Tilt rotors vs. helicopters-- manueverability in VT mode.
Old March 14th 05, 10:56 PM
George Vranek
"Jim Burt" schrieb im Newsbeitrag
Lightly loaded, either can do a full range of hover maneuvers. Forward,
backward, sideward, up and down. Heavy, not necessarily so. But then,
same is true of conventional helicopters. . . .
"Charles Gray" wrote in message
Just a question-- how does the X-15 or the V-22 compare to a real
helicopter when hovering? Can they do helicopter style manuvers, or
are we talking more just up and over on the way to horizontal flight?
The tiltrotors have not optimal rotors for hovering and not optimal props
for crusing, Therefore they are les effective in hovering than conventional
helicopters and slower than conventional turboprops in cruising. The only
way, to fly fast with a helicopter is to stowe the rotor blades after the
vertical take off and convert so the helcopter into a fixed wing airplane.
please have a look at www.diskrotor.com .
George
Old March 15th 05, 01:51 PM
Helowriter
The V-22 in helicopter mode flies like a CH-47 or CH-46 tandem. It
hovers, turns, and maneuvers like a helicopter. Fly-by-wire controls
smooth the transition from helo to airplane mode. That said, the
proprotors were cropped to fit Marine amphibious assault ships, so the
V-22 has higher disk loading than an optimized helicopter. That means
it can't carry as much as efficiently as a tandem rotor of the same
size/weight. A V-22 would not be an efficient aircraft for Vertical
Replenishment with lots of hovering. Autorotation capability won't be
as good as a helicopter -- hopefully, you don't have to do it. The
tilt rotor can however cover long distances as an airplane faster and
more efficiently than a helicopter, and that's the payoff.
2 helicopters abandoned Bill Chernoff Rotorcraft 17 December 14th 04 02:44 AM
Future of Surveillance/Attack Helicopters Dave Jackson Rotorcraft 6 March 5th 04 02:58 AM
FA: The Helicopters Are Coming The Ink Company Aviation Marketplace 0 August 10th 03 05:53 PM
Inflatable Rotors (Flying Car?) Ken Sandyeggo Home Built 13 August 6th 03 06:37 AM
Inflatable Rotors (Flying Car?) Ken Sandyeggo Rotorcraft 2 August 6th 03 06:37 AM
