"In future if I go above FL180 I will have a spare battery and a
battery inside my clothing (32C degrees is about optimum battery operation body temp is 36C) with wires and connectors coming out to connect to the EDS unit. I will also carry a spare or emergency oxygen system. As simply having the battery in the pocket of the glider exposes the battery to the cold temperatures so its just as useless. Think of another thing its freezing cold you take your hands out of the gloves you then have to fumble with the battery and fly the glider." Point(s) well made. So far my O2 experience has been up to FL180. Certainly going far above that brings forth other serious considerations. I have thought I would install a continuous flow system as a back-up to the EDS if, and when I decide to fly at those altitudes. Then also a spare/emergency? Do you have any special considerations for the glider primary batteries when it gets that cold? |
![]() "Go" wrote in message oups.com... So far my O2 experience has been up to FL180. Certainly going far above that brings forth other serious considerations. I have thought I would install a continuous flow system as a back-up to the EDS if, and when I decide to fly at those altitudes. Then also a spare/emergency? Do you have any special considerations for the glider primary batteries when it gets that cold? I think it depends on how long exposed as well as how cold. The ship's lead-acid batteries have a fair amount of mass, so internal temperatures will drop more slowly than some other stuff in the glider. Obviously, battery location plays a role too, i.e. it's typically warmer in the cockpit than elsewhere. Since the batteries are discharging and have some internal resistance, the internal power dissipation also adds warmth. That said, battery capacity at freezing will be down some 20% or more, and at -22F, down 50%. I understand Stemme insulated their battery installation for the wave flights in S. America several years ago. bumper ZZ Minden, NV |
Yes the glider batteries were packed by some pilots in foam etc.
I have also pack the baggage compartment with a spare fleece or two less air mass to cool down and it insulates the area as well. "bumper" wrote in message ... "Go" wrote in message oups.com... So far my O2 experience has been up to FL180. Certainly going far above that brings forth other serious considerations. I have thought I would install a continuous flow system as a back-up to the EDS if, and when I decide to fly at those altitudes. Then also a spare/emergency? Do you have any special considerations for the glider primary batteries when it gets that cold? I think it depends on how long exposed as well as how cold. The ship's lead-acid batteries have a fair amount of mass, so internal temperatures will drop more slowly than some other stuff in the glider. Obviously, battery location plays a role too, i.e. it's typically warmer in the cockpit than elsewhere. Since the batteries are discharging and have some internal resistance, the internal power dissipation also adds warmth. That said, battery capacity at freezing will be down some 20% or more, and at -22F, down 50%. I understand Stemme insulated their battery installation for the wave flights in S. America several years ago. bumper ZZ Minden, NV |
Air defense (naval and air force) | Mike | Military Aviation | 0 | September 18th 04 04:42 PM |
Naval air defense | Mike | Naval Aviation | 0 | September 18th 04 04:42 PM |
Air Force Helper 2000 | tomcat | Naval Aviation | 0 | June 9th 04 11:54 PM |
Air Force Helper 2000 | tomcat | Military Aviation | 0 | June 9th 04 11:54 PM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
