IFR GPS certification
Old March 15th 05, 12:14 AM
Doug Carter
M wrote:
I made the same decision against getting a IFR GPS and statyed with /U
on my plane. I did get a Garmin 196 and it works fabulously along with
my onboard VOR on IFR flights. I made this choice because nearly all
the airports that I fly IFR into have ILS.
Nothing wrong with this but more and more airports are getting GPS
approaches for the opposite and crossing directions to the ILS runways.
So if the wind doesn't work for the ILS runway you can make a straight
in approach instead the more dangerous circle to land from the ILS
option; lower minimums to boot.
Old March 15th 05, 02:16 PM
Dave Butler
I haven't done a survey, but my impression is that the average straight in GPS
approach has higher minimums than the average ILS circling approach. I agree I'd
rather land straight in if possible, though.
DGB
Old March 16th 05, 04:16 AM
Doug Carter
in GPS approach has higher minimums than the average ILS circling
approach. I agree I'd rather land straight in if possible, though.
DGB
You may be correct but I looked at about a dozen airports in the
Southwest and in all cases the GPS approach was lower than the ILS
circling minimums.
Now that I think of it, I was looking at actual LNAV approaches, not
GPS overlays of NDB or VOR approaches. This could be a difference.
Old March 15th 05, 11:19 PM
M
Interestingly enough, it seems that on the days when the ceiling/vis is
low enough to make circling approach difficult are also likely to be
the days when the wind is either very light or lined up with the ILS
straight-in direction.
runways.
straight
Adding IFR Plane Certification To Planes Without It Blanche Cohen Owning 10 November 29th 04 06:37 PM
Aircraft certification questions. psyshrike Home Built 40 November 22nd 04 06:10 PM
Aircraft certification questions. psyshrike Owning 42 November 22nd 04 06:10 PM
certification of composite aircraft sebastian Home Built 6 March 25th 04 03:48 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
