on my plane. I did get a Garmin 196 and it works fabulously along with my onboard VOR on IFR flights. I made this choice because nearly all the airports that I fly IFR into have ILS. Nothing wrong with this but more and more airports are getting GPS approaches for the opposite and crossing directions to the ILS runways. So if the wind doesn't work for the ILS runway you can make a straight in approach instead the more dangerous circle to land from the ILS option; lower minimums to boot. |
Doug Carter wrote:
So if the wind doesn't work for the ILS runway you can make a straight in approach instead the more dangerous circle to land from the ILS option; lower minimums to boot. I haven't done a survey, but my impression is that the average straight in GPS approach has higher minimums than the average ILS circling approach. I agree I'd rather land straight in if possible, though. DGB |
Dave Butler wrote:
Doug Carter wrote: So if the wind doesn't work for the ILS runway you can make a straight in approach instead the more dangerous circle to land from the ILS option; lower minimums to boot. I haven't done a survey, but my impression is that the average straight in GPS approach has higher minimums than the average ILS circling approach. I agree I'd rather land straight in if possible, though. DGB You may be correct but I looked at about a dozen airports in the Southwest and in all cases the GPS approach was lower than the ILS circling minimums. Now that I think of it, I was looking at actual LNAV approaches, not GPS overlays of NDB or VOR approaches. This could be a difference. |
![]() Interestingly enough, it seems that on the days when the ceiling/vis is low enough to make circling approach difficult are also likely to be the days when the wind is either very light or lined up with the ILS straight-in direction. Nothing wrong with this but more and more airports are getting GPS approaches for the opposite and crossing directions to the ILS runways. So if the wind doesn't work for the ILS runway you can make a straight in approach instead the more dangerous circle to land from the ILS option; lower minimums to boot. |
Adding IFR Plane Certification To Planes Without It | Blanche Cohen | Owning | 10 | November 29th 04 06:37 PM |
Aircraft certification questions. | psyshrike | Home Built | 40 | November 22nd 04 06:10 PM |
Aircraft certification questions. | psyshrike | Owning | 42 | November 22nd 04 06:10 PM |
certification of composite aircraft | sebastian | Home Built | 6 | March 25th 04 03:48 PM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
